Flight planning software
Old April 10th 06, 06:03 AM posted to rec.aviation.piloting
Default Flight planning software
Recently, I found a link to a very simple, yet useful flight planning sight.
If I recall properly I was able to enter the departure and destination
airports, and it calculated initial heading, distance, etc. I believe that I
saw it here. Anybody know what I'm talking about? Thanks in advance for your
help.
Old April 10th 06, 06:58 AM posted to rec.aviation.piloting
I don't know if this is the one you are talking about but you might take a
look at the one on WWW.LANDINGS.COM . Also, if you are a member of AOPA they
have one that is not too bad. I use the AOPA one all the time.
Harry
PP-ASEL
San Antonio, TX
"GE" wrote in message
sight.
I
your
help.
Old April 10th 06, 11:19 AM posted to rec.aviation.piloting
Yes, that is the one. Thank you.
"Harry Gordon" wrote in message
they
Harry
PP-ASEL
San Antonio, TX
sight.
that
I
your
help.
Old April 10th 06, 06:07 PM posted to rec.aviation.piloting
Harry,
Do you have any problems with AOPA RTFP giving you a plan without winds.
I cannot make the program use the winds. I can go to the weather tab and
use all the features there. But in the plan flight mode, it just will
not go out and get the winds as necessary. I am working with AOPA on the
issue. Currently, they are stumped. Until then I continue to use Cirrus
5.0 in the internet mode.
Ross
KSWI
Harry
PP-ASEL
San Antonio, TX
sight.
I
your
help.
Old April 10th 06, 06:33 PM posted to rec.aviation.piloting
Ross Richardson wrote:
Harry,
Ross
KSWI
take a
AOPA they
Harry
PP-ASEL
San Antonio, TX
sight.
that
I
your
help.
Ross,
I saw this somewhere else. Click on the course "line" and then right
click on the course line. You can then pick properties and you can
input the wind data from the briefing. The drawback is that it uses
those winds for the whole flight.
Chris
Old April 10th 06, 11:26 PM posted to rec.aviation.piloting
I know I can do that, but according to AOPA this program should pick up
the winds aloft and calculate your flight plan. The "tech" that I have
talked to said it worked fine for him on the same route that I have been
experimenting with.
Ross
Harry,
winds. I cannot make the program use the winds. I can go to the
weather tab and use all the features there. But in the plan flight
mode, it just will not go out and get the winds as necessary. I am
working with AOPA on the issue. Currently, they are stumped. Until
then I continue to use Cirrus 5.0 in the internet mode.
Ross
KSWI
take a
AOPA they
Harry
PP-ASEL
San Antonio, TX
sight.
believe that
I
your
help.
Ross,
Chris
Old April 11th 06, 12:02 AM posted to rec.aviation.piloting
experimenting with.
Ross
Harry,
Ross
KSWI
take a
AOPA they
Harry
PP-ASEL
San Antonio, TX
sight.
believe that
I
for
your
help.
Ross,
Chris
It seems I've never been able to get it to import the winds
automatically either. Which is why most of the time, I'll use Golden Eagle.
Old April 11th 06, 12:14 AM posted to rec.aviation.piloting
It seems I've never been able to get it to import the winds automatically either. Which is why most of the time, I'll use Golden Eagle.
Some otherwise legitimate programs use parts of IE, and if IE has its
security set too high or has parts disabled (usually for good reason),
those programs would not work. Find out from the tech whether this
might be the case.
Jose
The price of freedom is... well... freedom.
Old April 11th 06, 07:03 PM posted to rec.aviation.piloting
I have issues with Golden Eagle also that I have worked with CSC and
they turned me to Jepp. Still not resolved. Good ol' Cirrus works so good.
up the winds aloft and calculate your flight plan. The "tech" that I
have talked to said it worked fine for him on the same route that I
have been experimenting with.
Ross
Harry,
Ross
KSWI
take a
AOPA they
Harry
PP-ASEL
San Antonio, TX
sight.
destination
believe that
I
advance for
your
help.
Ross,
Chris
Eagle.
Old April 11th 06, 07:05 PM posted to rec.aviation.piloting
I will find out. Thanks,
Ross
Eagle.
might be the case.
Jose
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
AirPlan Flight Planning Software Update Dean Wilkinson Products 0 October 26th 04 12:22 AM
