"Matt Whiting" wrote in message
... Jim Macklin wrote: The tail is more heavily loaded and at a higher angle of attack than the wing. The tail lift is actually a tail down force. You can look up a textbook on stability, control and weight and balance to see that with a conventional tail, the wing lift is located on the center of pressure, while the CG is located some small distance forward of that point. The tail provides a downward forced on the tail that creates a moment around the CG to balance the moment arm between the center of pressure and the CG. When the pilot feels a stall buffet, it is caused by air flow separation that impacts the tail or some other part of the structure. But the stall break happens when the tail stalls and the CG moment is no longer countered by the tail down force. Personally, I don't believe this. If this were the case, then during a full stall landing, the airplane would rise upward when the tail stalled as the net force in the vertical direction would be greater upward than downward. Yes the airplane would rotate about the center of lift and the nose would fall, but the wing would be rising at the same time. This isn't the way any airplane I've ever flown behaved. http://www.faa.gov/library/manuals/a...83-25-1of4.pdf I did a quick search and find nothing about the tail stalling before the wing under normal conditions. On which page did you see this? There's a paragraph on p. 3-21 that makes part (but not most) of the erroneous claim that Jim attributes to the publication. In particular, the paragraph does say (in a discussion of a typical GA plane's normal stall) that the tail loses lift (along with the wings). But it does not attribute the plane's stall to the tail's supposed loss of lift; on the contrary, it credits the supposed loss of lift with helping to recover from the stall. (Additionally, the paragraph claims that the wings' lift *ceases* during a stall, which is not the case.) --Gary |
![]() Orval Fairbairn wrote: The Velocity has a very large forward underside that does the same thing. In fact, the designer rode one all the way into a swamp doing deep stall tests. He was about to bail out when he noticed that the sink rate was on the order of 1000 fpm, so he rode it down and emerged unhurt. In fact, the airplane was repaired and flew again. Interesting. I can just imagine the thought process in that scenario. "Oh s**t I've lost it! Oh God!... uh... hey, it's only falling at 1000fpm - this should be survivable!! I'll stay with it then!! G I heard of a pair of engineers from SRI who took a TC up high and tried the deep stall. They tried everything to recover and ended up unbuckling their seatbelts and getting under the panel. The plane finally recovered into a high speed dive and bent the structure on recovery. I would like to see two humans fit under the panel in a Twinkie. Were these guys circus freaks?? |
![]() "Kingfish" wrote I would like to see two humans fit under the panel in a Twinkie. Were these guys circus freaks?? I would say that if you thought you were about to die, but could be saved by crawling into my back pocket, you would probably find a way to fit! g -- Jim in NC |
Practice stalls on your own? | [email protected] | Piloting | 34 | May 30th 05 05:23 PM |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
military men "dumb, stupid animals to be used" Kissinger | B2431 | Military Aviation | 3 | April 26th 04 05:46 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
