Hello all,
A colleague from our club is on the way to buy a Pik 20B. The trailer got broken into on the way for the sell and the sad individuals ran off with the tool box that contained the connecting pins in question. Glider untouched. We are now looking for Pik 20B control rod connecting pip pins. Is there someone that would sell 4 of these pins? Otherwise does anyone know where I may find a supply? I gather they would be metric in size but no idea what diameter they would be. Best regards Marc Arsenault 74 |
McMaster-Carr has them in some metric sizes:
http://www.mcmaster.com Search on "quick release pins." |
Marc Arsenault wrote:
Hello all, A colleague from our club is on the way to buy a Pik 20B. The trailer got broken into on the way for the sell and the sad individuals ran off with the tool box that contained the connecting pins in question. Glider untouched. We are now looking for Pik 20B control rod connecting pip pins. Is there someone that would sell 4 of these pins? Otherwise does anyone know where I may find a supply? I gather they would be metric in size but no idea what diameter they would be. Best regards Marc Arsenault 74 Marc I just went out and checked mine for you. The diameter is 0.247 inch.(These are available in the US with a 0.250 inch diameter). The length of the shank is 1.102 inch. The head length is 0.590 inch. Now a suggestion. I have connected the right flap and aileron pins together with a short piece of parachute cord. I have done same with the pins on the left as well. I never remove a connected pair. This prevents loss and dropping one into the bilge. The cord has never interferred with the mixer movement at least over the last 30 years but do have your A&I check it out. I hope that this helps. Paul |
Paul and Bob,
Thank you very much for your help. I am looking into it Monday morning. Cheers from Montreal Marc |
They are metric, made of stainless steel, and I believe the shank to be
6mm in diameter. I am using them, but the previous owner was using 6mm aircraft bolts and several washers with safety pins. He said he never felt secure with the pip pins. Go figure... Jack Womack PIK-20B N77MA (TE) |
Hello Jack et all,
Thank you for the measurment. Best regards Marc Arsenault 74 "Jack" a écrit dans le message de news: ... They are metric, made of stainless steel, and I believe the shank to be 6mm in diameter. I am using them, but the previous owner was using 6mm aircraft bolts and several washers with safety pins. He said he never felt secure with the pip pins. Go figure... Jack Womack PIK-20B N77MA (TE) |
As an Austin-Healey maintainer I'm familiar with grub screws and nib
nuts, but what's a pip pin? -John |
Earlier, jcarlyle wrote:
...what's a pip pin? Generally, it's a mechanical pin retained by one or more balls at the tip that protrude beyond the cylindrical body of the pin. The balls are either spring loaded, or are allowed to retract when you press the button on the handle of the pin. Here's a picture of a typical locking pin: http://www.aircraftspruce.com/catalo.../qkrelease.jpg Thanks, and best regards to all Bob K. http://www.hpaircraft.com/hp-24 |
Aha! Thanks very much for adding to my dictionary of UK-US terms, Bob!
-John Bob Kuykendall wrote: Here's a picture of a typical locking pin: http://www.aircraftspruce.com/catalo.../qkrelease.jpg |
| Thread Tools | |
| Display Modes | |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 04:55 AM |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 10:39 PM |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
