I'm part owner of a IFR 172E. Nice equipment, but no vacuum redundancy.
I know I can add a dual-rotor vacuum pump or a manifold-driven alternate vacuum source, but I'd rather have an electric backup (in case of engine failure). Electric pumps add weight and good backup electric AI's are expensive. Does anyone have any experience installing/using the new solid state gyros? I have an iPaq and handheld GPS, so the "portable" units would be OK. One of the manufacturers has a panel mounted unit, but apparently it can't go into a production plane. What are the chances of getting a 337 for that if it is for backup only? I can do partial panel, but I'd rather have the most capability that I can get (within reasonable expense). -- Remove "2PLANES" to reply. |
On Wed, 14 Jan 2004 08:16:01 -0500, Dan Truesdell
wrote: I'm part owner of a IFR 172E. Nice equipment, but no vacuum redundancy. I know I can add a dual-rotor vacuum pump or a manifold-driven alternate vacuum source, but I'd rather have an electric backup (in case of engine failure). Electric pumps add weight and good backup electric AI's are expensive. Does anyone have any experience installing/using the new solid state gyros? I have an iPaq and handheld GPS, so the "portable" units would be OK. One of the manufacturers has a panel mounted unit, but apparently it can't go into a production plane. What are the chances of getting a 337 for that if it is for backup only? I can do partial panel, but I'd rather have the most capability that I can get (within reasonable expense). If it is for backup and you keep the orginal AI in the plane, and you have a cooperative mechanic and FSDO, you might be able to pull it off. I'd make a few phone calls and get everything lined up before you buy the equipment. BTW, what panel mount solid state AI is available? Besides the 40k G1000 and Entegra stacks? -Nathan |
There was an article about this in a recent AviationConsumer
(www.aviationconsumer.com). Regarding the portable units, the gist is that they're capable enough if you're in a bind. In fact, even something like a Garmin 196 would probably get you out of trouble (at $999 though, you won't save any money here). Depending on the flying you do, they also recommend keeping a spare pump around (they estimate $300), otherwise if you're away from home you'll either be going home VFR or paying some unknown shop to replace your pump. Regarding a 337, it seems to depend heavily on your FSDO. Which company offers a panel mount option? blue skies, mark "Dan Truesdell" wrote in message ... I'm part owner of a IFR 172E. Nice equipment, but no vacuum redundancy. I know I can add a dual-rotor vacuum pump or a manifold-driven alternate vacuum source, but I'd rather have an electric backup (in case of engine failure). Electric pumps add weight and good backup electric AI's are expensive. Does anyone have any experience installing/using the new solid state gyros? I have an iPaq and handheld GPS, so the "portable" units would be OK. One of the manufacturers has a panel mounted unit, but apparently it can't go into a production plane. What are the chances of getting a 337 for that if it is for backup only? I can do partial panel, but I'd rather have the most capability that I can get (within reasonable expense). -- Remove "2PLANES" to reply. |
PCFlightSystems (eGyro-3).
Dan Mark Astley wrote: There was an article about this in a recent AviationConsumer (www.aviationconsumer.com). Regarding the portable units, the gist is that they're capable enough if you're in a bind. In fact, even something like a Garmin 196 would probably get you out of trouble (at $999 though, you won't save any money here). Depending on the flying you do, they also recommend keeping a spare pump around (they estimate $300), otherwise if you're away from home you'll either be going home VFR or paying some unknown shop to replace your pump. Regarding a 337, it seems to depend heavily on your FSDO. Which company offers a panel mount option? blue skies, mark "Dan Truesdell" wrote in message ... I'm part owner of a IFR 172E. Nice equipment, but no vacuum redundancy. I know I can add a dual-rotor vacuum pump or a manifold-driven alternate vacuum source, but I'd rather have an electric backup (in case of engine failure). Electric pumps add weight and good backup electric AI's are expensive. Does anyone have any experience installing/using the new solid state gyros? I have an iPaq and handheld GPS, so the "portable" units would be OK. One of the manufacturers has a panel mounted unit, but apparently it can't go into a production plane. What are the chances of getting a 337 for that if it is for backup only? I can do partial panel, but I'd rather have the most capability that I can get (within reasonable expense). -- Remove "2PLANES" to reply. -- Remove "2PLANES" to reply. |
Thanks. Just checked out the aviation consumer article. Great
information. I have a call into the local FSDO. We'll see what they say about the panel-mounted unit (e-Gyro-3). I do seem to recall someone in the mid-west that tried to put one in with no luck. Maybe the people in Maine will be a bit more helpful. Mark Astley wrote: There was an article about this in a recent AviationConsumer (www.aviationconsumer.com). Regarding the portable units, the gist is that they're capable enough if you're in a bind. In fact, even something like a Garmin 196 would probably get you out of trouble (at $999 though, you won't save any money here). Depending on the flying you do, they also recommend keeping a spare pump around (they estimate $300), otherwise if you're away from home you'll either be going home VFR or paying some unknown shop to replace your pump. Regarding a 337, it seems to depend heavily on your FSDO. Which company offers a panel mount option? blue skies, mark "Dan Truesdell" wrote in message ... I'm part owner of a IFR 172E. Nice equipment, but no vacuum redundancy. I know I can add a dual-rotor vacuum pump or a manifold-driven alternate vacuum source, but I'd rather have an electric backup (in case of engine failure). Electric pumps add weight and good backup electric AI's are expensive. Does anyone have any experience installing/using the new solid state gyros? I have an iPaq and handheld GPS, so the "portable" units would be OK. One of the manufacturers has a panel mounted unit, but apparently it can't go into a production plane. What are the chances of getting a 337 for that if it is for backup only? I can do partial panel, but I'd rather have the most capability that I can get (within reasonable expense). -- Remove "2PLANES" to reply. -- Remove "2PLANES" to reply. |
Dan Truesdell wrote:
One of the manufacturers has a panel mounted unit, but apparently it can't go into a production plane. What are the chances of getting a 337 for that if it is for backup only? I can do partial panel, but I'd rather have the most capability that I can get (within reasonable expense). By installing uncertified equipment as an emergency backup, you are essentially becoming a test pilot. How will this unit handle turbulence, temperature and pressure changes, static charges, nearby lightning? Will it produce emmissions that may interfere with your other radios or navigation equipment? How much training will be required to stay proficient in it's use? My guess is at least as much as partial panel using a plain old turn coordinator, probably more if it is mounted outside your normal insturment scan area. IMHO, this would not be a safety gain, and the money would be better spent on traditional partial panel practice. Ross Oliver |
PCFlight Systems sizes their portable unit to fit into a standard 3"
instrument hole (wink, wink). I was told the odds of getting a 337 for the thing were about zero. I asked PCFlight Systems if they had any plans to invest the $50 - $100K it would take to get an STC and they just laughed. Ah, the FAA, busy enshrining mediocrity. Tell you what, if 100 people on here each chip in $1000 I'll put the money into an escrow account, get the 337 and then sell you a unit at cost. Think of it, you'll own 1/100th of an avionics company! "Dan Truesdell" wrote in message ... Thanks. Just checked out the aviation consumer article. Great information. I have a call into the local FSDO. We'll see what they say about the panel-mounted unit (e-Gyro-3). I do seem to recall someone in the mid-west that tried to put one in with no luck. Maybe the people in Maine will be a bit more helpful. Mark Astley wrote: There was an article about this in a recent AviationConsumer (www.aviationconsumer.com). Regarding the portable units, the gist is that they're capable enough if you're in a bind. In fact, even something like a Garmin 196 would probably get you out of trouble (at $999 though, you won't save any money here). Depending on the flying you do, they also recommend keeping a spare pump around (they estimate $300), otherwise if you're away from home you'll either be going home VFR or paying some unknown shop to replace your pump. Regarding a 337, it seems to depend heavily on your FSDO. Which company offers a panel mount option? blue skies, mark "Dan Truesdell" wrote in message ... I'm part owner of a IFR 172E. Nice equipment, but no vacuum redundancy. I know I can add a dual-rotor vacuum pump or a manifold-driven alternate vacuum source, but I'd rather have an electric backup (in case of engine failure). Electric pumps add weight and good backup electric AI's are expensive. Does anyone have any experience installing/using the new solid state gyros? I have an iPaq and handheld GPS, so the "portable" units would be OK. One of the manufacturers has a panel mounted unit, but apparently it can't go into a production plane. What are the chances of getting a 337 for that if it is for backup only? I can do partial panel, but I'd rather have the most capability that I can get (within reasonable expense). -- Remove "2PLANES" to reply. -- Remove "2PLANES" to reply. |
I had an interesting conversation with out local FSDO today. He
basically reported the FAA party line that anything that is "physically attached" to a production aircraft must have an STC/337/what-ever to be legal. (I guess in the event that someone uses your plane and gets into trouble using the "unapproved" device, the FAA could be held accountable?) Anyway, he (in so many words) seemed to agree that it's odd that, while I can't put the eGyro3 into the plane, I can (and probably will) purchase the PCEFIS "portable" unit and use it as a backup. (Maybe they trust velcro more than actual bolts.) The aviation consumer article had an interesting take, however, on the role of the backup pump. From what I understand, if I install an electric pump and a regular vacuum backup AI. If either the regular pump or the AI bites the dust, I can still legally fly, even IFR with the backup system. Interesting point. But my main goal was to give myself some redundancy. McGregor wrote: PCFlight Systems sizes their portable unit to fit into a standard 3" instrument hole (wink, wink). I was told the odds of getting a 337 for the thing were about zero. I asked PCFlight Systems if they had any plans to invest the $50 - $100K it would take to get an STC and they just laughed. Ah, the FAA, busy enshrining mediocrity. Tell you what, if 100 people on here each chip in $1000 I'll put the money into an escrow account, get the 337 and then sell you a unit at cost. Think of it, you'll own 1/100th of an avionics company! "Dan Truesdell" wrote in message ... Thanks. Just checked out the aviation consumer article. Great information. I have a call into the local FSDO. We'll see what they say about the panel-mounted unit (e-Gyro-3). I do seem to recall someone in the mid-west that tried to put one in with no luck. Maybe the people in Maine will be a bit more helpful. Mark Astley wrote: There was an article about this in a recent AviationConsumer (www.aviationconsumer.com). Regarding the portable units, the gist is that they're capable enough if you're in a bind. In fact, even something like a Garmin 196 would probably get you out of trouble (at $999 though, you won't save any money here). Depending on the flying you do, they also recommend keeping a spare pump around (they estimate $300), otherwise if you're away from home you'll either be going home VFR or paying some unknown shop to replace your pump. Regarding a 337, it seems to depend heavily on your FSDO. Which company offers a panel mount option? blue skies, mark "Dan Truesdell" wrote in message ... I'm part owner of a IFR 172E. Nice equipment, but no vacuum redundancy. I know I can add a dual-rotor vacuum pump or a manifold-driven alternate vacuum source, but I'd rather have an electric backup (in case of engine failure). Electric pumps add weight and good backup electric AI's are expensive. Does anyone have any experience installing/using the new solid state gyros? I have an iPaq and handheld GPS, so the "portable" units would be OK. One of the manufacturers has a panel mounted unit, but apparently it can't go into a production plane. What are the chances of getting a 337 for that if it is for backup only? I can do partial panel, but I'd rather have the most capability that I can get (within reasonable expense). -- Remove "2PLANES" to reply. -- Remove "2PLANES" to reply. -- Remove "2PLANES" to reply. |
Dan Truesdell wrote in
: Thanks. Just checked out the aviation consumer article. Great information. I have a call into the local FSDO. We'll see what they say about the panel-mounted unit (e-Gyro-3). I do seem to recall someone in the mid-west that tried to put one in with no luck. Maybe the people in Maine will be a bit more helpful. A lot will depend upon how you describe this thing. It is **not** a backup AI, nor is it a redundant AI, or is it even an aviation product. It is a small electronic device, which you wish to panel mount and connect to the ship's power. This device will be adequately fused and tested in VFR/VMC by the pilot/operator prior to operation IFR, and verified not to interfere with onboard avionics. Remember, in an EMERGENCY it suddenly doesn't matter if it's an AI or a tuna sandwich, it's legal to use. ----------------------------------------------- James M. Knox TriSoft ph 512-385-0316 1109-A Shady Lane fax 512-366-4331 Austin, Tx 78721 ----------------------------------------------- |
Take a look at www.dynondevelopment.com/ , they have an awesome EFIS for $2000.
No it is not "certified". Dan Truesdell wrote in message ... I'm part owner of a IFR 172E. Nice equipment, but no vacuum redundancy. I know I can add a dual-rotor vacuum pump or a manifold-driven alternate vacuum source, but I'd rather have an electric backup (in case of engine failure). Electric pumps add weight and good backup electric AI's are expensive. Does anyone have any experience installing/using the new solid state gyros? I have an iPaq and handheld GPS, so the "portable" units would be OK. One of the manufacturers has a panel mounted unit, but apparently it can't go into a production plane. What are the chances of getting a 337 for that if it is for backup only? I can do partial panel, but I'd rather have the most capability that I can get (within reasonable expense). |
| How to drill a cenetered hole in end of solid rod | Scott | Home Built | 21 | November 2nd 04 04:04 PM |
| State Of Michigan Sales/Use Tax | Rich S. | Home Built | 0 | August 9th 04 05:41 PM |
| Q for Jim Weir or others: solid state fuel level probes? | Charlie England | Home Built | 11 | March 12th 04 01:35 AM |
| Penn State Soaring Club Schreder projects sale. | Wayne Paul | Home Built | 0 | January 6th 04 03:21 AM |
| Homebuilts by State | Ron Wanttaja | Home Built | 14 | October 15th 03 09:30 PM |
