The plane does have an alternate static source vented inside; however, I
pushed the valve in to select the exterior port. My guess is that either this is normal or the static pressure system has a leak. "Ron Rosenfeld" wrote in message ... On Fri, 6 Aug 2004 10:11:59 -0400, "Derrick Early" wrote: When I close the door to my 172, the airspeed, vsi and altimeter instruments jump. Does this mean that I have a leak in my static line? The last check of the system was 18 to 20 months ago. The last thing that I want is errors in altitude while flying IFR. Do you have an alternate static source that is inside the cabin, and possible in the wrong position? --ron |
Yes, this is possible. I'm trying to figure out if jumpy instruments is
normal. I think that I should make a test or have it tested. "SFM" wrote in message ... Could this just be that the static port is very close to the pilot's door and you closing it cause a disruption of air over the outside static port? Scott -- ------------------------------------------------------------------ Scott F. Migaldi, K9PO MI-150972 PP-ASEL-IA Are you a PADI Instructor or DM? Then join the PADI Instructor Yahoo Group at http://groups.yahoo.com/group/PADI-Instructors/join ----------------------------------- Catch the wave! www.hamwave.com **"A long time ago being crazy meant something, nowadays everyone is crazy" -- Charles Manson** ------------------------------------- "Derrick Early" wrote in message ... When I close the door to my 172, the airspeed, vsi and altimeter instruments jump. Does this mean that I have a leak in my static line? The last check of the system was 18 to 20 months ago. The last thing that I want is errors in altitude while flying IFR. |
When I close the door to my 172, the airspeed, vsi and altimeter instruments jump. Does this mean that I have a leak in my static line? The last check of the system was 18 to 20 months ago. The last thing that I want is errors in altitude while flying IFR. A way you can evauluate this... If you are flying along and you OPEN the alternate static port and it doesn't do anything... you have a leak. Usually will change the altitude 50-100 feet. Bill Hale |
| Thread Tools | |
| Display Modes | |
| ADF static? question | JFLEISC | Home Built | 3 | December 28th 04 02:28 AM |
| What caused the VSI and ALT bouce in the IMC? | cpu | Instrument Flight Rules | 38 | May 5th 04 04:45 PM |
| FS: Avery Dennison Adds Static Cling Vinyls to Fasson® Rapid-Roll Dry erase easel pads that clings to most walls. | M.Roy | Home Built | 0 | February 11th 04 06:18 PM |
| Is a static port a precision thing? | Larry Smith | Home Built | 8 | August 12th 03 11:26 PM |
| Canard static port location | Paul Lee | Home Built | 1 | July 12th 03 03:55 AM |
