GNS 430 reception problems
Old September 9th 06, 06:29 AM posted to rec.aviation.owning
Default GNS 430 reception problems
On 7-Sep-2006, Kevin Clarke wrote:
When running the recv sensitivity test, the KX drops out much later than
the GNS.
Was the RX sensitivity test done on the bench or in the airplane? How "much
later" (in dB)? If it's more than a few dB then the GNS 430 is probably
defective. There should be a published specification for receive
sensitivity, which will be shown in the Garmin shop service manual if
nowhere else. If what you get, with a bench test, does not meet spec then
troubleshooting needs to move to internal circuitry. Probably best done by
a Garmin authorized repair facility if there is such a thing.
Good luck!
-Elliott Drucker
Old September 9th 06, 08:10 PM posted to rec.aviation.owning
No way the sensitivity difference between the two radios should be 20 dB --
that reflects an incident signal strength difference of 100-fold! If the
Garmin is not defective (and the unit swap seems to confirm this) then the
receive signal is being attenuated by roughly 20 dB someplace. This should
be fairly easy to find using a spectrum analyzer or similar instrument,
again something any avionics shop should have available.
However, I must wonder why your avionics shop isn't going through these
rather obvious diagnostic steps without outside help.
-Elliott Drucker
Garmin 496 loss of satellite reception Dan Luke Piloting 5 August 22nd 06 04:30 PM
GPS Problems near CHD.. Dan Piloting 7 August 7th 06 10:46 PM
GPS Reception Problems with 396 Dan Piloting 16 August 5th 06 04:01 AM
Mooney Engine Problems in Flight Paul Smedshammer Piloting 45 December 18th 04 09:40 AM
And they say the automated Weather Station problems "ASOS" are insignificant because only light aircraft need Weather Observations and forecasts... Roy Piloting 4 July 12th 03 04:03 PM
