Ian Stirling wrote:
Peter Dohm wrote: snip The 9 cylinder 1820 and 1840 CID radials used on B-17's were geared approximately 16:9. However, your point is well taken, and I also am unable to name any 4 or 6 cylinder engines that have stood the test of time with reduction drives. I also believe that tuning any drive system, including a PSRU, is a science--when fully understood. And therein lies the rub: There's plenty left to learn--especially if it must also be light. So, in practice, you are right--it is still an art. :-( I suspect that electronics help. Instrumenting the shaft, to measure resonances in real time is no longer prohibitively expensive. I suspect a belt PSRU - if properly configured could act to decouple the prop from the engine/shaft somewhat. Add one or more rotational vibrational dampers - fill the shaft with oil? And trim. Best tool available to the amateur is a variable speed strobe - Party Light! That way you can actually look and SEE what's happening. Richard |
Richard Lamb wrote:
Ian Stirling wrote: Peter Dohm wrote: snip The 9 cylinder 1820 and 1840 CID radials used on B-17's were geared approximately 16:9. However, your point is well taken, and I also am unable to name any 4 or 6 cylinder engines that have stood the test of time with reduction drives. I also believe that tuning any drive system, including a PSRU, is a science--when fully understood. And therein lies the rub: There's plenty left to learn--especially if it must also be light. So, in practice, you are right--it is still an art. :-( I suspect that electronics help. Instrumenting the shaft, to measure resonances in real time is no longer prohibitively expensive. I suspect a belt PSRU - if properly configured could act to decouple the prop from the engine/shaft somewhat. Add one or more rotational vibrational dampers - fill the shaft with oil? And trim. Best tool available to the amateur is a variable speed strobe - Party Light! That way you can actually look and SEE what's happening. That'll spot ordinary vibrations. Torsional ones are a little bit harder. Especially if you want, as you probably should, a graph of maximum stress anywhere in the shaft/PSRU/Prop system vs RPM. |
Ian Stirling wrote:
Best tool available to the amateur is a variable speed strobe - Party Light! That way you can actually look and SEE what's happening. That'll spot ordinary vibrations. Torsional ones are a little bit harder. Especially if you want, as you probably should, a graph of maximum stress anywhere in the shaft/PSRU/Prop system vs RPM. A few fine white lines down the length of the shaft will clear up that problem. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Ernest Christley wrote:
Ian Stirling wrote: Best tool available to the amateur is a variable speed strobe - Party Light! That way you can actually look and SEE what's happening. That'll spot ordinary vibrations. Torsional ones are a little bit harder. Especially if you want, as you probably should, a graph of maximum stress anywhere in the shaft/PSRU/Prop system vs RPM. A few fine white lines down the length of the shaft will clear up that problem. Will they? It'll obviously show huge torsional movement, but many, especially shorter shafts may fail before it becomes visible. |
"Richard Lamb" wrote in message k.net... Best tool available to the amateur is a variable speed strobe - Party Light! That way you can actually look and SEE what's happening. Richard I used to use a tool called a "Strobotach" which was a variable speed strobe unit used for a non-contact tachometer. Very useful for analyzeing periodic motions. :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
The 9 cylinder 1820 and 1840 CID radials used on B-17's were geared approximately 16:9. However, your point is well taken, and I also am unable to name any 4 or 6 cylinder engines that have stood the test of time with reduction drives. Continental GO-300 (Cessna 175). Lycoming GO-435 (Navion). -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail Spell checking is left as an excercise for the reader. |
Peter Dohm wrote:
"Bill Daniels" bildan@comcast-dot-net wrote in message ... The basics: Piston engines produce more power per pound if they rev higher. (HP = RPM x torque/5252) Propellers are MUCH more efficient if they turn slow. This begs for a PSRU. BUT, a PSRU adds weight, cost and complexity. Resonances, particularly torsional resonances are a real problem. Lots of examples of PSRU's on 12, 14 and 18 cyinder engines Few workable examples with fewer cylinders suggesting PSRU's don't like power pulses. If a shaft has a strong resonant fundamental, don't excite it or lower the fundamental below the input frequency. Tuning a PSRU/shaft/propeller system is like tuning a piano - it's an art not a science. The 9 cylinder 1820 and 1840 CID radials used on B-17's were geared approximately 16:9. However, your point is well taken, and I also am unable to name any 4 or 6 cylinder engines that have stood the test of time with reduction drives. I also believe that tuning any drive system, including a PSRU, is a science--when fully understood. And therein lies the rub: There's plenty left to learn--especially if it must also be light. So, in practice, you are right--it is still an art. :-( Peter Rotax - the 912/914 Jabaru - (but the 6 cylinder will be a better seller - IMHO) Believe it or not, a few VW's with belts. And a couple of Subes with Rotax B boxes scabbed on. The one that DIDN'T work was the Geo Metro 3-banger (broke the crank). But that issue was already known - don't cut off any flywheel on 3 holers. With the full flywheel, the 3 cylinder runs fine. Richard |
"Richard Lamb" wrote in message k.net... Peter Dohm wrote: "Bill Daniels" bildan@comcast-dot-net wrote in message ... The basics: Piston engines produce more power per pound if they rev higher. (HP = RPM x torque/5252) Propellers are MUCH more efficient if they turn slow. This begs for a PSRU. BUT, a PSRU adds weight, cost and complexity. Resonances, particularly torsional resonances are a real problem. Lots of examples of PSRU's on 12, 14 and 18 cyinder engines Few workable examples with fewer cylinders suggesting PSRU's don't like power pulses. If a shaft has a strong resonant fundamental, don't excite it or lower the fundamental below the input frequency. Tuning a PSRU/shaft/propeller system is like tuning a piano - it's an art not a science. The 9 cylinder 1820 and 1840 CID radials used on B-17's were geared approximately 16:9. However, your point is well taken, and I also am unable to name any 4 or 6 cylinder engines that have stood the test of time with reduction drives. I also believe that tuning any drive system, including a PSRU, is a science--when fully understood. And therein lies the rub: There's plenty left to learn--especially if it must also be light. So, in practice, you are right--it is still an art. :-( Peter Rotax - the 912/914 Jabaru - (but the 6 cylinder will be a better seller - IMHO) Believe it or not, a few VW's with belts. And a couple of Subes with Rotax B boxes scabbed on. The one that DIDN'T work was the Geo Metro 3-banger (broke the crank). But that issue was already known - don't cut off any flywheel on 3 holers. With the full flywheel, the 3 cylinder runs fine. Richard OK, you caught me fair and square on poor phrasing. I tend to think of higher power applications, but you are right that some of the more conservative and lower powered systems with flywheels still in place and a little looser coupling seem to run quite reliably. I don't know how much power is lost to friction, but some of the v-belt reduction drives even seem to work quite reliably without any external crankshaft support! Peter |
Peter Dohm wrote:
"Richard Lamb" wrote in message k.net... Peter Dohm wrote: "Bill Daniels" bildan@comcast-dot-net wrote in message ... The basics: Piston engines produce more power per pound if they rev higher. (HP = RPM x torque/5252) Propellers are MUCH more efficient if they turn slow. This begs for a PSRU. BUT, a PSRU adds weight, cost and complexity. Resonances, particularly torsional resonances are a real problem. Lots of examples of PSRU's on 12, 14 and 18 cyinder engines Few workable examples with fewer cylinders suggesting PSRU's don't like power pulses. If a shaft has a strong resonant fundamental, don't excite it or lower the fundamental below the input frequency. Tuning a PSRU/shaft/propeller system is like tuning a piano - it's an art not a science. The 9 cylinder 1820 and 1840 CID radials used on B-17's were geared approximately 16:9. However, your point is well taken, and I also am unable to name any 4 or 6 cylinder engines that have stood the test of time with reduction drives. I also believe that tuning any drive system, including a PSRU, is a science--when fully understood. And therein lies the rub: There's plenty left to learn--especially if it must also be light. So, in practice, you are right--it is still an art. :-( Peter Rotax - the 912/914 Jabaru - (but the 6 cylinder will be a better seller - IMHO) Believe it or not, a few VW's with belts. And a couple of Subes with Rotax B boxes scabbed on. The one that DIDN'T work was the Geo Metro 3-banger (broke the crank). But that issue was already known - don't cut off any flywheel on 3 holers. With the full flywheel, the 3 cylinder runs fine. Richard OK, you caught me fair and square on poor phrasing. I tend to think of higher power applications, but you are right that some of the more conservative and lower powered systems with flywheels still in place and a little looser coupling seem to run quite reliably. I don't know how much power is lost to friction, but some of the v-belt reduction drives even seem to work quite reliably without any external crankshaft support! Peter You didn't follow the link that blueskies posted, didja Peter. The BD-5 story - in all it's glory! And a few other odds and ends, That was not a high powered setup, but kicked a bunch of engineers around. http://www.prime-mover.org/Engines/T.../contact1.html Richard |
"Richard Lamb" wrote in message nk.net... Peter Dohm wrote: "Richard Lamb" wrote in message k.net... Peter Dohm wrote: "Bill Daniels" bildan@comcast-dot-net wrote in message ... The basics: Piston engines produce more power per pound if they rev higher. (HP = RPM x torque/5252) Propellers are MUCH more efficient if they turn slow. This begs for a PSRU. BUT, a PSRU adds weight, cost and complexity. Resonances, particularly torsional resonances are a real problem. Lots of examples of PSRU's on 12, 14 and 18 cyinder engines Few workable examples with fewer cylinders suggesting PSRU's don't like power pulses. If a shaft has a strong resonant fundamental, don't excite it or lower the fundamental below the input frequency. Tuning a PSRU/shaft/propeller system is like tuning a piano - it's an art not a science. The 9 cylinder 1820 and 1840 CID radials used on B-17's were geared approximately 16:9. However, your point is well taken, and I also am unable to name any 4 or 6 cylinder engines that have stood the test of time with reduction drives. I also believe that tuning any drive system, including a PSRU, is a science--when fully understood. And therein lies the rub: There's plenty left to learn--especially if it must also be light. So, in practice, you are right--it is still an art. :-( Peter Rotax - the 912/914 Jabaru - (but the 6 cylinder will be a better seller - IMHO) Believe it or not, a few VW's with belts. And a couple of Subes with Rotax B boxes scabbed on. The one that DIDN'T work was the Geo Metro 3-banger (broke the crank). But that issue was already known - don't cut off any flywheel on 3 holers. With the full flywheel, the 3 cylinder runs fine. Richard OK, you caught me fair and square on poor phrasing. I tend to think of higher power applications, but you are right that some of the more conservative and lower powered systems with flywheels still in place and a little looser coupling seem to run quite reliably. I don't know how much power is lost to friction, but some of the v-belt reduction drives even seem to work quite reliably without any external crankshaft support! Peter You didn't follow the link that blueskies posted, didja Peter. The BD-5 story - in all it's glory! And a few other odds and ends, That was not a high powered setup, but kicked a bunch of engineers around. http://www.prime-mover.org/Engines/T.../contact1.html Richard Actually I did, some months ago following an earlier post, and subsequently also learned that the Contact! article is quite famous. One of the more interesting points was that trying to make the shaft and/or transfer drive more rigid was not helpful on the BD-5. Softening the system eventually did resolve the breakage problem within the drive train; but IIRC the drive system to airframe resonance (evidenced initially by loosened rivets) was not fully resolved during the author's tenure. That was the article that really convinced me that I didn't necessarily know enough to design a clutchless system with a high degree of confidence--even by leaving the flywheel in place. However, the set of books mentioned elsewhere in this thread, by Mr. Horton, could prove to contain the necessary formulas and explanations to reduce this problem to a cookbook science. A quick web search confirmed his belief that one of the books may now be virtually unobtainable. I am willing to entertain his book suggestion because, in my earlier career as an electronic technician, a technical tome entitled "Shielding and Grounding Techniques in Instrumentation" made previously insurmountable grounding problems easy to solve. It is probable that work on mechanical resonance, done for World War II, may have been covered in books published during the succeeding quarter century. Peter |
| Thread Tools | |
| Display Modes | |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| Looking for a two-seater design | Shin Gou | Home Built | 13 | December 21st 04 07:44 AM |
| Aircraft Design 1942 flying boats FA | Sally | Home Built | 0 | August 19th 04 07:49 PM |
| amateur design consultant? | Shin Gou | Home Built | 14 | June 30th 04 02:34 AM |
| How 'bout a thread on the F-22 with no mud slinging, no axe grinding, no emotional diatribes, and just some clear, objective discussion? | Scott Ferrin | Military Aviation | 23 | January 8th 04 01:39 AM |
