: The thrust is probably 4x, like the engine's power. The advance rate makes
: the prop want to pull the airplane at 2x the speed, but again, 2x the speed : requires 4x the power... Check your equations. Drag force goes with the square of the velocity. Drag power (force*velocity) therefore goes with the *cube* of velocity. So, if that's the governing equation, 2x the speed requires 8x the power. If you look at the operator handbooks for identical airframes with different engine options (e.g. PA28-140/150/160/180/235, PA24-180/250/260/400), you'll see that they almost exactly follow this cubic (i.e. cube-root) equation. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Do you really think including factual data is likely to resolve the
question? And do you know Dr Dan? |
Bob Fry wrote:
I wish to leave the engine out of the discussion, but let's continue... "KB" == Kyle Boatright writes: KB If we assume the plane in question is a C-152, Close enough, it's an Aircoupe with a C90. But let's look just at the prop. Why does a prop produce so much more thrust, much more than double, when it's turned at only twice the rate? KB Another way to look at it is that your prop has an advance KB rate. Let's say it the advance rate is 4 feet per KB revolution. Yep, 48" pitch. KB At 1,000 rpm, and no drag on the airplane (rolling KB or aerodynamic), the airplane would have a terminal velocity KB of 4,000 fpm, or about 48 mph. Of course, there is rolling and KB aerodynamic drag, and there is prop drag too, so the engine KB can only drag the plane along at, say, 30 mph, assuming a flat KB smooth runway. KB At 2,000 rpm, with no drag, the terminal velocity would be KB 8,000 fpm, or about 85 mph. Hmmmm...so prop thrust is indeed only twice at double the rpm?...ideally speaking of course. The idealized (no viscosity etc.) math seems to say that it is linear, but intuitive feel says not. Is aerodynamic drag of an airfoil linear with speed? Is airfoil lift linear with speed? Since a prop is just an airfoil going in a circle, why would you expect it to be linear? Matt |
Bob Fry wrote:
Uh, thanks for trying...I guess: DC "Bob Fry" wrote in message DC ... At 1000 rpm or so, my airplane will taxi and get up to, what, 15-20 kts? But at double the rpm it will fly at 80-90 kts, though it would take a long time to take off. Surely double the rpm produces more than double the propellor thrust...or does it? Anyway, it seems very nonlinear, that is, double the rpm and I get much more than double the performance. Why is that? DC The laws of physics (certainly those relating to mechanics - DC velocity, acceleration, thrust, drag and all that) are rarely DC linear. Eh? F=ma and many others are. DC On the ground your aircraft is probably not in an DC optimum attitude for drag reduction, so it's probably not fair DC to compare it with an aircraft in the sky. And will your DC aircraft fly straight and level at 1000rpm? If so, how fast? Kee-rist. Drag, and attitude (angle of attack, really) have little to do with the explanation I was looking for. No, of course it won't fly straight and level at 1000 rpm. That's nearly full idle landing rpm. DC The main thing dictating how your aircraft performs is DC drag. "Normal" drag increases with the square of the speed you DC fly at I think you mean parasitic drag. DC - so if you double the speed, you roughly quadruple the DC drag (hence everything has a terminal velocity when falling to DC earth - as you get faster, the drag increases faster than your DC speed increases, and you stop accelerating once drag equals DC the acceleration caused by gravity). Remember also that at low DC speeds you have induced drag, which is high at low speeds but DC vanishes as you get faster. Induced drag--drag caused by the wing producing lift at a vector not perpendicular to flight--never vanishes unless lift vanishes. Anyway I'll restate the question, plus post to r.a.'s garbage heap, r.a.piloting. At 1000 rpm the prop produces some amount of thrust (lift), call it T[1000]. This thrust is only enough to move the plane in a moderate taxi. At double that rpm, 2000 rpm, the prop produces another amount of thrust, call it T[2000]. Now I'm not positive, but it sure seems that T[2000] T[1000] Why, if rpm only doubles, does thrust (seem to) much more than double? Because prop thrust increases as the square of the RPM and thus you get four times more thrust at twice the RPM. There are other factors that come into play as well such as advance ratio, but I assume you can Google... Matt |
Why does a prop ice up so apparently readily? | Brian Whatcott | Piloting | 2 | November 9th 05 12:02 AM |
Why does a prop ice up so apparently readily? | Brian Whatcott | Instrument Flight Rules | 2 | November 9th 05 12:02 AM |
Why does a prop ice up so apparently readily? | The Visitor | General Aviation | 0 | November 8th 05 08:53 PM |
Why does a prop ice up so apparently readily? | Mike Rapoport | Instrument Flight Rules | 2 | November 8th 05 02:52 PM |
Sensenich Wood Prop Question | [email protected] | Owning | 3 | April 4th 05 02:32 PM |
