Jim wrote:
What is the group's take on 91.126 and 91.127? Jim you mean the part about "Unless otherwise authorized or required..." ? --Sylvain |
Several thoughts... I'll line 'em up, let's shoot 'em down...
Publish date for 91.126 seems to be 2004. Was AC90.66A noting "the FAA acknowledges that straight in approaches are not prohibited" published before or after 91.126? IF the AC was issued after 91.126 was ruled, shouldn't 91.126 be amended by now or vise versa? "Otherwise authorized" Obviously a clearance would constitute authorization, what about local authorities such as airport owners, managers, or boards? Jim |
Sorry for responding to my own post, I was attempting to look up AC90.66A,
which I finally found was issued 8/26/1993, prior to 91.126. No school here today and every kid is home playing internet video games. They've got the net slowed to a crawl. Jim |
"Sylvain" wrote in message t... Jim wrote: What is the group's take on 91.126 and 91.127? Jim you mean the part about "Unless otherwise authorized or required..." ? --Sylvain AC90.6A states: e. The FAA encouragesp ilots to use the standard traffic pattern. However, for those pilots who choose to execute a straight-in approach, maneuvering for and execution of the approach should be completed so as not to disrupt the flow of arriving and departing traffic. Therefore,p ilots operating in the traffic pattern should be alert at all times to aircraft executing straight-in approaches. |
Right turn approved on departure.
Jim wrote: What is the group's take on 91.126 and 91.127? Jim |
I recalling hearing somewhere that straight-in approaches are now approved
at uncontrolled airports. Is this correct? As others have told you, it's never been illegal to do a straight-in approach. However, PLEASE try to refrain from doing them when the pattern is full. Not only is it rude, it's often dangerous to attempt when you've got three on downwind, one on base, and one already on final. I see this happen all too often -- almost invariably by the charter guys, who have a paying guy in the back that's late for his meeting -- and it results in frayed nerves and flared tempers. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
"Jay Honeck" wrote in message oups.com... As others have told you, it's never been illegal to do a straight-in approach. However, PLEASE try to refrain from doing them when the pattern is full. Not only is it rude, it's often dangerous to attempt when you've got three on downwind, one on base, and one already on final. I see this happen all too often -- almost invariably by the charter guys, who have a paying guy in the back that's late for his meeting -- and it results in frayed nerves and flared tempers. Simple solution. The straight-in should follow the aircraft on base and the aircraft on downwind alter their patterns to follow the straight-in. |
On Tue, 06 Feb 2007 01:09:56 GMT, "Steven P. McNicoll"
wrote: "Jay Honeck" wrote in message roups.com... As others have told you, it's never been illegal to do a straight-in approach. However, PLEASE try to refrain from doing them when the pattern is full. Not only is it rude, it's often dangerous to attempt when you've got three on downwind, one on base, and one already on final. I see this happen all too often -- almost invariably by the charter guys, who have a paying guy in the back that's late for his meeting -- and it results in frayed nerves and flared tempers. Simple solution. The straight-in should follow the aircraft on base and the aircraft on downwind alter their patterns to follow the straight-in. It's usually not complicated if people are paying attention. If I can fit between sky divers and jump planes at Zypher Hills I should be able to adjust to either have enough room to land and clear the runway ahead of the guy on long final, or extend my down wind to get behind him. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
"Roger" wrote in message ... It's usually not complicated if people are paying attention. If I can fit between sky divers and jump planes at Zypher Hills I should be able to adjust to either have enough room to land and clear the runway ahead of the guy on long final, or extend my down wind to get behind him. 'Zackly. I think many pilots interpret "right-of-way" to mean "the next aircraft to land". That's not what it means. Right-of-way rules come into play only if the aircraft concerned would otherwise occupy the same piece of sky, or nearly so. If you're on downwind when another aircraft announces a long straight-in you should be well in front of him and right-of-way shouldn't be an issue. If he's closer in you may have to extend your downwind a bit to follow him. |
"Steven P. McNicoll" wrote in message hlink.net... 'Zackly. I think many pilots interpret "right-of-way" to mean "the next aircraft to land". That's not what it means. Right-of-way rules come into play only if the aircraft concerned would otherwise occupy the same piece of sky, or nearly so. If you're on downwind when another aircraft announces a long straight-in you should be well in front of him and right-of-way shouldn't be an issue. If he's closer in you may have to extend your downwind a bit to follow him. Maybe, if that were based just on FAR91.113b. Where does "on final" begin? If I'm abeam the numbers on downwind and an inbound calls "...at 3300 feet [pattern altitude] on 15 mile final" for the same runway, can I cut in front of him or not? FAR 91.113b seems tenuous (subjective) while 91.113g seems to explicitly deny me that option. |
| Southern California airports have worst runway safety records | Larry Dighera | Piloting | 0 | November 26th 05 05:48 PM |
| Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 01:56 AM |
| Airports Rated Critical Unsatisfactory: Given Black Star Rating | Michael Ravnitzky | Piloting | 0 | February 3rd 05 04:34 AM |
| IFR hold short line at uncontrolled airports? | Peter R. | Instrument Flight Rules | 30 | June 9th 04 05:47 AM |
| fatal bird strike | StellaStar | Piloting | 9 | July 13th 03 10:41 PM |
