wrote in message ... What you're looking for is an airway database. Even the IFR Garmins don't have that. Those are the domain of airliners and biz jets for the most part. Even my old Northstar M3 has an airway data base. And I frequently use it to fly a flight plan using airways. |
Stan Prevost wrote: wrote in message ... What you're looking for is an airway database. Even the IFR Garmins don't have that. Those are the domain of airliners and biz jets for the most part. Even my old Northstar M3 has an airway data base. And I frequently use it to fly a flight plan using airways. Sigh. That's why I said for the most part. ;-) There are very few of those in use compared to Garmins and Kings. |
Dash8Driver wrote: Enter VORs as waypoints in a flight plan? And, turn points between VORs, if any. |
"Robert M. Gary" wrote in message om... (David Lindenauer) wrote in message ... On 15 Jun 2004 21:18:09 -0700, (Robert M. Gary) wrote: So how do you Garmin guys easily fly along an airway graphically? You have to put in everything that creates a bend in the airway: VORs, intersections. To make the task less daunting, in practice I put in just the first couple of these, then add the rest in cruise flight when the workload reduces. Do you define them between two airway points (one behind you) or do you have to direct to the next fix and just guess how far off the airway you are? You enter the one behind you and activate the leg you are intercepting. Michael |
Michael 182 wrote:
You enter the one behind you and activate the leg you are intercepting. This is about intercepting an airway at some point that's not a fix, right? In that case, you could "build" the airway segment with the fixes before and after your intercept point or you could get "after" fix into the GPS and then use OBS mode. I have to admit, though, when given an airway intercept I find it easier to use a VOR receiver. The "user interface" seems to involve less work to me (although the end result of the GPS process yields more benefit). - Andrew |
There is another way to do this with the Garmin. Suppose
you're on V123 sector between the A and B VORs, and you have to turn onto V345 at an unnamed intersection between the X and Y VORs. Enter the flightplan A-B-X-Y. It will look funny on the display, but don't worry about it. Start flying from A to B. When you get fairly close to V345 (say five miles), go to the flight plan page, cursor down to Y and hit Direct-Direct-Enter. The GPS now thinks you're trying to intercept V345. Fly current heading until the CDI comes in, or even easier hit HDG-NAV on the a/p and let the autopilot fly the intercept. Or you can just use the VORs - which is what I do. Would it be easier if the GPS could do this all by itself? Sure. Would it be of the slightest significance in the big scheme of things? I don't think so. John "Andrew Gideon" wrote in message online.com... Michael 182 wrote: You enter the one behind you and activate the leg you are intercepting. This is about intercepting an airway at some point that's not a fix, right? In that case, you could "build" the airway segment with the fixes before and after your intercept point or you could get "after" fix into the GPS and then use OBS mode. I have to admit, though, when given an airway intercept I find it easier to use a VOR receiver. The "user interface" seems to involve less work to me (although the end result of the GPS process yields more benefit). - Andrew |
| Thread Tools | |
| Display Modes | |
| Marske Flying Wing discussion Group | mat Redsell | Home Built | 0 | September 19th 04 02:58 PM |
| Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 06:07 PM |
| Flying Wing Design workshop in july 04 | mat Redsell | Home Built | 1 | May 5th 04 02:53 PM |
| restarting instrument flying | Matthew S. Whiting | Instrument Flight Rules | 13 | November 21st 03 02:04 PM |
| seeking info from NW Ontario/ Upper Midwest Pilots flying intoAtikokan | David Megginson | Instrument Flight Rules | 0 | July 9th 03 04:04 PM |
