Is it possible for a "flight of two" to file and fly an IFR flight plan?
"Doug" wrote in message om... Is it possible for a "flight of two" to file and fly an IFR flight plan? Yes. |
Im sure the military does it all the time..
However.. practically.. WHO is going to be responsible for separation on a formation flight if it goes IMC? The military has procedures that address this.. i am curious to know if the US civil sector does, and I've not seen anything pertaining to it.. Anyone care to expand on the DETAILS of actually doing a formation under IFR in IMC or VMC? Dave Steven P. McNicoll wrote: "Doug" wrote in message om... Is it possible for a "flight of two" to file and fly an IFR flight plan? Yes. |
"Dave S" wrote...
Im sure the military does it all the time.. However.. practically.. WHO is going to be responsible for separation on a formation flight if it goes IMC? The military has procedures that address this.. i am curious to know if the US civil sector does, and I've not seen anything pertaining to it.. Anyone care to expand on the DETAILS of actually doing a formation under IFR in IMC or VMC? Indeed, the military has numerous procedures that address IFR flight in formations. I'm sure the Army, Navy, and Air Force have their own specific procedures, but in general: It begins with dedicated VMC formation flying practice early in training, then expands to IFR/IMC formation procedures. In an IFR formation, the flight is treated by ATC as a single airplane. Responsibility for separation between the separate elements in the flight is on the formation leader. It is possible and permissible to fly an approach and landing in formation with tactical (small) aircraft. Generally, IFR formation landings are limited to 2 airplanes, and approach minimums may be higher than those for single aircraft. When weather is below formation approach & landing minimums, the flight will separate into 2 single-aircraft flights prior to the approach. It is essentially the same as one of the airplanes asking for a "popup" IFR clearance. The flight remains together (either enroute or in holding) until the separate clearances are obtained. Then the second aircraft starts squawking his own discrete code and follows his own clearance with regard to altitude and route. I don't know if there are separate civil procedures; the concept should be the same. However, I don't know how the FAA looks on intentional civil IFR/IMC formation flight in the first place, especially with regard to FAR 91.13... |
John R Weiss wrote:
Responsibility for separation between the separate elements in the flight is on the formation leader. How does that work? Is visual contact required, or can this be done electronically? - Andrew |
"Andrew Gideon" wrote...
Responsibility for separation between the separate elements in the flight is on the formation leader. How does that work? Is visual contact required, or can this be done electronically? In most cases, visual separation. However, when working in altitude blocks, as with larger tanker/receiver formations, some of the separation may be done with air-to-air radar. Even in that case, though, the visibility must be good enough for visual rendezvous in close. |
"Dave S" wrote in message hlink.net... However.. practically.. WHO is going to be responsible for separation on a formation flight if it goes IMC? Responsibility for separation within the flight rests with the flight, whether that is practical or not. Responsibility for separation between the flight and other IFR aircraft rests with ATC. The military has procedures that address this.. i am curious to know if the US civil sector does, and I've not seen anything pertaining to it.. US ATC procedures do not distinguish between civil or military with regard to formation flights. The FARs prohibit formation flights by aircraft carrying passengers for hire. Formation flights by civil VFR aircraft are not uncommon. I issued an IFR clearance to a civil formation just once, that I can recall. It was during the EAA convention, a group of T-34s wanted to get away from OSH to practice their routine, the weather was MVFR. FAA Order 7110.65P Air Traffic Control Chapter 2. General Control Section 1. General 2-1-13. FORMATION FLIGHTS Control formation flights as a single aircraft. When individual control is requested, issue advisory information which will assist the pilots in attaining separation. When pilot reports indicate separation has been established, issue control instructions as required. NOTE- 1. Separation responsibility between aircraft within the formation during transition to individual control rests with the pilots concerned until standard separation has been attained. 2. Formation join-up and breakaway will be conducted in VFR weather conditions unless prior authorization has been obtained from ATC or individual control has been approved. Chapter 5. Radar Section 5. Radar Separation 5-5-8. ADDITIONAL SEPARATION FOR FORMATION FLIGHTS Because of the distance allowed between formation aircraft and lead aircraft, additional separation is necessary to ensure the periphery of the formation is adequately separated from other aircraft, adjacent airspace, or obstructions. Provide supplemental separation for formation flights as follows: a. Separate a standard formation flight by adding 1 mile to the appropriate radar separation minima. REFERENCE- FAAO 7110.65, Formation Flights, Para 2-1-13. FAAO 7110.65, Application, Para 5-5-1. FAAO 7110.65, Separation, Para 7-7-3. P/CG Term- Formation Flight. b. Separate two standard formation flights from each other by adding 2 miles to the appropriate separation minima. c. Separate a nonstandard formation flight by applying the appropriate separation minima to the perimeter of the airspace encompassing the nonstandard formation or from the outermost aircraft of the nonstandard formation whichever applies. d. If necessary for separation between a nonstandard formation and other aircraft, assign an appropriate beacon code to each aircraft in the formation or to the first and last aircraft in-trail. NOTE- The additional separation provided in para 5-5-8, Additional Separation for Formation Flights, is not normally added to wake turbulence separation when a formation is following a heavier aircraft since none of the formation aircraft are likely to be closer to the heavier aircraft than the lead aircraft (to which the prescribed wake turbulence separation has been applied). § 91.111 Operating near other aircraft. (a) No person may operate an aircraft so close to another aircraft as to create a collision hazard. (b) No person may operate an aircraft in formation flight except by arrangement with the pilot in command of each aircraft in the formation. (c) No person may operate an aircraft, carrying passengers for hire, in formation flight. |
"John R Weiss" wrote in message news:RlG6c.39299$JL2.454869@attbi_s03... I don't know if there are separate civil procedures; the concept should be the same. However, I don't know how the FAA looks on intentional civil IFR/IMC formation flight in the first place, especially with regard to FAR 91.13... The only restriction on civil formation flights is carrying passengers for hire. § 91.111 Operating near other aircraft. (a) No person may operate an aircraft so close to another aircraft as to create a collision hazard. (b) No person may operate an aircraft in formation flight except by arrangement with the pilot in command of each aircraft in the formation. (c) No person may operate an aircraft, carrying passengers for hire, in formation flight. |
"Steven P. McNicoll" wrote...
I don't know how the FAA looks on intentional civil IFR/IMC formation flight in the first place, especially with regard to FAR 91.13... The only restriction on civil formation flights is carrying passengers for hire. § 91.111 Operating near other aircraft. (b) No person may operate an aircraft in formation flight except by arrangement with the pilot in command of each aircraft in the formation. (c) No person may operate an aircraft, carrying passengers for hire, in formation flight. Thanks. 91.111(b) applies to VFR or IFR, and as you pointed out in your other post, civil formation flights under VFR is relatively common. However, with the increased skill level required for safe IFR formation flight, I would expect that in reality 91.13 would be also be cited if there were any incident or mishap involving aircraft in IFR formation flight. |
"John R Weiss" wrote in message news:Z_K6c.43426$KO3.110749@attbi_s02... 91.111(b) applies to VFR or IFR, and as you pointed out in your other post, civil formation flights under VFR is relatively common. However, with the increased skill level required for safe IFR formation flight, I would expect that in reality 91.13 would be also be cited if there were any incident or mishap involving aircraft in IFR formation flight. I would expect 91.13 to be cited if there were any incident or mishap involving aircraft in VFR formation flight. |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| new theory of flight released Sept 2004 | Mark Oliver | Aerobatics | 1 | October 5th 04 11:20 PM |
| Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Home Built | 0 | September 22nd 04 08:16 PM |
| FAA letter on flight into known icing | C J Campbell | Instrument Flight Rules | 78 | December 22nd 03 08:44 PM |
| Sim time loggable? | [email protected] | Instrument Flight Rules | 12 | December 6th 03 08:47 AM |
