#11
wrote in message oups.com... I'm betting there is a really good reason, but why not use automotive antifreeze? Is it not compatible with composites? Very bad for the environment. and you can't drink it if you land out. Al |
Try windshield washer fluid
Does anyone disagree with JS's statement that I do not need tail
ballast antifreeze for flying at -5C for six or seven hours? I can't imagine six liters of sloshing water freezing at only a few degrees below. But I don't have practical experience in this area and I don't want to make a really expensive mistake. I appreciate all the feedback but I'm specifically asking about (1) methanol, (2) ethanol and (3) none. I'm familiar with all the other options from older posts. Ely in 3 days -- can't wait! ~ted V2C "2NO" |
The German manufacturers would rather have their customers release the =
tail ballast at +2=BAC. I suspect solar radiation is the reason why = people can keep their water at lower air temperatures without = immediately being awarded a split tailplane. So if you have both outside temperatures below 2=BAC and no sunlight ... = beware! |
Francisco De Almeida wrote:
The German manufacturers would rather have their customers release the = tail ballast at +2=BAC. I suspect solar radiation is the reason why = people can keep their water at lower air temperatures without = immediately being awarded a split tailplane. So if you have both outside temperatures below 2=BAC and no sunlight ... = beware! I've been assuming that solar heating is the reason that the tail ballast doesn't end up freezing during these summer flights. At a few degrees below 0C in shadow, it should still take something more than an hour for a few liters of water to freeze to the extent that it would cause structural damage. Lack of lift and cold toes would cause me to seek warmer environs long before that point... |
I may as well mention another variable: radiant temperature.
Imagine you are attending a spring wave camp in some Nordic country. It = is a beautiful, cold, clear day without a trace of cloud. The sun gives = little warmth as its rays are so slanted. In these conditions, even if = outside air temperature is, let's say, +2=BAC, you are already in risk, = because the sky vault has a radiant temperature some ten degrees lower = than the local air temperature, and will be chilling all exposed = surfaces. This is the same mechanism that causes frost on clear nights. = Manufacturers have to take into account such worst case scenarios for = certification purposes. In a midsummer Arizona day things will be quite different. The blazing = sun, re-irradiation from cumulus clouds and even from the warm ground, = will ensure that the mean radiant temperature to which the glider is = subjected is higher than the air temperature at altitude. Therefore, a = (few) degrees below zero will still be safe. |
Wont the "sloshing around" restrict the ability of the water to freeze solid? More likely to get a frozen slushy effect.
I suggest vodka 20% and red cordial at 20% would be the perfect mix, wont freeze solid, you can see it on the metal bits to hose it off and it wont bother the feilds too much when dumped. Cant wait for first drinks at an outlanding party either! Bagger HEY! Only joking! |
Francisco De Almeida a écrit :
I may as well mention another variable: radiant temperature. Imagine you are attending a spring wave camp in some Nordic country. It = is a beautiful, cold, clear day without a trace of cloud. The sun gives = little warmth as its rays are so slanted. In these conditions, even if = outside air temperature is, let's say, +2=BAC, you are already in risk, = because the sky vault has a radiant temperature some ten degrees lower = than the local air temperature, and will be chilling all exposed = surfaces. This is the same mechanism that causes frost on clear nights. = Manufacturers have to take into account such worst case scenarios for = certification purposes. In a midsummer Arizona day things will be quite different. The blazing = sun, re-irradiation from cumulus clouds and even from the warm ground, = will ensure that the mean radiant temperature to which the glider is = subjected is higher than the air temperature at altitude. Therefore, a = (few) degrees below zero will still be safe. you're right, but I suspect that thermal inertia is even more important than radiation. Put 5 liter of water at 30°C in an fiberglass can into a freezer at -5°C, I suspect it will take hours to freeze. And in flight you're not always at cloudbase, only the temperature at mean altitude counts -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
| Thread Tools | |
| Display Modes | |
| I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 04:55 AM |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| AH64 tail rotor | CivetOne | Rotorcraft | 3 | October 23rd 03 08:18 PM |
| The prone postion for tail gunners versus turrets. | The Enlightenment | Military Aviation | 8 | July 23rd 03 12:01 AM |
