Hi, I tried to balance a prop on a O-320 on a RV-6 the other day and could not because other large vibrations were present. Im summary, I got: 0.7 IPS at 0.5 crank RPM 0.2 IPS at crank RPM 0.5 IPS at 3.5 crank RPM The vibration levels at the other multiples of 1/2 crank were all relatively small. I can find lots of info on the web re 1/2 crank vibration and its causes but I can find nothing on 3.5 crank and I am puzzled as to why it is so high. Is it normal for this kind of engine? Thanks, Mark |
Have you tried rotating your prop 60 degrees? I wonder if it is a
prop/engine interaction imbalance. |
How many blades on the prop? Variable pitch? What balancer are you using?
Is it nose wheel or tail dragger? I do some helicopter blade balancing and have gotten funny results at times. We really have to get the helo off the ground to do the fine tuning. Helicopter vibrations reflecting from the ground can be misleading. I've never tried balancing a " Stuck Wing" prop. -- Stuart Fields Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 (760) 408-9747 general and layout cell (760) 608-1299 technical and advertising cell www.vkss.com www.experimentalhelo.com "Mark Burton" wrote in message ... Hi, I tried to balance a prop on a O-320 on a RV-6 the other day and could not because other large vibrations were present. Im summary, I got: 0.7 IPS at 0.5 crank RPM 0.2 IPS at crank RPM 0.5 IPS at 3.5 crank RPM The vibration levels at the other multiples of 1/2 crank were all relatively small. I can find lots of info on the web re 1/2 crank vibration and its causes but I can find nothing on 3.5 crank and I am puzzled as to why it is so high. Is it normal for this kind of engine? Thanks, Mark |
Stuart How many blades on the prop? Variable pitch? What Stuart balancer are you using? Is it nose wheel or tail dragger? It's a 2 blade metal prop (Sensenich) and I am using the spectrum mode of a Smart Avionics PB-1 balancer to look at the vibration spectrum. As I am actually the manufacturer of the PB-1, I believe it to be trustworthy! The spectrum display very clearly shows big peaks at 0.5 and 3.5 crank speed and not much elsewhere. A previous post suggested re-indexing the prop and that sounds like it's worth trying. What I really would like to find out is if there are any known engine problems that can give rise to that particular vibration frequency. Mark |
I am unaware of anything within a 4 cyl opposed engine that would
theoretically that would give anything at the 3.5 harmonic. I think you might be looking at a non-linearity in the mount (is it a dynafocal or a straight conical mouint?) or in the transducer(s) mounting. I'd guess the 3.5 order output to be comparatively insignificant compare to the 0.5 harmonic as far as human discomfort is concerned. Do try the prop indexing thing. Let us know the results. Good luck & THX |
Thanks for the reply, Sorry, off the top of my head, I don't know what kind of engine mount it is. I shall ask the aircraft's owner. Checking the transducer mounting is a good idea even if it only removes another unknown from the equation. What I should have done at the time was vary the RPM more and see how the 3.5 order vibration magnitude changed. That surely would have indicated whether it was a resonance at a particular RPM. What's nagging at me is the magnitude of the 3.5 order vibration. 0.5 IPS equates to quite a lot of acceleration at that frequency and acceleration means force! Mark |
removes another unknown from the equation - Maybe your xdcr mount is resonant at the 3.5 harmonic? Change the RPM & see what the measurments show. What's nagging at me is the magnitude of the 3.5 order vibration. 0.5 IPS equates to quite a lot of acceleration at that frequency Its still only 1/4 g approx. Not that much for a piece of cheap machinery.......! |
Also - check the prop blade resonant frequency in the flapping mode
without the engine running, hitting it at a tip with the tip of your index finger. You might be able to hear it with your ear. |
| Thread Tools | |
| Display Modes | |
| O-320 3.5 crank speed vibration | Mark Burton | Owning | 12 | January 23rd 06 10:14 PM |
| terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 10:39 PM |
| Engine Balancing and Resonance Vibration Problem | AllanFuller | Owning | 13 | September 12th 05 01:51 AM |
| Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 01:18 PM |
| New Film: The Need For Speed - Going to war on drugs | Phil Carpenter | Military Aviation | 0 | July 23rd 03 08:43 AM |
