Matt Whiting wrote in news:Sf_lg.9891$lb.874408
@news1.epix.net: Skywise wrote: Bob Moore wrote in . 122: Dylan Smith wrote Snipola http://en.wikipedia.org/wiki/Deep_stall This Wikipedia article leaves a lot to be desired. Snipola The beauty of Wikipedia is that YOU can change it. Brian Which is why it leaves a lot to be desired. Matt I have heard more than once that a collection of average people is smarter than a few experts. If no one corrects the data then it will continue to be wrong. I've been seriously thinking of getting an account so I can make changes as I see the need. Mostly minuscule stuff, but every bit would help. The only concern I have is time. I find it fascinating, the human capacity to bitch about something, yet not have the willingness to actually DO soemthing to fix the problem. I'll admit up front I've done that myself, and it's something I should change. Brian -- http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html Quake "predictions": http://www.skywise711.com/quakes/EQDB/index.html Sed quis custodiet ipsos Custodes? |
Dylan Smith wrote: Conventional light planes should not do that (i.e. certified, non-canard designs). A Morane Saulnier Rallye is a conventional certified light plane and it just drops with its nose up and tail down when stalled. But I suppose it is an exception to the rule. -Kees. |
Hi Marty, Rallyes are really fun, I miss mine from time to time. :-( -Kees (D-EHNE) |
Ron Rosenfeld wrote: Thinking about it simply, if the airplane is not generating lift, it should fall with the heaviest end down. For most light GA a/c, the engine is up front, so that end goes down first. The wing's center of pressure moves forward as the stall is approached, as the laminar flow over the top of the wing breaks up toward the trailing edge and lift is lost over the aft area of the wing. At the stall, the center of pressure moves aft as the whole laminar flow goes turbulent, and the CP shift lifts the tail. The loss of effective downforce on the stabilizer as speed decreases contributes to the nose drop. That's the "heavy end down" effect you speak of. Dan |
On Tue, 20 Jun 2006 07:36:13 -0400, Ron Rosenfeld
wrote in :: On 20 Jun 2006 03:30:46 -0700, wrote: Is it possible for an aircraft to stall and sink nose-up tail-down instead of pitching nose-down? Or does aircraft design inherently preclude that? ![]() Thanks in advance, Ramapriya Thinking about it simply, if the airplane is not generating lift, it should fall with the heaviest end down. For most light GA a/c, the engine is up front, so that end goes down first. You may recall, that Galileo Galilei (1564-1642) performed experiments to verify that heavier bodies do not fall faster than lighter ones, rather that they fall at the same rate, therefore your analysis is incorrect. While it is true, that an airplane in a vacuum will fall in any orientation, in the atmosphere, it is practically impossible to prevent the falling airplane's wings from providing some lift. Given an airplane correctly loaded within its weight and balance envelope, when the wing is generating lift, the center of lift is located behind the aircraft's center of gravity. The center of gravity acts as a fulcrum, and the lifting force aft of the CG is acting in the direction roughly upward, while the gradational force acts uniformly on the entire airplane in a downward direction resulting in the nose dropping as the aircraft was designed. |
On Tue, 20 Jun 2006 14:00:39 GMT, Larry Dighera wrote:
On Tue, 20 Jun 2006 07:36:13 -0400, Ron Rosenfeld wrote in :: On 20 Jun 2006 03:30:46 -0700, wrote: Is it possible for an aircraft to stall and sink nose-up tail-down instead of pitching nose-down? Or does aircraft design inherently preclude that? ![]() Thanks in advance, Ramapriya Thinking about it simply, if the airplane is not generating lift, it should fall with the heaviest end down. For most light GA a/c, the engine is up front, so that end goes down first. You may recall, that Galileo Galilei (1564-1642) performed experiments to verify that heavier bodies do not fall faster than lighter ones, rather that they fall at the same rate, therefore your analysis is incorrect. While it is true, that an airplane in a vacuum will fall in any orientation, in the atmosphere, it is practically impossible to prevent the falling airplane's wings from providing some lift. Given an airplane correctly loaded within its weight and balance envelope, when the wing is generating lift, the center of lift is located behind the aircraft's center of gravity. The center of gravity acts as a fulcrum, and the lifting force aft of the CG is acting in the direction roughly upward, while the gradational force acts uniformly on the entire airplane in a downward direction resulting in the nose dropping as the aircraft was designed. You're both getting into a more complicated, thoughtful (and accurate) analysis than I. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
The location of the center of gravity directly relates to an
aircraft's dynamic and static stability. Stall behavior with a CG aft of the center of pressure on a wing will cause the stalled aircraft to pitch deeper into the stall. The stall buffet comes from disturbance of the air flow over the wing root, but the actual stall comes from the tail. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. wrote in message oups.com... | Is it possible for an aircraft to stall and sink nose-up tail-down | instead of pitching nose-down? Or does aircraft design inherently | preclude that? ![]() | | Thanks in advance, | | Ramapriya | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Practice stalls on your own? | [email protected] | Piloting | 34 | May 30th 05 06:23 PM |
| Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 05:05 AM |
| military men "dumb, stupid animals to be used" Kissinger | B2431 | Military Aviation | 3 | April 26th 04 06:46 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
