I was impressed when I found this one. A guy named Mark Ecko penetrates
Airforce 1 security, makes it to the President's plane and spray-paints it with Graffiti, wow, and was not busted. He could have easily attached anything he wanted to. In this case it was only black Spray-paint. You got to see this: http://www.jumpingpixels.com/airforce1.html |
oups.com... I was impressed when I found this one. A guy named Mark Ecko penetrates Airforce 1 security, makes it to the President's plane and spray-paints it with Graffiti, wow, and was not busted. He could have easily attached anything he wanted to. In this case it was only black Spray-paint. You got to see this: http://www.jumpingpixels.com/airforce1.html Is this for real or a hoax? Haven't heard about it anywhere else... JD |
On Tue, 18 Apr 2006 22:57:22 -0700, Joe Delphi wrote:
Is this for real or a hoax? Of course it's a hoax: http://web.morons.org/article.jsp?sectionid=10&id=6914 -- -Jeff B. zoomie at fastmail dot fm |
Seeing as how AF-1 has the same priority as an active alert aircraft,
how would you rate your chances of getting to it? I can tell you where you would end up - on your face, spread-eagled, with a loaded M16 pointed at your back. Saw a GS18 on the ground once - started to take a shortcut across the 'red line'. Walt BJ |
On 20 Apr 2006 19:28:04 -0700, "WaltBJ"
wrote: Seeing as how AF-1 has the same priority as an active alert aircraft, how would you rate your chances of getting to it? I can tell you where you would end up - on your face, spread-eagled, with a loaded M16 pointed at your back. Saw a GS18 on the ground once - started to take a shortcut across the 'red line'. I had to "rescue" our flight engineer one day when, at Seymour-Johnson, he decided to take a "closer look" at a KC-135 behind some red lines. I found that being diplomatic was a Good Thing. I promised that the FE (an ADJ1; E-6) would receive some "counseling" when we got home. I also pointed out that we wern't going home until we got him back. I don't know if that influenced the Lt. Col. to let him go or not, but he did. The FE by this time was pretty much "scared ****less." When we got back home I told the CO what had happened. He had the Command Master Chief to make sure that the promised "counseling" was done. Even reserve units can function "as advertised." :-) Bill Kambic Haras Lucero, Kingston, TN Mangalarga Marchador: Uma Raça, Uma Paixão |
... On 20 Apr 2006 19:28:04 -0700, "WaltBJ" wrote: I had to "rescue" our flight engineer one day when, at Seymour-Johnson, he decided to take a "closer look" at a KC-135 behind some red lines. OK - time for my story. I worked at NAS Point Mugu, CA during the 1980s. There was an old hangar on base that was always posted off-limits because of "PROJECT X". We had to walk past the "PROJECT X" hangar everyday to get from the parking lot to the hangar where we worked. The doors were always closed with some type of death threat warning posted on the doors. Then one day in about 1988 I was walking into work and noticed that the hangar doors were open about 6 inches. Well, you know....I just HAD to pause and stick my nose in there to find out what the big PROJECT X was all about. What I saw: The hangar contained about 15 of the black Secret Service limousines. When President Reagan flew into Point Mugu on Air Force One he normally de-planed and then hopped onto a Marine Helo to make the trip to his ranch. But sometimes the fog rolled into Point Mugu and it was not safe to fly the helo so they kept these limousines stored there just so that he could get to the ranch (about 50 miles away) on the highway. Sort of a Plan B thing. I think the hangar door were open that day because he had left office and the new President (Bush) would not be coming to California so someone had to move the limos to the NEW Plan B location, probably a Naval Air Station near Kennebunkport, ME. I remember that shortly after this, the hangar doors were fully open again and it was used for what airplane hangars are normally used for and the death threat signs were also gone. So the lesson that I learned from all of this is that "PROJECT X" = parking lot for expensive cars. JD |
nice JD, hey...the best naval airshow i have
ever seeb was @ pt magu nas... nice facility... |
ever seen was @ pt magu nas... nice facility... |
A startling Internet video that shows someone spraying graffiti on
President Bush's jet looked so authentic that the Air Force wasn't immediately certain whether the plane had been targeted. It was all a hoax. No one actually sprayed the slogan "Still Free" on the cowling of Air Force One. The pranksters responsible for the grainy, two-minute Web video _ employed by a New York fashion company _ revealed Friday how they pulled it off: a rented 747 in California painted to look almost exactly like Air Force One. "I wanted to do something culturally significant, wanted to create a real pop-culture moment," said Marc Ecko of Marc Ecko Enterprises. "It's this completely irreverent, over-the-top thing that could really never happen: this five-dollar can of paint putting a pimple on this Goliath." The video shows hooded graffiti artists climbing barbed-wire fences and sneaking past guards with dogs to approach the jumbo jet. They spray-paint a slogan associated with free expression. After the video began circulating on the Web on Tuesday, the Air Force checked to see whether the plane had been vandalized. "We're looking at it, too," said Lt. Col. Bruce Alexander, a spokesman for the Air Mobility Command's 89th Airlift Wing, which operates Air Force One. "It looks very real." Alexander later confirmed that no such spray-painting had occurred. Ecko acknowledged Friday that his company had rented a 747 cargo jet at San Bernardino's airport and covertly painted one side to look like Air Force One. Employees signed secrecy agreements and worked inside a giant hangar until the night the video was made. Ecko declined to say how much the stunt cost. "It's not cheap," he said. "You have to be rich." |
| Thread Tools | |
| Display Modes | |
| A Guy spray-painted Airforce 1, WOW*, Presidential Graffiti....... all on Tape | [email protected] | General Aviation | 11 | May 13th 06 06:50 PM |
| A Guy spray-painted Airforce 1, WOW*, Presidential Graffiti....... all on Tape | Hansi | Piloting | 13 | April 22nd 06 07:29 PM |
