Paul Tomblin wrote:
Our club just got a 530 for one of our planes, and so before I fly it I'm spending a lot of time with Garmin's simulator. So one of the flights I do a lot is here (KROC) to Ottawa (CYOW) and back. When I fly from Ottawa, I always get the OTTAWA ONE departure, which means I put ASHTN and REEDO in my handheld GPS flight plan. But since the manual tells me that I can select depature procedures in the 530, I thought I could leave them off my flight plan on the 530 and have the procedure loaded. But at least in the simulator, I have no such luck - I can't select this departure procedure. Is this a limitation of the simulator, or does the 530 not allow you to select departure procedures if they're classified as "vector"? If it is purely a vector departure; i.e., "fly xxx heading for vectors to en route fix" then the 530 won't have those. Why should it? All you do is fly an initial heading for vectors. |
In a previous article, Sam Spade said:
Paul Tomblin wrote: can't select this departure procedure. Is this a limitation of the simulator, or does the 530 not allow you to select departure procedures if they're classified as "vector"? If it is purely a vector departure; i.e., "fly xxx heading for vectors to en route fix" then the 530 won't have those. Why should it? All you do is fly an initial heading for vectors. Well, it's vectors to several specific courses - for instance the way I go it's vectors to intercept the R-199 from YOW somewhere between ASHTN and REEDO. So it would be useful to have the GPS put ASHTN and REEDO in the procedure. -- Paul Tomblin http://xcski.com/blogs/pt/ When C++ is your hammer, everything looks like a thumb. -- Steven M. Haflich |
Paul Tomblin wrote:
In a previous article, Sam Spade said: Paul Tomblin wrote: can't select this departure procedure. Is this a limitation of the simulator, or does the 530 not allow you to select departure procedures if they're classified as "vector"? If it is purely a vector departure; i.e., "fly xxx heading for vectors to en route fix" then the 530 won't have those. Why should it? All you do is fly an initial heading for vectors. Well, it's vectors to several specific courses - for instance the way I go it's vectors to intercept the R-199 from YOW somewhere between ASHTN and REEDO. So it would be useful to have the GPS put ASHTN and REEDO in the procedure. Garmin has no way of knowing which of many possible waypoints the vector will take you to. So, you have to line select the waypoints and TF legs appropriate to the vector. On the other hand, with a structured SID, with very specific transitions, then Garmin has it all there; i.e., the three elements: The SID, the runway, and the transition. If a vector SID were to have structured, fix transitions published on the source document, then Garmin would include those transitions in the database. |
(Paul Tomblin) wrote in
: Well, it's vectors to several specific courses - for instance the way I go it's vectors to intercept the R-199 from YOW somewhere between ASHTN and REEDO. So it would be useful to have the GPS put ASHTN and REEDO in the procedure. Put them (everything) in a stored route. -- Regards, Stan "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." B. Franklin |
| Thread Tools | |
| Display Modes | |
| Question on Aivdyne / Garmin Integrated Avionics Packages | Jon | Instrument Flight Rules | 14 | June 2nd 05 01:26 AM |
| Question on Aivdyne / Garmin Integrated Avionics Packages | Jon | Owning | 14 | June 2nd 05 01:26 AM |
| Garmin 296 worth the money? | Terry | Piloting | 3 | June 17th 04 08:24 AM |
| garmin 296 | Robert M. Gary | Piloting | 1 | June 16th 04 07:59 PM |
| Garmin 76S question | Carl Buehler | Soaring | 2 | April 30th 04 12:06 PM |
