tail ballast antifreeze
Old June 28th 06, 07:24 PM posted to rec.aviation.soaring
Default tail ballast antifreeze
Try windshield washer fluid
Old June 28th 06, 07:52 PM posted to rec.aviation.soaring
Does anyone disagree with JS's statement that I do not need tail
ballast antifreeze for flying at -5C for six or seven hours? I can't
imagine six liters of sloshing water freezing at only a few degrees
below. But I don't have practical experience in this area and I don't
want to make a really expensive mistake.
I appreciate all the feedback but I'm specifically asking about (1)
methanol, (2) ethanol and (3) none. I'm familiar with all the other
options from older posts.
Ely in 3 days -- can't wait!
~ted
V2C "2NO"
Old June 28th 06, 11:47 PM posted to rec.aviation.soaring
The German manufacturers would rather have their customers release the =
tail ballast at +2=BAC. I suspect solar radiation is the reason why =
people can keep their water at lower air temperatures without =
immediately being awarded a split tailplane.
So if you have both outside temperatures below 2=BAC and no sunlight ... =
beware!
Old June 29th 06, 12:51 AM
bagmaker bagmaker is offline
Senior Member
First recorded activity by AviationBanter: Aug 2005
Cool
Wont the "sloshing around" restrict the ability of the water to freeze solid? More likely to get a frozen slushy effect.
I suggest vodka 20% and red cordial at 20% would be the perfect mix, wont freeze solid, you can see it on the metal bits to hose it off and it wont bother the feilds too much when dumped. Cant wait for first drinks at an outlanding party either!
Bagger
HEY! Only joking!
Old June 29th 06, 12:07 AM posted to rec.aviation.soaring
beware!
I've been assuming that solar heating is the reason that the tail
ballast doesn't end up freezing during these summer flights. At a few
degrees below 0C in shadow, it should still take something more than an
hour for a few liters of water to freeze to the extent that it would
cause structural damage. Lack of lift and cold toes would cause me to
seek warmer environs long before that point...
Old June 29th 06, 03:31 PM posted to rec.aviation.soaring
What can happen though is that the small water content in the valve does
freeze, nad then you'll have a bloody leaking valve.
"Marc Ramsey" wrote in message
beware!
I've been assuming that solar heating is the reason that the tail ballast
doesn't end up freezing during these summer flights. At a few degrees
below 0C in shadow, it should still take something more than an hour for a
few liters of water to freeze to the extent that it would cause structural
damage. Lack of lift and cold toes would cause me to seek warmer environs
Old June 29th 06, 04:25 PM posted to rec.aviation.soaring
Hi,
I am not an expert on high altitude flying as I've done very little of it.
However, I do believe I would take the possibility of water freezing in the
wing and/or tail very seriously if I were flying above 10,000 feet for more
than a few minutes. The reason is that a while back I saw a photo of a
glider with the leading edge of the wing split open due to water freezing
and expanding in the wing. It was a dramatic photo taken in flight with the
leading edge open 4 inches or more over a split that was perhaps 3 feet
long. This is all from memory so I may not be remembering correctly. It
think it was a photo in Soaring magazine.
Good Soaring,
Paul Remde
"Bert Willing" wrote in message
beware!
a few liters of water to freeze to the extent that it would cause
structural damage. Lack of lift and cold toes would cause me to seek
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
AH64 tail rotor CivetOne Rotorcraft 3 October 23rd 03 08:18 PM
The prone postion for tail gunners versus turrets. The Enlightenment Military Aviation 8 July 23rd 03 12:01 AM
