Jack Allison's discussion of the Hartzell AD for his Arrow has gotten me
to thinking. What aircraft do you fly/have you flown/do you have first hand knowledge of which have a red zone somewhere in the green arc of the tachometer? For example, I know there are/were certain models of Cessna 210's that had such markings, but I cannot remember the specific models/engine/prop combinations. |
Jack Allison's discussion of the Hartzell AD for his Arrow has gotten me to thinking.
What aircraft do you fly/have you flown/do you have first hand knowledge of which have a red zone somewhere in the green arc of the tachometer? There was one aircraft I flew (C172? Arrow?) which had a placard to avoid operations between (I think) 2000 and 2200, or something like that. It was not marked as a red zone on the tach though. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
john smith wrote:
Jack Allison's discussion of the Hartzell AD for his Arrow has gotten me to thinking. What aircraft do you fly/have you flown/do you have first hand knowledge of which have a red zone somewhere in the green arc of the tachometer? My club used to have an Arrow-II which had a red arc from (IIRC 2150 - 2300 RPM). Green above and below that. The POH listed only two allowable cruise RPMs: 2100 or 2400, nothing in between. I may be off a little on the actual numeric values. |
Several reasons for a restricted RPM, due to harmonic
vibration...some say not to have prolonged operation in certain RPM ranges, some have a red range in the green arc. I think Lycomng has a FAQ on their engines. "Roy Smith" wrote in message ... | john smith wrote: | Jack Allison's discussion of the Hartzell AD for his Arrow has gotten me | to thinking. | What aircraft do you fly/have you flown/do you have first hand knowledge | of which have a red zone somewhere in the green arc of the tachometer? | | My club used to have an Arrow-II which had a red arc from (IIRC 2150 - 2300 | RPM). Green above and below that. The POH listed only two allowable | cruise RPMs: 2100 or 2400, nothing in between. | | I may be off a little on the actual numeric values. |
C-177B models also had a red zone range
you could feel the vibration in the floor if you were in the "red zone", neat trick for instructors.. Instructor to student: "you feel that vibration" Student: "yes"... Instructor: "Then do something about it" Student: "What should I do? I'm not flying to fast.." Instructor: "You think maybe the engine or prop are trying to tell you something?" Student: "Oh yah.. That red arc" BT "john smith" wrote in message ... Jack Allison's discussion of the Hartzell AD for his Arrow has gotten me to thinking. What aircraft do you fly/have you flown/do you have first hand knowledge of which have a red zone somewhere in the green arc of the tachometer? For example, I know there are/were certain models of Cessna 210's that had such markings, but I cannot remember the specific models/engine/prop combinations. |
Jose wrote:
There was one aircraft I flew (C172? Arrow?) which had a placard to avoid operations between (I think) 2000 and 2200, or something like that. It was not marked as a red zone on the tach though. I'll bet it was the Arrow. I recall seeing the same sort of placard but nothing on the tach, either. -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
"Jim Macklin" wrote in message ... Several reasons for a restricted RPM, due to harmonic vibration...some say not to have prolonged operation in certain RPM ranges, some have a red range in the green arc. I think Lycomng has a FAQ on their engines. The Lockheed Electra sure could have used a prop AD for this one! Dudley Henriques "Roy Smith" wrote in message ... | john smith wrote: | Jack Allison's discussion of the Hartzell AD for his Arrow has gotten me | to thinking. | What aircraft do you fly/have you flown/do you have first hand knowledge | of which have a red zone somewhere in the green arc of the tachometer? | | My club used to have an Arrow-II which had a red arc from (IIRC 2150 - 2300 | RPM). Green above and below that. The POH listed only two allowable | cruise RPMs: 2100 or 2400, nothing in between. | | I may be off a little on the actual numeric values. |
"Dudley Henriques" wrote The Lockheed Electra sure could have used a prop AD for this one! So there was a RPM restriction on the Electra? What do you recall? Didn't a constant speed prop pretty much bypass it? -- Jim in NC |
"Morgans" wrote in message ... "Dudley Henriques" wrote The Lockheed Electra sure could have used a prop AD for this one! So there was a RPM restriction on the Electra? What do you recall? Didn't a constant speed prop pretty much bypass it? -- Jim in NC I only have a vague recall on this. It came up during a safety meeting at the Naval Test Pilots School many years ago. If I remember right, it involved a harmonic mode (whirl I believe) not transmitting correctly through the outboard engine mounts on the airplane. They specified certain conditions that caused this to happen but I don't remember what they were. I seem to recall that after the issue was addressed by Lockheed and the mounts were redesigned, there was a further wing issue as well that had to be dealt with. I think Macklin will probably be the guy who can best deal with exactly what was going on. Dudley Henriques |
| Thread Tools | |
| Display Modes | |
| Verdant green... | Jay Honeck | Piloting | 17 | July 9th 06 07:58 AM |
| Military Green Laser Pointer | [email protected] | Naval Aviation | 0 | July 5th 05 07:42 PM |
| Simple Green Pirep | JJS | Owning | 13 | May 19th 05 04:35 AM |
| I am in The Killing Zone | Marco Rispoli | Piloting | 68 | June 14th 04 06:16 PM |
| Garmin gpsmap 76s airspace zone home made maps (follow up) | Gilles_Sauvagnat | Soaring | 0 | May 13th 04 09:41 PM |
