Actually, I believe you are incorrect. That passage only implies the
belt will move inversely proportional to the wheels on the plane; meaning the delta is conantly zero. They never actually state the plane is moving forward. Thus, with a wheel speed of zero, the delta is still zero. Therefore, I would suggest the only correct answer, based on that sole passage is, "no". Now, if we look at the actual question posted on straight dope, the answer is, "maybe", for many reasons. Having said that, we can *easily* tear up the explanation provided on straight dope. Simple fact is, Cecil makes a huge assumption which causes his whole house of cards to come tumbling down. Simply stated, there is nothing which precludes the belt from being motorized. Given a sophisticaed enough implementation, one can absolutely state, the plane would never leave the ground; assuming no head wind is involved. Long of the short, there is simply not enough information to provide an exact answer, other than maybe. If the belt is not motorized, AND the plane is moving (positive delta), yes, the plane will fly. If the belt is motorized, and it is intelligent enough to ensure a belt/wheel delta of zero, no, the plane will never fly. |
There will be airspeed felt by the plane in the area of the propellor
wash. Out of the prop wash, since the plane is not moving relative to the surrounding air, there will be no relative wind felt by the airplane. The airplane MIGHT take off, but it will not be a normal takeoff, at least not for a normal airplane with 36' wingspan and a 6' propellor. I really don't think there is enough information to know the answer for sure. Too many unknowns. This is one of these "frame of reference" problems. |
![]() "Doug" wrote in message oups.com... There will be airspeed felt by the plane in the area of the propellor wash. Out of the prop wash, since the plane is not moving relative to the surrounding air, there will be no relative wind felt by the airplane. The airplane MIGHT take off, but it will not be a normal takeoff, at least not for a normal airplane with 36' wingspan and a 6' propellor. I really don't think there is enough information to know the answer for sure. Too many unknowns. This is one of these "frame of reference" problems. Re-read it, Doug. The plane is not getting its motion from the wheels, so it matters not what the wheels or wheel speed is doing. -- Jim in NC |
Sorry....the plane would not fly as you described. For if your
statement were true, we would not need wings...only a engine and a prop. We must have air flow over the wings to generate lift. Propwash does not generate enough lift, especially for planes wihch have a centrally located engine/prop between the wings. |
"Greg Copeland" wrote
Sorry....the plane would not fly as you described. For if your statement were true, we would not need wings...only a engine and a prop. We must have air flow over the wings to generate lift. Propwash does not generate enough lift, especially for planes wihch have a centrally located engine/prop between the wings. Nitpicking aside, I suspect that everyone agrees that in order for the plane to take off it must move forward along the conveyor. Since the prop applies a force to the plane which acts independent of what the conveyor and the wheels are doing, the plane can definitely move forward, and therefore it can take off. Tie a rope to the plane and to your car which is parked in front of the conveyor and not on the belt. Start the conveyor and run the belt at any speed you wish. The plane sits still on the conveyor as the wheels spin away. Now, if you drive your car forward the plane will move forward along the conveyor at the speed that you are driving your car forward, regardless of how fast the conveyor belt is moving. The conveyor cannot keep the plane from moving forward, it can only spin the plane's wheels. The example says that the belt moves backwards at the same speed that the plane moves forward, but that doesn't mean that the plane must be standing still. Get rid of the rope and the car and use the prop and the engine to pull you forward along the conveyor (because it pulls you by exerting a force on the air) and voila, you're flyin' the friendly skies. BDS |
forward along the conveyor. Which is exactly my point! If you have a motoroized conveyor which always reduces the plane's forward movement to zero, no lift is generated, preventing the plane from flying. In other words, the plane generates lift by moving air over its wings. It moves air over its wings by moving forward. If you zero out forward movement, by a motorized conveyor, resulting in a zero delta, no lift is generated. it's a question of the plane making forward movement. Specifically, as it relates to your reply, while prop wash would indeed produce some lift over the wing, it would not be nearly enough to obtain take off....which is why we have wings. Thusly, if forward movement is zero and you're full throttle, you're not airbound....which is exaclty the same thing as a plane with no wings. |
![]() "Greg Copeland" wrote Nitpicking aside, I suspect that everyone agrees that in order for the plane to take off it must move forward along the conveyor. Which is exactly my point! If you have a motoroized conveyor which always reduces the plane's forward movement to zero It doesn't say that the plane has no forward movement - it says that the conveyor moves backwards at the same speed at which the plane moves forward - that does not prevent the plane from moving forward. |
always reduces the plane's forward movement to zero, no lift is generated, preventing the plane from flying. That's not what the original problem stated. And we have explained at least ten times why the conveyor belt CANNOT prevent the plane from moving forward. My attempt, an earlier post: You are taking the statement 'a conveyer belt that moves in the opposite direction at exactly the speed that the airplane is moving forward' to mean that somehow there is a force being applied to the mass of the aircraft, equal and opposite the thrust generated by the propellor. The only place the treadmill can exert any force an the airplane is the only place the treadmill is touching the airplane: the wheels. Any motion of the treadmill belt will be translated into rotation of the wheels. This will not prevent the aircraft from moving forward, through the air and taking off. |
Greg,
If you have a motoroized conveyor which always reduces the plane's forward movement to zero, Nowhere does it say that in the question. -- Thomas Borchert (EDDH) |
First I'm not a pilot.... But the engine is providing thrust, not driving
the wheels like a car. The airplane is gonna move regardless of what speed the wheels are or are not turning. What the wheels do is only slightly relevant if at all unless you're holding the brake....and even that wouldn't matter if you're on a treadmill. Second.....are we talking about a treadmill or a conveyer belt? The treadmill may or may not move at all relative to the world if it's the "classic" kind ... (i.e. non-motorized). Depends on whether the wheels or treadmill has better bearings. "Morgans" wrote in message ... "Doug" wrote in message oups.com... What is keeping the airplane's speed up with the conveyor belt? The propeller. Said propeller moves air. Air causes lift. The problem is more complicated than it seems to be at first read. Another way to say it; it had better be a long conveyer belt, cause the prop is pulling the plane forward, without caring how fast the wheels are going. That will make the necessary airspeed to lift off. -- Jim in NC |
Passenger crash-lands plane after pilot suffers heart attack | R.L. | Piloting | 7 | May 7th 05 11:17 PM |
Navy sues man for plane he recovered in swamp | marc | Owning | 6 | March 29th 04 12:06 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
