"A Lieberma" wrote in message
. 18 Or you can just file an ATC flight plan for VFR flight following. That automatically puts you into the system. Filing VFR flight plan DOES NOT put you in the system. It's only for search and rescue, nothing more. You don't activate the flight plan with ATC, but with FSS on a VFR flight plan. You're both right. ![]() A traditional VFR flight plan is as you describe, but it is also possible to file a flight plan for VFR flight in the ATC system. In fact, this is exactly what happens for every VFR flight in the Washington DC ADIZ. -- John T http://sage1solutions.com/blogs/TknoFlyer Reduce spam. Use Sender Policy Framework: http://openspf.org ____________________ |
On 2006-12-10, A Lieberma wrote:
"Stan Prevost" wrote in : Or you can just file an ATC flight plan for VFR flight following. That automatically puts you into the system. Filing VFR flight plan DOES NOT put you in the system. It's only for search and rescue, nothing more. You don't activate the flight plan with ATC, but with FSS on a VFR flight plan. Allen He did not say to file a VFR flight plan, he said an ATC flight plan for VFR flight following - you check the IFR box, put VFR or VFR/altitude in the altitude box. -Milen |
-----Original Message----- From: Milen Lazarov ] Posted At: Saturday, December 09, 2006 11:23 PM Posted To: rec.aviation.ifr Conversation: Flight Following question Subject: Flight Following question .... He did not say to file a VFR flight plan, he said an ATC flight plan for VFR flight following - you check the IFR box, put VFR or VFR/altitude in the altitude box. -Milen Do you have any quick references for that Milen? I've never heard of an IFR flight plan with "VFR" in the enroute altitude box. Or are you referring to filing VFR-on-top? If so, that's a lot different than just requesting flight following for VFR flights. |
"Jim Carter" wrote in news:000601c71c5c$d669dee0$4b01a8c0@omnibook6100:
Do you have any quick references for that Milen? I've never heard of an IFR flight plan with "VFR" in the enroute altitude box. Or are you referring to filing VFR-on-top? If so, that's a lot different than just requesting flight following for VFR flights. Hey Jim, Did a little research myself and found the following http://72.14.209.104/search?q=cache:...&ct=clnk&cd=13 See 1155 A. Flight planning. Sounds to me that what he is doing is fudging the system by filing an IFR flight plan and annotating it with VFR references in the remarks. I know when you select the IFR box, it does generate a flight strip to ATC, and that would be an IFR filing naturally. Selecting VFR does not generate a flight strip to ATC, nor is a filing with ATC to obtain an ATC clearance. To my knowledge, you don't get clearances on VFR operations EXCEPT for class B entry, take offs and landings. Canada on the other hand does use ATC flight plan for VFR operations. See http://72.14.209.104/search?q=cache:... ct=clnk&cd=1 Allen |
As Milen says, check IFR (it is not an IFR flight plan, that is just a
routing flag for ATC vs FSS), put VFR or VFR/120 for 12,000 feet or whatever your filed altitude is. I also add VFR Flight Following in Remarks to clarify my intent for some controllers who are not very familiar with the practice. I recommend only doing this through DUAT/S, as most FSS personnel are unfamiliar with it. Stan "Jim Carter" wrote in message news:000601c71c5c$d669dee0$4b01a8c0@omnibook6100.. . -----Original Message----- From: Milen Lazarov ] Posted At: Saturday, December 09, 2006 11:23 PM Posted To: rec.aviation.ifr Conversation: Flight Following question Subject: Flight Following question ... He did not say to file a VFR flight plan, he said an ATC flight plan for VFR flight following - you check the IFR box, put VFR or VFR/altitude in the altitude box. -Milen Do you have any quick references for that Milen? I've never heard of an IFR flight plan with "VFR" in the enroute altitude box. Or are you referring to filing VFR-on-top? If so, that's a lot different than just requesting flight following for VFR flights. |
Jim Carter wrote: Do you have any quick references for that Milen? I've never heard of an IFR flight plan with "VFR" in the enroute altitude box. Or are you referring to filing VFR-on-top? If so, that's a lot different than just requesting flight following for VFR flights. OTP is similar but different. OTP is also an altitude you can file but you'll get an IFR clearance. |
On 2006-12-10, Jim Carter wrote:
Do you have any quick references for that Milen? I've never heard of an IFR flight plan with "VFR" in the enroute altitude box. Or are you referring to filing VFR-on-top? If so, that's a lot different than just requesting flight following for VFR flights. No, I'm not referring to VFR-on-top, that would be OTP or OTP/altitude in the altitude box. A quick copy/paste from DUATS: (go to file domestic, click on Cruising altitude) You may also use one of the following additional formats: * OTP (for an IFR flight operating VFR on top) * OTP followed by a slash and a 2 or 3 digit number (i.e., OTP/120) * ABV followed by a slash and a 2 or 3 digit number (i.e., ABV/120) * VFR (for a VFR flight, no specified altitude) * VFR followed by a slash and a 2 or 3 digit number (i.e., VFR/125) * A block altitude may be entered using a low limit 2 or 3 digit number followed by a B, followed by a high limit 2 or 3 digit number. The low limit must be lower than the high limit. For example, enter 120B160 for 12,000 through 16,000 feet. -Milen |
A Lieberma wrote: "Stan Prevost" wrote in : Or you can just file an ATC flight plan for VFR flight following. That automatically puts you into the system. Filing VFR flight plan DOES NOT put you in the system. It's only for search and rescue, nothing more. You don't activate the flight plan with ATC, but with FSS on a VFR flight plan. What he meant was to file an IFR flight plan except to put VFR as the altitude. That would generate a strip just like an IFR aircraft but when you put that transponder code in the data block on the radar scope shows you as a VFR aircraft. |
-----Original Message----- From: Newps ] Posted At: Sunday, December 10, 2006 9:59 AM Posted To: rec.aviation.ifr Conversation: Flight Following question Subject: Flight Following question .... What he meant was to file an IFR flight plan except to put VFR as the altitude. That would generate a strip just like an IFR aircraft but when you put that transponder code in the data block on the radar scope shows you as a VFR aircraft. That's pretty cool. So if I understand correctly now, I can file an IFR flight plan, but specify the enroute altitude as VFR/065 (6500') and that will generate a strip. Can I then call CD and pick up an IFR clearance to VFR enroute with flight following? Since I'm still an analog guy in a digital world and like to talk to the FSS guys on the phone (makes 'em feel needed don't ya know), I've been filing with them. Do you think they will understand how to take this type of flight plan? |
Jim Carter wrote: That's pretty cool. So if I understand correctly now, I can file an IFR flight plan, but specify the enroute altitude as VFR/065 (6500') and that will generate a strip. Can I then call CD and pick up an IFR clearance to VFR enroute with flight following? Just file a regular IFR and pick it up how you normally do. When you get to the point you want to be VFR tell the controller you want to cancel and receive FF. |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| IFR use of handheld GPS | [email protected] | Instrument Flight Rules | 251 | May 19th 06 03:04 PM |
| I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 04:55 AM |
| ramifications of new TSA rules on all non-US and US citizen pilots | paul k. sanchez | Piloting | 19 | September 28th 04 12:49 AM |
| PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 01:14 PM |
