![]() "Ramy" wrote in message oups.com... I think you would get a very different reaction now, that it's been discovered that the sky is not that big after all, not even on a weekday over Minden nor over the remote Amazonas rainforest. I'll be the first one in line to replace my volkslogger with a flarm. The cost should be minimal. Ramy Ramy, I'm not so sure. Mid-air awareness has probably risen some. However, the Minden incident would not have been averted by Flarm, nor would the SA mid-air between two jets. And because of the far flung "wide open spaces" in the US, there are but few places, such as the Whites in NV, where glider density comes close to the Alps (though I've not been there). To make something universally acceptable in the US, if it only works between gliders it'll have to be cheap and small. Such a device would be much better received if it warns of both power and glider threats. The bigger catastrophic risk at Minden is that an airliner and glider will try to occupy the same airspace. Many of us worry about that and transponders seem the best answer for now. -- bumper ZZ (reverse all after @) "Dare to be different . . . circle in sink." Quiet Vent kit & MKII yaw string |
bumper wrote:
To make something universally acceptable in the US, if it only works between gliders it'll have to be cheap and small. Such a device would be much better received if it warns of both power and glider threats. I hope some clever person will modify a Zaon MRX by adding another, perhaps externally mounted, RF "front end" that transmits an ID code and the altitude every few seconds, then listens for other units. The estimated distance (based on the strength of the received signal) of the "threat" is displayed along with the transponder derived "threats". The developer would have to do some reverse engineering on the MRX to gain access to the altitude signal (or just use another pressure sensor) and to mix the info into data stream to the logic/display, but could end up with a small, cheap enough, add-on to the MRX. Ta da! Transponder and glider proximity alerts in (maybe) one small box. Or, a person even more clever might convince Zaon to do it instead. -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
![]() "Eric Greenwell" wrote in message news:U3iXg.5681$ic1.2059@trndny06... bumper wrote: To make something universally acceptable in the US, if it only works between gliders it'll have to be cheap and small. Such a device would be much better received if it warns of both power and glider threats. I hope some clever person will modify a Zaon MRX by adding another, perhaps externally mounted, RF "front end" that transmits an ID code and the altitude every few seconds, then listens for other units. The estimated distance (based on the strength of the received signal) of the "threat" is displayed along with the transponder derived "threats". The developer would have to do some reverse engineering on the MRX to gain access to the altitude signal (or just use another pressure sensor) and to mix the info into data stream to the logic/display, but could end up with a small, cheap enough, add-on to the MRX. Ta da! Transponder and glider proximity alerts in (maybe) one small box. Or, a person even more clever might convince Zaon to do it instead. -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org Or, a "clever" person could design something akin to Garmin's RINO (a GPS that is able to send it's position and/or acquire the position of other nearby units - up to 23 nm in the air). Unfortunately, the FCC did not allow Garmin to program the RINO to send/receive automatically - - one has to push the side button to send position to all other units within range. The "RINO", at $150 US, still remains a useful tool for buddy or team soaring. (RINO will display other units range, bearing, and altitude. When your buddy's info is updated on your display, your unit will "chime" and this reminds you to push the button on your unit to send him your position. It's also possible to "poll" other RINOs within range for their current position - - though this takes more button pushes and so is not so convenient while flying.) Think about it though, if Garmin can use Family Radio Service (FRS or GMRS) band to send / receive position, then why the h__l can't the FCC allow the use of this radio band, even if limited to less power/range, to be used in an automatic position reporting mode. The equipment would be cheap, portable, low-power consuming and would display other threat aircraft on a moving map display w/ GPS altitude. Sounds just like a poor man's ADS-B, but with less range, doesn't it? -- bumper ZZ (reverse all after @) "Dare to be different . . . circle in sink." Quiet Vent kit & MKII Yaw String |
I suspect if these units could transmit in auto mode, the frequency would
become completely unusable. Mike Schumann "bumper" wrote in message ... "Eric Greenwell" wrote in message news:U3iXg.5681$ic1.2059@trndny06... bumper wrote: To make something universally acceptable in the US, if it only works between gliders it'll have to be cheap and small. Such a device would be much better received if it warns of both power and glider threats. I hope some clever person will modify a Zaon MRX by adding another, perhaps externally mounted, RF "front end" that transmits an ID code and the altitude every few seconds, then listens for other units. The estimated distance (based on the strength of the received signal) of the "threat" is displayed along with the transponder derived "threats". The developer would have to do some reverse engineering on the MRX to gain access to the altitude signal (or just use another pressure sensor) and to mix the info into data stream to the logic/display, but could end up with a small, cheap enough, add-on to the MRX. Ta da! Transponder and glider proximity alerts in (maybe) one small box. Or, a person even more clever might convince Zaon to do it instead. -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org Or, a "clever" person could design something akin to Garmin's RINO (a GPS that is able to send it's position and/or acquire the position of other nearby units - up to 23 nm in the air). Unfortunately, the FCC did not allow Garmin to program the RINO to send/receive automatically - - one has to push the side button to send position to all other units within range. The "RINO", at $150 US, still remains a useful tool for buddy or team soaring. (RINO will display other units range, bearing, and altitude. When your buddy's info is updated on your display, your unit will "chime" and this reminds you to push the button on your unit to send him your position. It's also possible to "poll" other RINOs within range for their current position - - though this takes more button pushes and so is not so convenient while flying.) Think about it though, if Garmin can use Family Radio Service (FRS or GMRS) band to send / receive position, then why the h__l can't the FCC allow the use of this radio band, even if limited to less power/range, to be used in an automatic position reporting mode. The equipment would be cheap, portable, low-power consuming and would display other threat aircraft on a moving map display w/ GPS altitude. Sounds just like a poor man's ADS-B, but with less range, doesn't it? -- bumper ZZ (reverse all after @) "Dare to be different . . . circle in sink." Quiet Vent kit & MKII Yaw String |
That sounds just like Flarm, which is available from two manufacturers in
Europe and one in Australia, and has sold about 5,000 units so far. Are you suggesting that the USA re-invent the wheel? W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "bumper" wrote in message ... snip Sounds just like a poor man's ADS-B, but with less range, doesn't it? -- bumper ZZ (reverse all after @) "Dare to be different . . . circle in sink." Quiet Vent kit & MKII Yaw String |
It would make a lot more sense if someone would engineer a low cost ADSB
compliant transceiver that would interface with a PDA. Then eveyone could go nuts developing software that would be able to identify not only gliders but also power aircraft. Once the FAA starts installing the necessary ground equipment, we'll even be able to see Mode C transponder equiped aircraft using the ADSB version of TIS. Mike Schumann "Eric Greenwell" wrote in message news:U3iXg.5681$ic1.2059@trndny06... bumper wrote: To make something universally acceptable in the US, if it only works between gliders it'll have to be cheap and small. Such a device would be much better received if it warns of both power and glider threats. I hope some clever person will modify a Zaon MRX by adding another, perhaps externally mounted, RF "front end" that transmits an ID code and the altitude every few seconds, then listens for other units. The estimated distance (based on the strength of the received signal) of the "threat" is displayed along with the transponder derived "threats". The developer would have to do some reverse engineering on the MRX to gain access to the altitude signal (or just use another pressure sensor) and to mix the info into data stream to the logic/display, but could end up with a small, cheap enough, add-on to the MRX. Ta da! Transponder and glider proximity alerts in (maybe) one small box. Or, a person even more clever might convince Zaon to do it instead. -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Mike Schumann wrote:
It would make a lot more sense if someone would engineer a low cost ADSB compliant transceiver that would interface with a PDA. Then eveyone could go nuts developing software that would be able to identify not only gliders but also power aircraft. Once the FAA starts installing the necessary ground equipment, we'll even be able to see Mode C transponder equiped aircraft using the ADSB version of TIS. The ground equipment is already in place along the east coast from New York down to Florida, Alaska, Oregon, and a few other scattered places. It's much cheaper than upgrading radar equipment, but suffers from the classic chicken and egg problem. In principle, a simple low power ADS-B transceiver (to be precise a UAT) need be no more complicated or expensive to manufacture than a FLARM unit. In practice, however, the certification costs alone are something over a million dollars for a device which currently has a tiny market. If the FAA really wants to kick start use of ADS-B in this country, they need to take a serious look at simplifying or subsidizing the certification process. Marc |
Glider Crash - Minden? | Mitch | Soaring | 141 | September 13th 06 07:31 PM |
FLARM | Robert Hart | Soaring | 50 | March 16th 06 11:20 PM |
Flarm | Mal | Soaring | 4 | October 19th 05 08:44 AM |
Pilot statistics: SSA vs non-SSA | DrJack | Soaring | 6 | March 10th 04 05:55 PM |
Safety statistics | F.L. Whiteley | Soaring | 20 | September 4th 03 05:50 PM |
