Airplane Batteries
Old January 24th 06, 07:56 PM posted to rec.aviation.piloting
Default Airplane Batteries
It is your battery, use what ever water you want. But most
bottled water has minerals added so there is a flavor, some
waters now have flavors.
Only distilled water is pure, deionized water is OK too, but
that is harder to find on the store shelves.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Newps" wrote in message
| Well sure, that's essentially what bottled water is
anyways.
| Distilled is hardly the same as filtered (which is
actually what bottled
| water typically is).
| Most bottled water is dead water. You couldn't find a
mineral in there
| to save your life.
Old January 24th 06, 08:07 PM posted to rec.aviation.piloting
Most bottled water is dead water. You couldn't find a mineral in there to
save your life.
So? Even if more than half the bottled waters out there have had every
molecule of minerals filtered out (and I doubt that's true), that doesn't
make the water distilled.
Old January 23rd 06, 08:16 PM posted to rec.aviation.piloting
Bottled water is filtered tap water and often is enhanced
with "minerals for taste" or spring water which also has
minerals.
Distilled water has been BOILED and the steam condensed, it
is as pure as chemically possible. Less than a dollar a
gallon. A gallon will keep the battery in your car and
plane filled for about 25 years. Use a basting syringe to
add distilled water, an ounce at a time, six cells. If the
electrolyte level is low in all cells that means that it is
working evenly, but if just one or two cells are low, there
is likely to be a problem developing.
FAR preventative maintenance does allow the pilot to check
electrolyte levels and add water, also use a hydrometer to
check specific gravity to see that the battery is fully
charging. That combined with a voltage check to be sure
that the system is not charging at too high a voltage is the
most important things a pilot/owner can do to get maximum
life.
But all batteries wear out because lead flakes off the
plates and collects in the bottom of a standard lead/acid
battery [that's why the plates do not extend all the way to
the bottom of the case, the space is there to collect lead
sludge. When the sludge touches the plates they short out
and the cell is dead.]
James H. Macklin
ATP,CFI,A&P
some support
| Jim Macklin wrote:
| Distilled water is cheap and can even be drunk in an
| emergency.
anyways.
Old January 23rd 06, 10:03 PM posted to rec.aviation.piloting
"Jim Macklin" wrote in message news:lSaBf.69242$QW2.68282@dukeread08...
minerals.
You can also get distilled water from the de-humidifier....
Old January 23rd 06, 10:17 PM posted to rec.aviation.piloting
I didn't mean to imply that tap or even mud puddle water is good for a
lead acid battery. It's just that exposed plates are really bad &
should be covered ASAP. Dehumidifier water is good.
Old January 23rd 06, 10:59 PM posted to rec.aviation.piloting
You can get it from the outside of a glass of ice water too,
but my bladder can't handle that much ice water. It is just
easier to buy a gallon jug at the grocery store for less
than a dollar.
".Blueskies." wrote in
message
et...
enhanced
| minerals.
it
to
is
there
de-humidifier....
Old January 24th 06, 05:30 AM posted to rec.aviation.piloting
Blueskies
You can also get from your wife if she uses it for her steam iron
(like she should) )
Been doing that for years.
Big John
On Mon, 23 Jan 2006 22:03:02 GMT, ".Blueskies."
minerals.
Old January 23rd 06, 10:46 PM posted to rec.aviation.piloting
("Jim Macklin" wrote)
But all batteries wear out because lead flakes off the plates and collects
in the bottom of a standard lead/acid battery [that's why the plates do
not extend all the way to the bottom of the case, the space is there to
collect lead sludge. When the sludge touches the plates they short out
Would sucking out the sludge/flakes, once in a while, extend the life of the
battery? Drain (filter) back any acid/water into the cells.
Has anyone tried this?
Montblack
Old January 23rd 06, 11:07 PM posted to rec.aviation.piloting
There really isn't space to clean the sludge and if you
invert the case, you just dump the sludge into the plates.
I don't know of any batteries with a drain/cleanout plug on
the bottom. Battery recyclers rebuild batteries by cutting
the top open and washing the plates and reinstalling them
into clean cases. But the plates are worn and the life of
the battery would be shortened. I don't think any aircraft
batteries are rebuilt this way, usually the metals are
melted down and new batteries manufactured. NiCad batteries
use individual cells and those cells can be swapped into a
case and the cells are remanufactured under careful
controls. Of course NiCad batteries used in KingAirs and
jets cost as much as a small car.
James H. Macklin
ATP,CFI,A&P
some support
"Montblack" wrote in
message ...
plates and collects
why the plates do
space is there to
they short out
cells.
| Montblack
Old January 24th 06, 01:00 AM posted to rec.aviation.piloting
Would it make sense to periodically drain the sludge and refill with
fresh water?
Jose
Money: what you need when you run out of brains.
Crash In The Nolichucky W P Dixon Piloting 2 June 22nd 05 04:16 PM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 05:14 AM
Newbie Qs on stalls and spins Ramapriya Piloting 72 November 23rd 04 04:05 AM
The Best Airplane Veeduber Home Built 1 February 13th 04 05:43 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
