Are Weak Links really Necessary for Aero Tow?
Old September 17th 06, 08:03 PM posted to rec.aviation.soaring
W.J. \(Bill\) Dean \(U.K.\).
Default Are Weak Links really Necessary for Aero Tow?
Note that the drawing on p.28 of the document referenced by John Smith was
taken from a series of photos taken with a motor drive camera during a
deliberate upset of a Supercub towing a K8 during trials many years ago.
Note that the rope angle to the tug hardly changes.
See http://www.glidingmagazine.com/Featu...cle.asp?id=327 , where Chris
Rollings who was flying the K8 describes what happened. The PA18-180 was
being flown by Brian Spreckley.
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
"John Smith"
wrote in message ...
The document at the following reference may be of interest
- in particular pages 28 - 30
https://www.gliding.co.uk/bgainfo/cl...rotownotes.pdf .
also see my edit re the tow plane diving
At 17:24 17 September 2006, John Smith wrote:
A simple question to all the participants in this thread
- How many off you have actually experienced piloting
a tow plane when the glider has kited behind you?
As a tow pilot who has had it happen at 500 feet agl
and did survive I can state that it is not just the
angle of the rope but also the high loads imposed that
prevent release of the rope by the tow plane. This
affects all types of release. You have a tow plane
'most likely at full power' trying to dive at a steep
angle and a glider virtually winch launching of the back of it - quite a
high loading I can assure you and one that decelerates the tow
plane rapidly. Secondly the upset occurs because of
the upwards load from the glider overcoming the maximum
down load able to be applied at the tow planes tailplane.
This effectively stalls the tailplane in an inverted
sense and the tow plane is actually pitched rapidly
nose down with very little acceleration and indeed
speed. If the rope breaks or releases it is actually
necessary to accelerate the tow plane in its nose down
attitude to gain sufficient speed to pull out of the
nose down attitude.
And NO, I really don't want to experience it again.
With reference to the original question I would strongly
advise the fitting of weak links to all glider tow
ropes regardless of the supposed breaking strength
of the rope used.
PS I do operate at both ends of the tow rope.
Old September 18th 06, 01:45 AM posted to rec.aviation.soaring
Don Johnstone
A very good friend of mine died several years ago in
a tug upset.
He was aero-towing I believe a Ka6 out of a wave site
when turbulence caused the glider to loose sight of
the tug at about 300ft. The glider pilot did not release
and the tug pilot could not as his inertia reel harness
had locked and he was unable to reach the release (conclusion
of the AAIB). The uspet was so bad that the tug was
hanging vertically from the glider before the rope
broke. The resulting dive was irrecoverable and the
pilot died when the tug hit the ground, the glider
pilot of course survived.
I recall fitting a new rear end to a Tiger Moth that
had been used for glider towing, 3 of the four rear
longerons were almost pulled completely apart. None
of the other Tiger Moths, which were not tugs, serviced
by the same organisation had the same problem. Co-incidentaly
the main pilot of the Tiger Moth was the pilot mentioned
above but he was not flying the Tiger in the incident.
The answer to the original poster is, yes they bl00dy
well are, and you would do well to remember it especially
if you are a tuggie.
Glider pilots always seem to survive tug upsets it's
the tuggie that gets it.
At 21:06 17 September 2006, Doug Haluza wrote:
KM wrote:
OK now focus here Doug, the math is not in dispute.
The question is
whether a glider could exert this force while on tow.
If both aircraft are in a steep dive from a high altitude
upset, and
the glider pilot panics and pulls the sitck, it certainly
can. But it
really doesn't matter--using a dockline as a tow rope
means it won't
break before one of the aircraft does.
But what makes you think the dive would be 'Unrecoverable'
just because
the tow plane is past its manurering speed?
The dive after an upset will be unrecoverable as long
as the glider
stays attached to the towplane.
Old September 18th 06, 05:40 PM posted to rec.aviation.soaring
Derek Copeland
The tail loads imposed by a glider during a normal
aero tow are really quite small; probably less than
50lbs. The weak links are only really necessary to
cope with upset situations, or if the rope snags a
tree or power lines on the approach to landing. Obviously
they must break before the tail is damaged, or the
aircraft is slowed down enough to stall in.
Derek Copeland
At 13:36 18 September 2006, Bill Daniels wrote:
Bob's post below is clear and correct.
I would like to add, however, that at least my reading
of accident reports
suggest that a fatal glider accident is more likely
when the towline fails
prematurely. For that reason, I like to stay near
the stronger end of the
FAR 80% - 200% range.
Actually, reading the POH for several German gliders,
I note the weak link
for aerotow is specified as as exact figure. For example,
the weak link for
both aero tow and winch for my Nimbus 2C is specified
as 600 Kg (1323 Lbs)
or a blue Tost weak link. The tolerance is + or -10%.
The US Airworthiness
Certificate specifies that the Nimbus 2C is to be flown
as specified in the
Pilots Handbook (POH). Considering the possible flying
weights, this ranges
between 95% - 160% which is a narrower range than specified
in the FAR's.
Make me wonder if we should be using Tost weak links
instead of old bits of
rope.
Bill Daniels
'RL' wrote in message
This topic is worthy of discussion, so it would be
nice to avoid having
it degenerate into the typical RAS morass. I've flown
at commercial
operations that use large diameter 'tugboat' rope.
The explanation
for this is usually something like, 'Oh well, we put
a knot at the
end that cuts the breaking strength in half', or 'We
can't afford
to keep changing those little skinny ropes...'.
Let's start at the top of the list: Number one - In
the US, FAR
Part 91.309(3) seems crystal clear in terms of requirements
- A
towline (or weaklink) is required to be not less than
80% of max glider
weight and not more than twice the max operating weight.
I am not
aware of any options in the regulations to do something
different. In
fact, if you are doing something different I suspect
the FAA, your
insurance company, or maybe some plaintiff's attorney
might be very
interested should an accident occur.
Doug and Papa3 are right in their assessment and experience
that a
glider can damage a towplane. I've seen an overstress
failure of a
tow hitch which broke and bent parts in the attachment
assembly.
Notwithstanding excess structural loads on the empennage,
the very real
danger is the tow plane running out of pitch control
in the event of a
kiting incident.
I witnessed a kiting accident caused by a glider elevator
misconnect.
The glider climb resembled a winch launch with the
tow plane at 50-100
feet off the ground. The tow rope broke at about the
same time the
towpilot had the stick on the back stop and was pitching
down. This
happened so fast, had the rope not broken as it was
designed to it is
very doubtful the towplane could have either released
or recovered.
There would have most likely been two fatalities that
day if the tow
rope had not been the correct breaking strength.
It would take a foolhardy towpilot to believe: 1)
An over-strength rope
would be legal 2) An over-strength rope could not
cause structural
damage to the towplane 3) The tow pilot could react
quickly enough to
release in a low level kiting incident.
The tow 'system' works with multiple layers of protection
if the
rope is the proper specification.
Bob
Old September 18th 06, 09:31 PM posted to rec.aviation.soaring
Derek Copeland
At 20:18 18 September 2006, Al wrote:
Uh, 'PT3' ?
I know what a PT6 is.
Premature Termination of The Tow (PTTT = PT3)
Derek C
Winch Launch Stresses on Vintage Gliders Mike Schumann Soaring 31 January 30th 06 09:29 PM
Blanik Weak Link for Winch Launch??? Gary Emerson Soaring 6 February 24th 04 08:08 PM
Weak Dollar (Bad News - Good News) JJ Sinclair Soaring 6 January 27th 04 03:06 AM
Aviation Links Nov. 2 DHeitm8612 General Aviation 0 October 31st 03 01:50 PM
