#121
"Ron Wanttaja" wrote Yes, but: Most of the other warbirds you saw have tailwheel steering. Without it, directional control is pretty indirect, and S-turning isn't just a matter of a casual push on a pedal. Couple that with the realization that every S-turn wears a brake pad, and that pads for TBMs are probably neither common nor cheap. Heck, they're $200 a pair just for my Fly Baby... Ron, you know better than that. Every type of warbird at OSH has taxied past me. They all managed. Plus, the cost of brakes is part of being at OSH. If you can not taxi safely cause it costs too much, stay home. Couple with a big radial cowling, the pilot probably doesn't truly get a good view forward until the longitudinal axis takes a significant offset from the centerline. With that, you're heading towards the taxiway lights that much quicker, and you're going to want to turn back early enough so the wheels don't leave the pavement. There are no taxiway lights on that particular taxiway. It is not a normally used taxiway. Like Dougdrivr said, it certainly was the pilot's responsibility to clear the taxiway ahead. But I can sympathize with the problems he faced. Problems that can be overcome, since everyone else managed. -- Jim in NC |
#122
Morgans wrote:
"Ron Wanttaja" wrote Yes, but: Most of the other warbirds you saw have tailwheel steering. Ron, you know better than that. Every type of warbird at OSH has taxied past me. They all managed. Plus, the cost of brakes is part of being at OSH. If you can not taxi safely cause it costs too much, stay home. And all of it is neither here nor there. I used to drive a big truck, and 18-wheeler as moving van. 18 wheels down through residential neighborhoods. The number one rule was "If you don't know you're clear, you don't move." Period. No guessing. No thinking. No hoping and no wishing. Either you can see you're clear through mirrors or sticking your head out the window, or you have your partner get out and sight for you. If you don't have a partner, you set the parking brake and take a walk around the truck. The pilot knew the airplane had visibility issues, and he knew he would be in crowded environment. It's his responsibility, plain and clear. Oshkosh organizers are fully culpable for not requiring that he observe the simplest safety rule. This isn't something that's limited to aviation. Anytime you have large equipment moving in a crowded environment, you will see extra precautions taken. Anytime a forklift is moving something at the HomeDepot, they'll post two guards to keep people back. It's my opinion that the Oshkosh organizers should be held responsible for criminal negligence, and Uncle Tom should be whipped at high noon for the crude and audacious remark that "this will not detract from the success of the convention." Not the fact that this was allowed to occur, but it was allowed to happen in such a glaringly stupid fashion, without the first modicum of the normal safeguards that you would see at any large convention is a serious black eye on Warbirds, GA aircraft, the EAA, and especially Oshkosh. Whether it is true or no, this just screams to the world that we're all a bunch of reckless yahoos. Most of us aren't, but just try to convince Joe Public of that when the biggest convention of GA aircraft in the world doesn't practice safety measures that would be strictly enforced at the county fair. ---- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
#123
A warbird taxiing behind me in my homebuilt with limited visibility
would be an un-nerving experience indeed. Especially after what just happened. Being that we are the inventors, and constructors we are, I may just construct a whip type mast with a flag on top that the warbird driver can see in front of his face. Like dune buggies use so they can see the next one comming from below the dunes. I could have a mount for it inside, like a fishing pole holder, and just need to figure out how to stow it. (make it telescopic?) Or maybe the EAA could provide them, and hand it to the flagman right before takeoff. Give them to anyone taxiing in front of a warbird. The canopy would have to be back of course to use it, but it's feasable. There's no way to make a small plane in front of a plane like an Avenger visible unless you get something up to where he can see it. I don't trust the all the guys taxiing warbirds. Some have the money, but not the experience to really be safe in the things. But many are plenty experienced. But in an accident like this one, experience may not help you see something that's out of your field of vision. Remember the USAir 737 in LA that landed on top of the Metroliner. They couldn't see it either, and there was no lack of experience there. But some changes need to be made to prevent a repeat type of accident. If you can think of a better idea, post it. On Fri, 11 Aug 2006 05:00:05 GMT, Ernest Christley wrote: And all of it is neither here nor there. I used to drive a big truck, and 18-wheeler as moving van. 18 wheels down through residential neighborhoods. The number one rule was "If you don't know you're clear, you don't move." Period. No guessing. No thinking. No hoping and no wishing. Either you can see you're clear through mirrors or sticking your head out the window, or you have your partner get out and sight for you. If you don't have a partner, you set the parking brake and take a walk around the truck. The pilot knew the airplane had visibility issues, and he knew he would be in crowded environment. It's his responsibility, plain and clear. Oshkosh organizers are fully culpable for not requiring that he observe the simplest safety rule. This isn't something that's limited to aviation. Anytime you have large equipment moving in a crowded environment, you will see extra precautions taken. Anytime a forklift is moving something at the HomeDepot, they'll post two guards to keep people back. It's my opinion that the Oshkosh organizers should be held responsible for criminal negligence, and Uncle Tom should be whipped at high noon for the crude and audacious remark that "this will not detract from the success of the convention." Not the fact that this was allowed to occur, but it was allowed to happen in such a glaringly stupid fashion, without the first modicum of the normal safeguards that you would see at any large convention is a serious black eye on Warbirds, GA aircraft, the EAA, and especially Oshkosh. Whether it is true or no, this just screams to the world that we're all a bunch of reckless yahoos. Most of us aren't, but just try to convince Joe Public of that when the biggest convention of GA aircraft in the world doesn't practice safety measures that would be strictly enforced at the county fair. ---- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
#124
Ron Wanttaja wrote:
Heck, they're $200 a pair just for my Fly Baby.... Speaking of which, I keep seeing Goodyear brake pucks for much (much much much) less than that on the "overstock" webpage of Aircraft Spruce. Thought you might like to know if you didn't already. The downside is you have to pay for shipping on orders under $500 ![]() |
#125
On Fri, 11 Aug 2006 14:49:28 -0500, Jim Carriere
wrote: Ron Wanttaja wrote: Heck, they're $200 a pair just for my Fly Baby.... Speaking of which, I keep seeing Goodyear brake pucks for much (much much much) less than that on the "overstock" webpage of Aircraft Spruce. Thought you might like to know if you didn't already. Yes, thanks...these are the old Barry Jay inventory, which ACS got when they bought the other company out. I had emailed ACS about it...whether it was from my email or not, they did put the old stuff on the web page at the same price Barry Jay had been selling it for. I bought four complete sets about eight months ago. They're not "approved" parts, but neither were my homemade sets (made with brake-pad stock and a router). Installed a set just two weeks ago. Flip out the old outer pad (held with RTV), slip out the thicker, inner pad (no attachment necessary), and reverse the process with the new pads. Took less than five minutes per side (other than jacking the plane up and removing the wheel, of course) and didn't use any tools other than my pocket knife. Ron Wanttaja |
#126
Convair wrote:
But some changes need to be made to prevent a repeat type of accident. If you can think of a better idea, post it. On Fri, 11 Aug 2006 05:00:05 GMT, Ernest Christley wrote: The number one rule was "If you don't know you're clear, you don't move." Either you can see you're clear through mirrors or sticking your head out the window, or you have your partner get out and sight for you. If you don't have a partner, you set the parking brake and take a walk around... This isn't something that's limited to aviation. Anytime you have large equipment moving in a crowded environment, you will see extra precautions taken. Anytime a forklift is moving something at the HomeDepot, they'll post two guards to keep people back. I've repeated myself, just in case you missed it. 8*) A flag on the part of the protagonist moves the responsibility from the antagonist seeing to the protagonist being seen (any time you move your vehicle, you're the antagonist, the mover, the doer, the responsible party). If the Avenger's co-pilot couldn't ride or walk a wing to the run-up area, stick a bug-eye mirror on a stick or out on a wing (temporarily). The solutions are simple, abundant, and in use all around us every day. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
#127
A flag on the part of the protagonist moves the responsibility from the antagonist seeing to the protagonist being seen (any time you move your vehicle, you're the antagonist, the mover, the doer, the responsible party). If the Avenger's co-pilot couldn't ride or walk a wing to the run-up area, stick a bug-eye mirror on a stick or out on a wing (temporarily). The solutions are simple, abundant, and in use all around us every day. With the price and availability of tiny little video cameras and LCD displays, I can't imagine why anyone who could afford to fly a warbird couldn't afford to put a forward-looking video system in place (even if it's only a temporary installtion used for crowded events). It would cost what - $100? - to prevent blind taxiing. Mark Hickey |
#128
Mark Hickey wrote: Ernest Christley wrote: A flag on the part of the protagonist moves the responsibility from the antagonist seeing to the protagonist being seen (any time you move your vehicle, you're the antagonist, the mover, the doer, the responsible party). If the Avenger's co-pilot couldn't ride or walk a wing to the run-up area, stick a bug-eye mirror on a stick or out on a wing (temporarily). The solutions are simple, abundant, and in use all around us every day. With the price and availability of tiny little video cameras and LCD displays, I can't imagine why anyone who could afford to fly a warbird couldn't afford to put a forward-looking video system in place (even if it's only a temporary installtion used for crowded events). It would cost what - $100? - to prevent blind taxiing. Mark Hickey This "solution" requires too much "head buried in the cockpit" to be practical. If the pilot is looking at the screen, he is not paying attention to other things of equal or greater importance happening around him. I like the idea of spotters better. |
#129
ridiculous argument. The person that needs to see the other aircraft
is the one taxiing the plane with his foot on the brake pedals. Spotters, wing walkers, ect.. all involve critical delays. The pilot has to look over to see them, then notice they are saying to stop, and in those few seconds, you could have already hit the other aircraft. Especially if planes are close together in a takeoff line. It would make more sense for a warbird to be required to fall further beind the aircraft in front of him when taxiing, but then you can still have a plane turn in front of the warbird from another taxiway, too close for the pilot to notice, which is what seems to have happened at OSH. On Sat, 12 Aug 2006 03:47:29 GMT, Ernest Christley wrote: A flag on the part of the protagonist moves the responsibility from the antagonist seeing to the protagonist being seen (any time you move your vehicle, you're the antagonist, the mover, the doer, the responsible party). If the Avenger's co-pilot couldn't ride or walk a wing to the run-up area, stick a bug-eye mirror on a stick or out on a wing (temporarily). The solutions are simple, abundant, and in use all around us every day. |
#130
Convair wrote:
but then you can still have a plane turn in front of the warbird from another taxiway, too close for the pilot to notice, which is what seems to have happened at OSH. I think you need to go read the full NTSB preliminary report. |
| Thread Tools | |
| Display Modes | |
| Get Rid Of Warbirds At Oshkosh | RST Engineering | Piloting | 131 | August 11th 06 07:00 AM |
| Oshkosh Reflections | Jay Honeck | Owning | 44 | August 7th 05 03:31 PM |
| Oshkosh Reflections | Jay Honeck | Piloting | 45 | August 7th 05 03:31 PM |
| Oshkosh EAA Warbirds ??? | Paul | Restoration | 0 | July 11th 04 05:17 AM |
| How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 01:05 AM |
