Each manufacturer used his own scale for AOA 'units'. The 104's read
from 0 to 5. At 5 the auto stick kicker kicked. I never looked at the AOA gauge in the F4 on approach - I used the 'bullseye' indicator and if the runway was wet it ws the bullseye plus the slow chevron together. FWIW the F102 with its 60 degree swept delta wing did make its approach at roughly 15 degrees which happily coincided with the tip of the pitot boom on the horizon. (Same AOA for rotation and liftoff.) At 18 degrees you could drag the tailpipe (and P/O maintenance!) I'd be surprised if an F14 in standard landing config reached 15 degrees AOA. Walt BJ |
Hey Scott,
For the F-14 approach alpha, true degrees is 10.8 which is published in various sources. Julian. |
" wrote in message oups.com... Hey Scott, For the F-14 approach alpha, true degrees is 10.8 which is published in various sources. Julian. That would make my 20 year old memory (11 degrees) pretty good. R / John |
John Carrier wrote: " wrote in message oups.com... Hey Scott, For the F-14 approach alpha, true degrees is 10.8 which is published in various sources. Julian. That would make my 20 year old memory (11 degrees) pretty good. R / John Yes it does John! ![]() Julian |
"Each manufacturer used his own scale for AOA 'units'. The 104's read
from 0 to 5. At 5 the auto stick kicker kicked." so Walt, do we see these "units of measure" in other industries? Such as boating, mining, manufacturing/lazers, etc..? |
| Thread Tools | |
| Display Modes | |
| RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 07:31 PM |
| Canadian holding procedures | Derrick Early | Instrument Flight Rules | 24 | July 22nd 04 05:03 PM |
| Approach Question- Published Missed Can't be flown? | Brad Z | Instrument Flight Rules | 8 | May 6th 04 05:19 AM |
| Where is the FAF on the GPS 23 approach to KUCP? | Richard Kaplan | Instrument Flight Rules | 36 | April 16th 04 01:41 PM |
| IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 10:03 PM |
