Drew Dalgleish wrote:
On Sun, 11 Sep 2005 02:38:36 GMT, On-Condition wrote: Just wondering, exactly why are radial diesels not part of the diesel revival? You can't beat radials on airplanes for smooth reliability. I once saw a cracked-off jug pounding through the cowling as the engine was still running (the single Otter had just landed). If I won the lottery I'd buy a machine shop. My fist project would be to machine a radial case to accept cylinders off a deutz engine There are excavators using those, screaming full tilt all day long with next to no airflow! BTW, weren't there some diesel radials in the early days of aviation? I've seen some photos I think. The high torque of diesel almost begs for that can't-keep-from-turning radial geometry. Anybody know if the Lycoming/Detroit will be air-cooled opposed? |
("On-Condition" wrote)
BTW, weren't there some diesel radials in the early days of aviation? I've seen some photos I think. The high torque of diesel almost begs for that can't-keep-from-turning radial geometry. http://www.goldenwingsmuseum.com/Aircraft%20Pages/Stin-Det.html Golden Wings Museum 1928 Stinson Detroiter Packard Diesel Montblack |
Montblack wrote:
("On-Condition" wrote) BTW, weren't there some diesel radials in the early days of aviation? I've seen some photos I think. The high torque of diesel almost begs for that can't-keep-from-turning radial geometry. http://www.goldenwingsmuseum.com/Aircraft%20Pages/Stin-Det.html Golden Wings Museum 1928 Stinson Detroiter Packard Diesel http://home.earthlink.net/~ralphcooper/pimagh34.htm 2 lbs/hp, but that was then. I'm sure 1/1 could be had today (for air cooled). |
![]() If I won the lottery I'd buy a machine shop. My fist project would be to machine a radial case to accept cylinders off a deutz engine There are excavators using those, screaming full tilt all day long with next to no airflow! Yeah I work in an underground mine. I've seen first hand what kind of abuse these engines can endure in the hands of union personel that hate the things. |
Just wondering, exactly why are radial diesels not part of the diesel revival? You can't beat radials on airplanes for smooth reliability. I once saw a cracked-off jug pounding through the cowling as the engine was still running (the single Otter had just landed). http://www.goldenwingsmuseum.com/Aircraft%20Pages/Stin-Det.html Golden Wings Museum 1928 Stinson Detroiter Packard Diesel John Ousterhaut told me last week that my idea for a diesel rotary engine needed more time back at the ol' drawing board. Translation: It won't work. I didn't tell him I was planning on running discarded Chinese buffet "grease" through it. g Heat the grease with exhaust tubing - start and shut down with a small Jet-A tank. See, I've thought this all through. http://www.greasecar.com/index.cfm Check out the FAQs Montblack |
Any comparison on energy content diesel v vegetable oil?
"Montblack" wrote in message
... ("On-Condition" wrote) I didn't tell him I was planning on running discarded Chinese buffet "grease" through it. g Heat the grease with exhaust tubing - start and shut down with a small Jet-A tank. See, I've thought this all through. http://www.greasecar.com/index.cfm Check out the FAQs On Dutch television they showed a diesel truck that could switch from regular diesel to chicken fat, garbage from a chicken processing plant. The truck ran equally well on both types of 'fuel'... Can you imagine stuffing chicken waste in your diesel-powered plane? Two thoughts: 1. See, chickens *can* fly! 2. Finally a positive effect of a bird strike.. Rob |
On Sun, 11 Sep 2005 22:38:52 +0200, "Rob Turk"
wrote: On Dutch television they showed a diesel truck that could switch from regular diesel to chicken fat, garbage from a chicken processing plant. The truck ran equally well on both types of 'fuel'... Can you imagine stuffing chicken waste in your diesel-powered plane? 2. Finally a positive effect of a bird strike.. All you need is something like a Bussard ramscoop, and you can fly forever..... Ron "Or a Bustard Ramscoop" Wanttaja |
Just imagine the entries to all the fly in's smelling like fried
chicken!!!! ![]() Patrick student SPL aircraft structural mech "Ron Wanttaja" wrote in message ... On Sun, 11 Sep 2005 22:38:52 +0200, "Rob Turk" wrote: On Dutch television they showed a diesel truck that could switch from regular diesel to chicken fat, garbage from a chicken processing plant. The truck ran equally well on both types of 'fuel'... Can you imagine stuffing chicken waste in your diesel-powered plane? 2. Finally a positive effect of a bird strike.. All you need is something like a Bussard ramscoop, and you can fly forever..... Ron "Or a Bustard Ramscoop" Wanttaja |
Rob Turk wrote:
"Montblack" wrote in message ... ("On-Condition" wrote) I didn't tell him I was planning on running discarded Chinese buffet "grease" through it. g Heat the grease with exhaust tubing - start and shut down with a small Jet-A tank. See, I've thought this all through. http://www.greasecar.com/index.cfm Check out the FAQs On Dutch television they showed a diesel truck that could switch from regular diesel to chicken fat, garbage from a chicken processing plant. The truck ran equally well on both types of 'fuel'... Some buses in Halifax ran on fishing industry waste oils. For all I know that could be the whole fleet by now. What I like about diesel in airplanes is the possibility of low rpm power for sometimes double the range (at lower speeds). A radial will turn very smoothly at 1000 rpm and the diesel would be torquing near optimum just audible around 1400-1600 (?). |
2-stroke diesel is the (near) future? | Max Kallio | Home Built | 134 | July 18th 05 12:39 AM |
2-stroke diesel is the (near) future? | Max Kallio | Rotorcraft | 123 | July 18th 05 12:39 AM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | Home Built | 1 | January 4th 04 04:04 AM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | General Aviation | 1 | January 4th 04 04:04 AM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | Owning | 1 | January 4th 04 04:04 AM |
