Recently, I found a link to a very simple, yet useful flight planning sight.
If I recall properly I was able to enter the departure and destination airports, and it calculated initial heading, distance, etc. I believe that I saw it here. Anybody know what I'm talking about? Thanks in advance for your help. |
I don't know if this is the one you are talking about but you might take a
look at the one on WWW.LANDINGS.COM . Also, if you are a member of AOPA they have one that is not too bad. I use the AOPA one all the time. Harry PP-ASEL San Antonio, TX "GE" wrote in message ... Recently, I found a link to a very simple, yet useful flight planning sight. If I recall properly I was able to enter the departure and destination airports, and it calculated initial heading, distance, etc. I believe that I saw it here. Anybody know what I'm talking about? Thanks in advance for your help. |
Yes, that is the one. Thank you.
"Harry Gordon" wrote in message ... I don't know if this is the one you are talking about but you might take a look at the one on WWW.LANDINGS.COM . Also, if you are a member of AOPA they have one that is not too bad. I use the AOPA one all the time. Harry PP-ASEL San Antonio, TX "GE" wrote in message ... Recently, I found a link to a very simple, yet useful flight planning sight. If I recall properly I was able to enter the departure and destination airports, and it calculated initial heading, distance, etc. I believe that I saw it here. Anybody know what I'm talking about? Thanks in advance for your help. |
Harry,
Do you have any problems with AOPA RTFP giving you a plan without winds. I cannot make the program use the winds. I can go to the weather tab and use all the features there. But in the plan flight mode, it just will not go out and get the winds as necessary. I am working with AOPA on the issue. Currently, they are stumped. Until then I continue to use Cirrus 5.0 in the internet mode. Ross KSWI Harry Gordon wrote: I don't know if this is the one you are talking about but you might take a look at the one on WWW.LANDINGS.COM . Also, if you are a member of AOPA they have one that is not too bad. I use the AOPA one all the time. Harry PP-ASEL San Antonio, TX "GE" wrote in message ... Recently, I found a link to a very simple, yet useful flight planning sight. If I recall properly I was able to enter the departure and destination airports, and it calculated initial heading, distance, etc. I believe that I saw it here. Anybody know what I'm talking about? Thanks in advance for your help. |
Ross Richardson wrote:
Harry, Do you have any problems with AOPA RTFP giving you a plan without winds. I cannot make the program use the winds. I can go to the weather tab and use all the features there. But in the plan flight mode, it just will not go out and get the winds as necessary. I am working with AOPA on the issue. Currently, they are stumped. Until then I continue to use Cirrus 5.0 in the internet mode. Ross KSWI Harry Gordon wrote: I don't know if this is the one you are talking about but you might take a look at the one on WWW.LANDINGS.COM . Also, if you are a member of AOPA they have one that is not too bad. I use the AOPA one all the time. Harry PP-ASEL San Antonio, TX "GE" wrote in message ... Recently, I found a link to a very simple, yet useful flight planning sight. If I recall properly I was able to enter the departure and destination airports, and it calculated initial heading, distance, etc. I believe that I saw it here. Anybody know what I'm talking about? Thanks in advance for your help. Ross, I saw this somewhere else. Click on the course "line" and then right click on the course line. You can then pick properties and you can input the wind data from the briefing. The drawback is that it uses those winds for the whole flight. Chris |
I know I can do that, but according to AOPA this program should pick up
the winds aloft and calculate your flight plan. The "tech" that I have talked to said it worked fine for him on the same route that I have been experimenting with. Ross Chris Ehlbeck wrote: Ross Richardson wrote: Harry, Do you have any problems with AOPA RTFP giving you a plan without winds. I cannot make the program use the winds. I can go to the weather tab and use all the features there. But in the plan flight mode, it just will not go out and get the winds as necessary. I am working with AOPA on the issue. Currently, they are stumped. Until then I continue to use Cirrus 5.0 in the internet mode. Ross KSWI Harry Gordon wrote: I don't know if this is the one you are talking about but you might take a look at the one on WWW.LANDINGS.COM . Also, if you are a member of AOPA they have one that is not too bad. I use the AOPA one all the time. Harry PP-ASEL San Antonio, TX "GE" wrote in message ... Recently, I found a link to a very simple, yet useful flight planning sight. If I recall properly I was able to enter the departure and destination airports, and it calculated initial heading, distance, etc. I believe that I saw it here. Anybody know what I'm talking about? Thanks in advance for your help. Ross, I saw this somewhere else. Click on the course "line" and then right click on the course line. You can then pick properties and you can input the wind data from the briefing. The drawback is that it uses those winds for the whole flight. Chris |
I know I can do that, but according to AOPA this program should pick up the winds aloft and calculate your flight plan. The "tech" that I have talked to said it worked fine for him on the same route that I have been experimenting with. Ross Chris Ehlbeck wrote: Ross Richardson wrote: Harry, Do you have any problems with AOPA RTFP giving you a plan without winds. I cannot make the program use the winds. I can go to the weather tab and use all the features there. But in the plan flight mode, it just will not go out and get the winds as necessary. I am working with AOPA on the issue. Currently, they are stumped. Until then I continue to use Cirrus 5.0 in the internet mode. Ross KSWI Harry Gordon wrote: I don't know if this is the one you are talking about but you might take a look at the one on WWW.LANDINGS.COM . Also, if you are a member of AOPA they have one that is not too bad. I use the AOPA one all the time. Harry PP-ASEL San Antonio, TX "GE" wrote in message ... Recently, I found a link to a very simple, yet useful flight planning sight. If I recall properly I was able to enter the departure and destination airports, and it calculated initial heading, distance, etc. I believe that I saw it here. Anybody know what I'm talking about? Thanks in advance for your help. Ross, I saw this somewhere else. Click on the course "line" and then right click on the course line. You can then pick properties and you can input the wind data from the briefing. The drawback is that it uses those winds for the whole flight. Chris It seems I've never been able to get it to import the winds automatically either. Which is why most of the time, I'll use Golden Eagle. |
Some otherwise legitimate programs use parts of IE, and if IE has its security set too high or has parts disabled (usually for good reason), those programs would not work. Find out from the tech whether this might be the case. Jose -- The price of freedom is... well... freedom. for Email, make the obvious change in the address. |
I have issues with Golden Eagle also that I have worked with CSC and
they turned me to Jepp. Still not resolved. Good ol' Cirrus works so good. Chris Ehlbeck wrote: Ross Richardson wrote: I know I can do that, but according to AOPA this program should pick up the winds aloft and calculate your flight plan. The "tech" that I have talked to said it worked fine for him on the same route that I have been experimenting with. Ross Chris Ehlbeck wrote: Ross Richardson wrote: Harry, Do you have any problems with AOPA RTFP giving you a plan without winds. I cannot make the program use the winds. I can go to the weather tab and use all the features there. But in the plan flight mode, it just will not go out and get the winds as necessary. I am working with AOPA on the issue. Currently, they are stumped. Until then I continue to use Cirrus 5.0 in the internet mode. Ross KSWI Harry Gordon wrote: I don't know if this is the one you are talking about but you might take a look at the one on WWW.LANDINGS.COM . Also, if you are a member of AOPA they have one that is not too bad. I use the AOPA one all the time. Harry PP-ASEL San Antonio, TX "GE" wrote in message ... Recently, I found a link to a very simple, yet useful flight planning sight. If I recall properly I was able to enter the departure and destination airports, and it calculated initial heading, distance, etc. I believe that I saw it here. Anybody know what I'm talking about? Thanks in advance for your help. Ross, I saw this somewhere else. Click on the course "line" and then right click on the course line. You can then pick properties and you can input the wind data from the briefing. The drawback is that it uses those winds for the whole flight. Chris It seems I've never been able to get it to import the winds automatically either. Which is why most of the time, I'll use Golden Eagle. |
I will find out. Thanks,
Ross Jose wrote: It seems I've never been able to get it to import the winds automatically either. Which is why most of the time, I'll use Golden Eagle. Some otherwise legitimate programs use parts of IE, and if IE has its security set too high or has parts disabled (usually for good reason), those programs would not work. Find out from the tech whether this might be the case. Jose |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 05:40 AM |
| Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 06:14 AM |
| AirPlan Flight Planning Software Update | Dean Wilkinson | Products | 0 | October 26th 04 12:22 AM |
