Questions for Jim Weir, or other knowledgeable folks: I've got a couple of questions about an ideal antenna for ILS use. My Comm/Nav radio uses one antenna for both ILS and VOR. I rarely use VOR so I'd like to optimize an antenna for ILS use (a side note -- my current antenna sucks for both VOR and ILS). My plane is fiberglass. I'm thinking a "V" shape may give me a stronger lobe toward the front but don't know what the angle should be. So, my questions Is a "V" array a good idea for directional gain? What angle? Should the top of the "V" be oriented forward to maximize reception from that direction? How long should the elements be for optimum reception of a 109MHz signal? Thanks – Bill Kennedy N42BK -- billkennedy3 Powered by www.flight.org |
"billkennedy3" wrote:
So, my questions Is a "V" array a good idea for directional gain? What angle? Should the top of the "V" be oriented forward to maximize reception from that direction? How long should the elements be for optimum reception of a 109MHz signal? Jim can advise on the specifics if he desires, but to avoid potential contradiction, I'll say only there's more than enough signal strength available from the ILS antenna for practical IFR use. So, the effect of optimizations you propose will not give you anything you'll ever notice. I imagine for something as safety-critical as an ILS, FAA gotta send you enough RF energy to allow for things not being quite up to snuff on your end, or seriously still shooting a LOC approach with a ratty old Genave Alpha 200... But what's your theory on why your present antenna sucks for both VOR/ILS? Might it be the receiver, or coax? Did you install a balun, or if self-fabricated with RG-58, are the dimensions correct? Are the tips located near to any lengthy run of metal? Optimizing a replacement antenna won't make up for the problems these items can cause. Fred F. |
As Taxsrv noted, your current antenna "sucks for both VOR and ILS". Let's
explore that before we design you something that will suck for the same reasons. Jim "billkennedy3" wrote in message .. . Questions for Jim Weir, or other knowledgeable folks: I've got a couple of questions about an ideal antenna for ILS use. My Comm/Nav radio uses one antenna for both ILS and VOR. I rarely use VOR so I'd like to optimize an antenna for ILS use (a side note -- my current antenna sucks for both VOR and ILS). My plane is fiberglass. I'm thinking a "V" shape may give me a stronger lobe toward the front but don't know what the angle should be. So, my questions Is a "V" array a good idea for directional gain? What angle? Should the top of the "V" be oriented forward to maximize reception from that direction? How long should the elements be for optimum reception of a 109MHz signal? Thanks – Bill Kennedy N42BK -- billkennedy3 Powered by www.flight.org |
If he is using the SAME antenna for both glideslope and localizer/VOR
its understandeable how one or BOTH recievers are doing poorly. Correct me if I'm wrong.. Glideslope receivers are UHF band (400 mhz range??) while the LOC/VOR is in the VHF band (109-117 mhz range). He did not explicitly state he had glideslope, using the term "ILS" which im not sure if he's referring to Loc/GS or Loc alone. The a/c is a lancair 320 (if the N number search is correct). Where is the "per plans" antenna location for the nav and GS antennae? Dave RST Engineering wrote: As Taxsrv noted, your current antenna "sucks for both VOR and ILS". Let's explore that before we design you something that will suck for the same reasons. Jim "billkennedy3" wrote in message .. . Questions for Jim Weir, or other knowledgeable folks: I've got a couple of questions about an ideal antenna for ILS use. My Comm/Nav radio uses one antenna for both ILS and VOR. I rarely use VOR so I'd like to optimize an antenna for ILS use (a side note -- my current antenna sucks for both VOR and ILS). My plane is fiberglass. I'm thinking a "V" shape may give me a stronger lobe toward the front but don't know what the angle should be. So, my questions Is a "V" array a good idea for directional gain? What angle? Should the top of the "V" be oriented forward to maximize reception from that direction? How long should the elements be for optimum reception of a 109MHz signal? Thanks – Bill Kennedy N42BK -- billkennedy3 Powered by www.flight.org |
Dave ...
That doesn't happen to be true. What you say about the signals is correct .... Loc/Vor is 108-118 MHz. and glideslope is 325-340. An antenna, to work well, needs to be an *ODD* quarter wavelength per element. Note that a 1-quarter wave at the Loc/Vor just happens to be a 3-quarter wave at the glideslope, and as such, will work quite well for both frequencies. It is traditional to make a "splitter" to take each signal off unaffected by the other signal. Such a splitter can be made from two cents worth of parts and a few bucks for connectors and metalwork. You can go one step further and for half a buck's worth of coax have a two-radio VOR/LOC splitter plus a glideslope splitter in the same box. Now, back to the original question. Where is the CURRENT antenna located and why is it performing so poorly. No bandaids before we do the analysis. Jim "Dave S" wrote in message ink.net... If he is using the SAME antenna for both glideslope and localizer/VOR its understandeable how one or BOTH recievers are doing poorly. Correct me if I'm wrong.. Glideslope receivers are UHF band (400 mhz range??) while the LOC/VOR is in the VHF band (109-117 mhz range). He did not explicitly state he had glideslope, using the term "ILS" which im not sure if he's referring to Loc/GS or Loc alone. The a/c is a lancair 320 (if the N number search is correct). Where is the "per plans" antenna location for the nav and GS antennae? |
I'm using a Archer antenna in the top of my Lancair 320 fuselage just aft of the baggage compartment. I tried to do a careful job of installation but I'm a klutz. Not only that, I'm a 200 pound klutz and the area behind the baggage compartment was designed for very small non-klutz persons. So, I confess, I don't have a clue if my problem is from poor installation or from installing a poor choice of antenna. I've sent for Jim Weir's antenna kit, so I'm going to install another come hell or high water. I'll rig it temporarily above the baggage area (for reasons mentioned afore). So, back to my original questions: Is a "V" array a good idea for directional gain? (My space available make the "V" very tempting) What angle? Should the top of the "V" be oriented forward to maximize reception from that direction? How long should the elements be for optimum reception of a 109MHz signal? How fat? Thanks -- Bill Kennedy -- billkennedy3 Powered by www.flight.org |
"billkennedy3" wrote in message .. . Is a "V" array a good idea for directional gain? (My space available make the "V" very tempting) The V antenna may be made at any angle up to a 90d right angle, but the optimum for omnidirectional reception (which you want for VOR) would put the angle of the V somewhere around 120-140d. The V antenna will have SLIGHTLY better reception in the apex of the V -- that is, this V antenna will pick up slightly better towards the top of the page than the bottom, but will have no effect for all practical purposes. How long should the elements be for optimum reception of a 109MHz signal? Why 109? The center of the localizer band is 110 and the center of the whole nav band is 113. However, to answer your question directly, about 23.5" for each element. If you wanna split hairs l = 2575 / f where l is the length of an element and f is the frequency in MHz. In this case, the number works out to 23.62, but this is also like building a house with a micrometer. How fat? We've found that 1/2 " copper tape is about the best compromise between bandwidth and work-ability. Jim |
the length of an element and f is the frequency in MHz. In this case, the number works out to 23.62, but this is also like building a house with a micrometer. How fat? We've found that 1/2 " copper tape is about the best compromise between bandwidth and work-ability. Jim Hey Jim like we used to say in the Navy, "Measure it with a micrometer, mark it with chalk and cut it with an axe!" Have a good day John |
"...mark it with chalk and cut it with an axe." Thanks guys, I can really relate to this. And, beyond the construction tips, thanks for the technical advice as well. Bill Kennedy -- billkennedy3 Powered by www.flight.org |
| Thread Tools | |
| Display Modes | |
| I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 06:39 PM |
| Retractable Comm Antenna | Ron Wanttaja | Home Built | 11 | September 6th 04 07:59 PM |
| ELT antenna -- Pitts | Al MacDonald | Home Built | 0 | July 15th 04 04:27 PM |
| Ext antenna connection for handheld radio | Ray Andraka | Owning | 7 | March 5th 04 02:10 PM |
| comm's RX antenna | acepilot | Home Built | 5 | March 3rd 04 06:34 PM |
