Judah writes:
No, that does not accurately reflect the standards for altitude assignment/selection. Unless you only fly West in your sim. Only westbound traffic is assigned thousands? I thought it was odd thousands for 0-179 and even for 180-359, or something like that. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote in
: Judah writes: No, that does not accurately reflect the standards for altitude assignment/selection. Unless you only fly West in your sim. Only westbound traffic is assigned thousands? I thought it was odd thousands for 0-179 and even for 180-359, or something like that. Only westbound traffic is assigned even thousands. But if you already know the rules, why are you asking about them? |
Judah writes:
Only westbound traffic is assigned even thousands. But if you already know the rules, why are you asking about them? If you don't want to answer my questions, don't bother. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Judah writes:
If you're that afraid of flying, you should at least go to a Ground School course. I'm not afraid of flying per se, but I'm extremely wary of GA aircraft and their questionable maintenance records. They are inherently less safe than larger aircraft as well, but not so much so that one need be concerned, provided that they are properly maintained and operated. -- Transpose mxsmanic and gmail to reach me by e-mail. |
"Mxsmanic" wrote in message
I'm not afraid of flying per se, but I'm extremely wary of GA aircraft and their questionable maintenance records. They are inherently less safe than larger aircraft as well Please cite a source for this comment. , but not so much so that one need be concerned, provided that they are properly maintained and operated. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Steve Foley writes:
Please cite a source for this comment. The accident statistics. Just the fact that they use piston engines makes them less reliable, and thus less safe. -- Transpose mxsmanic and gmail to reach me by e-mail. |
... Steve Foley writes: Please cite a source for this comment. The accident statistics. Just the fact that they use piston engines makes them less reliable, and thus less safe. No source, huh? |
![]() Steve Foley wrote: Please cite a source for this comment. Perhaps you want to shoot the messenger, but it is true. Transport catagory aircraft are safer than GA aircraft. Dual load paths, for instance. Many critical loads carried by the airframe are dual load paths, one can actually fail. I think there are only 2 bizjets certified to the older part 25 standards. Before they got watered down. Or was it 23? No I think 25. I am Canadian and not up you your certification standards. But it seems, more-so than you. Bird strike testing. I have seen birds come off the glass of transport aircraft, and pictures of birds entering the cocpits of ga aircraft. Lightning strike protection. Discharge paths, no I am not talking about the static wicks. I have a friend in a large jet that took a hit that would no doubt would blow apart a ga plane. I will simpify this part. One thing that makes turbines safer than pistons. A turbine (okay yes, there are ga turbines now) never flies out of the green arc (30 fps). Many piston operators fly (moonies of course) and decend letting the airspeed build up into the yellow in smooth air. Aside from not beeing painted, but addressing the certification standards, a turbine redline(parber pole) allows for the same gust load tolerance as the top of the yellow arc (15 fps). Pistons are allowed to fly faster such that less of a gust load and break them. Why? Well so they can go faster and be popular? Perhaps. Then this was changed for pistons somewhat but also was the way it was calculated resulting in little change overall. Out of time. I am supposed to be working on something. Cite a source? Ha! Too basic to bother. Get educated. Adding to safety, dual and triple, "this and thats" (technical phrase for things like actuators and means to split controls or disconnect). Plus the way they are required to be operated. I am sure though all this would go out the window if the pilot training was the same as for GA. I think is some parts of the world it is. John |
The Visitor wrote in news:V24%g.172855
: Steve Foley wrote: Please cite a source for this comment. Perhaps you want to shoot the messenger, but it is true. Transport catagory aircraft are safer than GA aircraft. The disturbing comment from Manix is that GA aircraft are less safe because of "their questionable maintenance records." I believe the comment to be innacurate, biased, and inflammatory. |
![]() Judah wrote: The disturbing comment from Manix is that GA aircraft are less safe because of "their questionable maintenance records." Ha! We've seen that applied to large jets too. Remember the seat belt holding the fan blade picutres. About 1990 I went shopping for a 172 (and it kinda grew an extra engine), I found all kinds of aluminium sins. 2000 hour airplanes with foot holes worn in origional carpets. And around the airport I see all kinds of things that shouldn't be happening. Everybody means well enough and much of the mods happening are basically okay but some things that shouldn't happen also. People getting carried away. Then again on the other end, operators would not snag something because they don't have maintenance, and can't do the take off so the part fails in the air and they can continue to the next stop. Design can only do so much, what people do with it trumps all else I guess. |
Rudder for final runway alignment (?) | Mxsmanic | Piloting | 124 | October 2nd 06 09:39 PM |
Piper Altimatic II autopilots - anyone? | nobody | Owning | 12 | February 8th 06 03:38 PM |
DGs and Autopilots | Andrew Gideon | Owning | 11 | April 14th 05 06:04 PM |
Autopilots... failure modes | john smith | Instrument Flight Rules | 14 | October 22nd 04 05:22 AM |
Artificial Horizon/Autopilot Connection | Jay Honeck | Owning | 2 | September 7th 03 05:07 PM |
