I know it's "smart" to have, say a pfd when flying over water, but what
equipment is "required" by FAA/FARs.... I'm thinking of a situation like flying to Catalina Island from SNA, maintaining altitude such that we are always in gliding distance of either SNA or the airport at Catalina.... -- -- ET :-) "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams |
The FAA lists required equipment only for flights operating
under FAR 121/135 and large and turbine powered aircraft under 91/and 125. That said, going to Catalina and being able to glide to land would require an altitude of 10-12,000 feet. Also, you can buy some inflatable approved life vests and they can be rented at many FBOs and shops near the coasts. What you can carry depends on the airplane, not much room or useful load in a C150, plenty of both in a King Air 300. As long as you're within gliding distance, a charter in a Baron does not require any floatation gear, but if I paid for a charter to Catalina, I want vests, a small boat and a good personal ELT. On the east coast, the islands are too far to glide back. In any case, if the airplane is in good condition and full of fuel, the odds are on your side. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "ET" wrote in message ... |I know it's "smart" to have, say a pfd when flying over water, but what | equipment is "required" by FAA/FARs.... | | I'm thinking of a situation like flying to Catalina Island from SNA, | maintaining altitude such that we are always in gliding distance of either | SNA or the airport at Catalina.... | | -- | -- ET :-) | | "A common mistake people make when trying to design something | completely foolproof is to underestimate the ingenuity of complete | fools."---- Douglas Adams |
"Jim Macklin" wrote in
news:jHdVf.737$t22.45@dukeread08: The FAA lists required equipment only for flights operating under FAR 121/135 and large and turbine powered aircraft under 91/and 125. That said, going to Catalina and being able to glide to land would require an altitude of 10-12,000 feet. Also, you can buy some inflatable approved life vests and they can be rented at many FBOs and shops near the coasts. What you can carry depends on the airplane, not much room or useful load in a C150, plenty of both in a King Air 300. As long as you're within gliding distance, a charter in a Baron does not require any floatation gear, but if I paid for a charter to Catalina, I want vests, a small boat and a good personal ELT. On the east coast, the islands are too far to glide back. In any case, if the airplane is in good condition and full of fuel, the odds are on your side. OK, so our private craft has no "required" equipment??? Alright, our LSA aircraft has a glide ratio of 11-1 at idle, and 14-1 poweroff (at 60knots "best glide" speed).. We've confirmed the idle glide ratio, but have chosen not to purposely turn the engine off to confirm the poweroff glide speed. So, Avalon is at 1680msl, SNA to Avalon is 34 miles, 1/2 that= 17 miles, then assuming the 11-1 for saftey that's 1.54 miles * 5280=8131 + 1680 (field elevation) = your right, about 10,000 feet going, and about 8000 coming back (SNA is at ~50ftmsl) at the peak of travel.... -- -- ET :-) "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams |
Sec. 91.509 - Survival equipment for overwater operations.
(a) No person may take off an airplane for a flight over water more than 50 nautical miles from the nearest shore unless that airplane is equipped with a life preserver or an approved flotation means for each occupant of the airplane. (b) No person may take off an airplane for a flight over water more than 30 minutes flying time or 100 nautical miles from the nearest shore unless it has on board the following survival equipment: (1) A life preserver, equipped with an approved survivor locator light, for each occupant of the airplane. (2) Enough liferafts (each equipped with an approved survival locator light) of a rated capacity and buoyancy to accommodate the occupants of the airplane. (3) At least one pyrotechnic signaling device for each liferaft. (4) One self-buoyant, water-resistant, portable emergency radio signaling device that is capable of transmission on the appropriate emergency frequency or frequencies and not dependent upon the airplane power supply. (5) A lifeline stored in accordance with 25.1411(g) of this chapter. (c) The required liferafts, life preservers, and signaling devices must be installed in conspicuously marked locations and easily accessible in the event of a ditching without appreciable time for preparatory procedures. (d) A survival kit, appropriately equipped for the route to be flown, must be attached to each required liferaft. (e) As used in this section, the term shore means that area of the land adjacent to the water which is above the high water mark and excludes land areas which are intermittently under water. |
"Tom" wrote in
oups.com: Sec. 91.509 - Survival equipment for overwater operations. (a) No person may take off an airplane for a flight over water more than 50 nautical miles from the nearest shore unless that airplane is equipped with a life preserver or an approved flotation means for each occupant of the airplane. (b) No person may take off an airplane for a flight over water more than 30 minutes flying time or 100 nautical miles from the nearest shore unless it has on board the following survival equipment: (1) A life preserver, equipped with an approved survivor locator light, for each occupant of the airplane. (2) Enough liferafts (each equipped with an approved survival locator light) of a rated capacity and buoyancy to accommodate the occupants of the airplane. (3) At least one pyrotechnic signaling device for each liferaft. (4) One self-buoyant, water-resistant, portable emergency radio signaling device that is capable of transmission on the appropriate emergency frequency or frequencies and not dependent upon the airplane power supply. (5) A lifeline stored in accordance with 25.1411(g) of this chapter. (c) The required liferafts, life preservers, and signaling devices must be installed in conspicuously marked locations and easily accessible in the event of a ditching without appreciable time for preparatory procedures. (d) A survival kit, appropriately equipped for the route to be flown, must be attached to each required liferaft. (e) As used in this section, the term shore means that area of the land adjacent to the water which is above the high water mark and excludes land areas which are intermittently under water. Awsome Tom, Thank you very much for the concise reply, this tells me "excatly" what I need to know. So, my 30 mile flight to Catalina at 110knots cruise does not "require" any special equipment at all (Although I know I'm foolish to go without "some" kind of flotation/pfd/whatever...) Thanks! -- -- ET :-) "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams |
... I know it's "smart" to have, say a pfd when flying over water, but what equipment is "required" by FAA/FARs.... I'm thinking of a situation like flying to Catalina Island from SNA, maintaining altitude such that we are always in gliding distance of either SNA or the airport at Catalina.... FWIW... If it gets hazy over the water, the horizon will dissapear. That may or may not be a problem for you. My brother and I had the same "plan" (stay high enough to glide to one side or the other) for crossing lake Michigan some years ago. The problem was that as we got close to the lake, the horizon started to dissapear. So, we lost some altitude to maintain ground reference, then some more, then some more. At a couple hundred feet above the water, the waves gave enough reference to keep the airplane right side up. Of course, we were no longer high enough to make it to dry land if the engine quit... Now we fly around the bottom of the lake. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail Spell checking is left as an excercise for the reader. |
![]() Tom wrote: Sec. 91.509 - Survival equipment for overwater operations. For clarification, according to this website http://www.equipped.com/avraft4.htm " Part 91.509 "Survival equipment for over water operations" is part of Subpart F dealing only with Large (over 12,500 pounds MTOW) and Turbine-Powered (jet or turboprop) Multiengine Aircraft. This doesn't cover your Cessna 182 or any other light GA aircraft, single or twin." |
In article .com,
"Tom" wrote: Sec. 91.509 - Survival equipment for overwater operations. don't forget which the applicability of 91.509 (found in 91.501) "*91.501***Applicability. (a) This subpart prescribes operating rules, in addition to those prescribed in other subparts of this part, governing the operation of large airplanes of U.S. registry, turbojet-powered multiengine civil airplanes of U.S. registry, and fractional ownership program aircraft of U.S. registry that are operating under subpart K of this part in operations not involving common carriage. The operating rules in this subpart do not apply to those aircraft when they are required to be operated under parts 121, 125, 129, 135, and 137 of this chapter. (Section 91.409 prescribes an inspection program for large and for turbine-powered (turbojet and turboprop) multiengine airplanes and turbine-powered rotorcraft of U.S. registry when they are operated under this part or part 129 or 137.)" -- Bob Noel Looking for a sig the lawyers will hate |
Remember 10,000 is the LSA altitude limit.
Even though the FAA may not require floatation gear, I'd want a Sterns vest for each person. Personally, I get nervous over Lake Michigan or a few miles off shore in a King Air. And I had floatation gear and I can swim. I just prefer airports, unless I have floats on the airplane. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "ET" wrote in message ... | "Jim Macklin" wrote in | news:jHdVf.737$t22.45@dukeread08: | | The FAA lists required equipment only for flights operating | under FAR 121/135 and large and turbine powered aircraft | under 91/and 125. That said, going to Catalina and being | able to glide to land would require an altitude of 10-12,000 | feet. Also, you can buy some inflatable approved life vests | and they can be rented at many FBOs and shops near the | coasts. | | What you can carry depends on the airplane, not much room or | useful load in a C150, plenty of both in a King Air 300. | | As long as you're within gliding distance, a charter in a | Baron does not require any floatation gear, but if I paid | for a charter to Catalina, I want vests, a small boat and a | good personal ELT. On the east coast, the islands are too | far to glide back. | | In any case, if the airplane is in good condition and full | of fuel, the odds are on your side. | | | | OK, so our private craft has no "required" equipment??? | | Alright, our LSA aircraft has a glide ratio of 11-1 at idle, and 14-1 | poweroff (at 60knots "best glide" speed).. We've confirmed the idle glide | ratio, but have chosen not to purposely turn the engine off to confirm the | poweroff glide speed. | | So, Avalon is at 1680msl, SNA to Avalon is 34 miles, 1/2 that= 17 miles, | then assuming the 11-1 for saftey that's 1.54 miles * 5280=8131 + 1680 | (field elevation) = your right, about 10,000 feet going, and about 8000 | coming back (SNA is at ~50ftmsl) at the peak of travel.... | | | -- | -- ET :-) | | "A common mistake people make when trying to design something | completely foolproof is to underestimate the ingenuity of complete | fools."---- Douglas Adams |
Subpart F--LARGE AND TURBINE-POWERED MULTIENGINE AIRPLANES
AND FRACTIONAL OWNERSHIP PROGRAM AIRCRAFT §91.501 Applicability. §91.503 Flying equipment and operating information. §91.505 Familiarity with operating limitations and emergency equipment. §91.507 Equipment requirements: Over-the-top or night VFR operations. §91.509 Survival equipment for overwater operations. §91.511 Radio equipment for overwater operations. §91.513 Emergency equipment. §91.515 Flight altitude rules. §91.517 Passenger information. §91.519 Passenger briefing. §91.521 Shoulder harness. §91.523 Carry-on baggage. §91.525 Carriage of cargo. §91.527 Operating in icing conditions. §91.529 Flight engineer requirements. §91.531 Second in command requirements. §91.533 Flight attendant requirements. §91.535 Stowage of food, beverage, and passenger service equipment during aircraft movement on the surface, takeoff, and landing. §§91.536-91.599 [Reserved] "Tom" wrote in message oups.com... | Sec. 91.509 - Survival equipment for overwater operations. | | (a) No person may take off an airplane for a flight over water more | than 50 nautical miles from the nearest shore unless that airplane is | equipped with a life preserver or an approved flotation means for each | occupant of the airplane. | | (b) No person may take off an airplane for a flight over water more | than 30 minutes flying time or 100 nautical miles from the nearest | shore unless it has on board the following survival equipment: | | (1) A life preserver, equipped with an approved survivor locator light, | for each occupant of the airplane. | | (2) Enough liferafts (each equipped with an approved survival locator | light) of a rated capacity and buoyancy to accommodate the occupants of | the airplane. | | (3) At least one pyrotechnic signaling device for each liferaft. | | (4) One self-buoyant, water-resistant, portable emergency radio | signaling device that is capable of transmission on the appropriate | emergency frequency or frequencies and not dependent upon the airplane | power supply. | | (5) A lifeline stored in accordance with 25.1411(g) of this chapter. | | (c) The required liferafts, life preservers, and signaling devices must | be installed in conspicuously marked locations and easily accessible in | the event of a ditching without appreciable time for preparatory | procedures. | | (d) A survival kit, appropriately equipped for the route to be flown, | must be attached to each required liferaft. | | (e) As used in this section, the term shore means that area of the land | adjacent to the water which is above the high water mark and excludes | land areas which are intermittently under water. | |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
More IFR with VFR GPS questions | Chris Quaintance | Instrument Flight Rules | 58 | November 30th 05 08:39 PM |
ramifications of new TSA rules on all non-US and US citizen pilots | paul k. sanchez | Piloting | 19 | September 27th 04 11:49 PM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
