Mine started leaking after 20 years of service, not a bad service life for
something that I can replace for less than $10 at aircraft Spruce, or $14 from Sacramento Sky ranch. But since it is brass and looks to be in great shape, I would just like to replace it's rubber seal. I thought it was an o-ring, but it is a tiny rubber washer. I found what I thought was the perfect replacement from Mc Master Carr, had to order 100 of them. Sadly they do not fit. I asked the FBO guys next door and they said they used to be able to order the seals but they can't get them any more. BTW the new valve that I ordered from Spruce will be here next week. Does anyone know of a source of just the seals? Thanks for any info or suggestions. |
| Thread Tools | |
| Display Modes | |
| Quick drain mess. | dlevy | Owning | 10 | October 17th 05 02:55 AM |
| Spider in Archer Sump Drain | Bob Chilcoat | Owning | 3 | June 29th 05 11:29 PM |
| QUICK EASY CASH | [email protected] | Owning | 1 | April 20th 05 08:18 PM |
| RV Quick Build build times... | [email protected] | Home Built | 2 | December 17th 03 04:29 AM |
| sump drain cleaning | Mike Noel | Owning | 15 | August 15th 03 03:41 AM |
