aircraft approach category quandary
Old December 19th 04, 03:33 AM
Ben Jackson
John R. Copeland wrote:
(b) Aircraft approach category means a grouping of aircraft based on a
speed of VREF, if specified, or if VREF is not specified, 1.3 VS0 at the
Continuing beyond what Ron quoted, here's more...
"If it is necessary to maneuver at speeds in excess of the upper limit
of a speed range for a category, the minimums for the next higher
category should be used."
I never understood why they bothered to specify a "book" speed for
approach category when the real rule is that it's based on the speed
that you fly during the approach.
Ben Jackson
http://www.ben.com/
Old December 19th 04, 04:17 AM
John R. Copeland
"Ben Jackson" wrote in message =
news:YL5xd.284746$R05.189455@attbi_s53...
=20
=20
--=20
Ben Jackson
The reason is based in aerodynamics.
1.3 Vs0 is an acceptable approximation to the point of maximum
lift/drag ratio of fixed-wing airfoils on typical small =
general-aviation aircraft.
That makes it a reasonable target for threshold-crossing speed.
Old December 19th 04, 05:41 AM
Ben Jackson
Sure, but the rule doesn't need a number, much less a formula. The rule
is effectively "approach class is based on the speed you fly the approach".
Ben Jackson
http://www.ben.com/
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 04:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 03:31 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 06:15 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 08:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 08:29 PM
