Flaps on take-off and landing
Old September 15th 06, 09:54 AM posted to rec.aviation.piloting
Thomas Borchert
Default Flaps on take-off and landing
Ron,
The Cardinal will not fly at gusts of 30 knots - no matter whether the
flaps are down or not.
BULL****. 20G33 was good student solo weather in Colorado where I
learned. We regularly took the Cardinal RG's out in these conditions.
Misunderstanding. See Peter's post.
Thomas Borchert (EDDH)
Old September 17th 06, 02:17 PM posted to rec.aviation.piloting
mike regish
I think he meant that it won't leave the runway once it's down.
mike
"Ron Natalie" wrote in message
m...
Old September 14th 06, 12:56 PM posted to rec.aviation.piloting
Mxsmanic
Thomas Borchert writes:
No. But who cares - you're not flying, you're simming.
The whole idea of simulation is to approach real life, whence the
name.
For landing, you don't want to accidentally touch the wrong switch
while in a hurry on the runway (e.g. the gear switch - happens often).
Your primary concern is to get off the runway. After that, stop and
complete the after landing checklist, which includes flaps.
Do aircraft commonly have mechanisms to prevent gear retraction when
the wheels are touching ground, or is it usually up to the pilot not
to do anything unwise?
Your stall speed is reduced by the flaps by maybe 10 or 20 knots. If
the wind is blowing enough for your stall speed to be a factor - don't
fly.
I was under the impression that full flaps is a normal configuration
for landing; is this not true?
Old September 14th 06, 01:23 PM posted to rec.aviation.piloting
Jim Macklin
Squat switches of some type are common on all retractable
gear airplanes built since WWII. But they can fail for
several reasons.
Some airplanes have a squat switch on only one gear strut,
later models of the same aircraft often added a second squat
switch. A gentle landing with an over-inflated strut might
not compress the strut enough to activate the switch (open)
or a bump can allow the strut to re-extend.
Most gear up landings are just that, the pilot did not put
the gear down. But gear can be retracted while on the
ground if the airplane has the right combination of
"problems" such as over-inflated struts, shorted squat
switches, hydraulic problems, , etc.
"Mxsmanic" wrote in message
whence the
| name.
wrong switch
happens often).
that, stop and
flaps.
retraction when
pilot not
20 knots. If
factor - don't
| fly.
configuration
Old September 14th 06, 01:57 PM posted to rec.aviation.piloting
Roy Smith
name.
Do you guys do simulated ramp checks?
Old September 14th 06, 01:59 PM posted to rec.aviation.piloting
Peter R.
name.
I have read of many sim pilots actually drinking alcohol while they fly,
too.
Peter
Old September 14th 06, 06:41 PM posted to rec.aviation.piloting
B A R R Y[_1_]
too.
Count me as one. I damn near fell out of the chair after too many
Sierra Nevada Pale Ales while flying MSFS.
Old September 14th 06, 03:32 PM posted to rec.aviation.piloting
Mxsmanic
Roy Smith writes:
All sim users are not identical, but it certainly would not surprise
me if some of them are simulating ramp checks, as well as many other
aspects of real-world bureaucracy. Different people are interested in
different aspects of real-world aviation, and simulation generally
allows them to concentrate on the aspects that interest them most,
while letting the rest slide. In theory just about anything can be
simulated.
I personally avoid the paperwork. Sim software itself often makes no
significant provision for paperwork, beyond things like checklists and
the like, so anyone wanting the paperwork side has to pretend on his
own. MSFS allows you to file a "flight plan" for IFR flights and
simulates ATC interaction based on the flight plan, but it doesn't go
much beyond that. Fortunately for me, that's about as far as I'm
interested in going myself. The simulated ATC is limited in what it
can handle and varies from reality in a number of ways, and it
sometimes makes stupid mistakes, but it still enhances realism a great
deal.
Old September 14th 06, 06:40 PM posted to rec.aviation.piloting
B A R R Y[_1_]
How about a simulated IMSAFE or bottle to throttle? G
Old September 14th 06, 06:44 PM posted to rec.aviation.piloting
B A R R Y[_1_]
I wonder if there's a simulated mile high club?
Simulator pilots can pretend to have a date! G
