Tweaking the throttle on approach
Old March 4th 07, 04:50 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Tweaking the throttle on approach
Is it normal to constantly fiddle with the throttle on an approach in a small
plane? I find myself frequently making small adjustments on most approaches
(unless I'm coming absolutely arrow-straight into the runway and there's no
wind). From videos I've seen, this happens in real aircraft, too, depending
on conditions. I was under the impression that a steady throttle is ideal,
but perhaps that is hard to achieve in a small aircraft.
I don't have a problem in large jets--they take forever to answer the
throttle, anyway.
Old March 4th 07, 05:18 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
throttle, anyway.
A typical approach in my Cherokee includes at least a few minor power
adjustments after the main power reduction on downwind, abeam the
numbers. They are not usually large, probably +/- 100 rpm. I usually
attribute this to variable wind (speed and direction) between traffic
pattern altitude and ground. Some days, the wind varies considerably
on the way down, and larger, or more frequent power changes are
needed. On those rare wind-free days (i.e., from the surface up to
1000 AGL), I can set power at 1500 rpm on downwind, apply flaps in my
normal places in the pattern, and usually hit the runway nearly where
I want without any power adjustments.
Old March 4th 07, 06:02 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Mxsmanic
writes:
The Baron has a CS prop so I can't watch RPM. I guess I could look at
manifold pressure. However, I've been going mostly by sound to determine how
much power I have applied. What surprises me is that I can tell what changes
to make at all, given that there is no sensation in simulation. But I guess
after a while looking out the window gives me enough clues--as well as
checking instruments, but often I'll adjust power before I see a change in the
instruments.
In some videos I've seen there is constant change in the power setting.
Granted, a lot of these seem to have been on windy days or in mountain
settings.
In big iron I've learned the hard way not to constantly move the throttles
forward and back. I have to just move them a little and be patient. Small
aircraft respond immediately, which is nice (but it spoils you if you like to
fly both aircraft).
I've read about being in a stable configuration on approach and that this is a
Good Thing, but I'm not sure if that applies across the board for all aircraft
and approaches, or just for straight-in approaches, or what. I think it would
be quite a feat to be able to fly a pattern and land without hardly ever
touching the throttles, except perhaps on the kind of windless day that only
occurs in simulators. I can get the aircraft into a stable configuration on
approach if the weather is good and I'm coming straight in, but doing it while
flying a pattern seems unattainably difficult at times.
Old March 5th 07, 02:11 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
I don't know what CS prop guys do, but in my fixed-pitch prop, I
always make my initial power reduction based on RPM, I set it to 1500
and then adjust from there, based on the resulting approach. I
suspect that with a CS prop, some initial RPM/Manifold Pressure
combination is selected.
I have found that flying a normal rectangular pattern in the sim is
significantly more difficult than in real flight. In the real plane,
I compare my actual position to my desired position by frequently
glancing at the desired touchdown point on the runway. I find this
very difficult to do in the sim, I think because of the difficultly in
getting realistic view of the runway from the various legs of the
pattern (?). However, once established on final approach, I think the
sim is quite good in reproducing the sight picture of the approach.
In a light plane, the standard technique is to hold airspeed constant
(usually by trimming to that speed), and then fine tune the flight
path angle with small power adjustments.
But I guess
instruments.
In a normal approach, started from downwind in the traffic pattern,
once the initial power reduction is made, I make the rest of the
approach mostly without looking at the instruments, except for several
checks of airspeed. The descent to the runway is done visually.
Also, don't forget that in the real plane your attention will be
mostly devoted to looking for and avoiding other aircraft.
If you want to be realistic in the sim, then you should try to fly the
traffic pattern for most of your visual approaches. (This includes
instrument approaches to small airports in visual conditions; break
off the approach a few miles out and join the pattern normally.) I
agree about the difficulty of setting up a good approach from the
pattern in the sim. You need to find a set of zero-wind numbers that
works for your sim aircraft, e.g., power setting on downwind, initial
power reduction, time until you turn base, position where flaps are
applied, airspeed on final, etc. (Timing your turn to base may work
better for the sim than the real-life technique of waiting for 45
degrees from touchdown point). You may have to find them by trial and
error, but once you have them, they become your starting point for all
subsequent approaches; fly by those numbers, and then make adjustments
for wind, and other factors of the specific situation.
Old March 5th 07, 04:11 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Mxsmanic
writes:
pattern (?).
I had tremendous trouble seeing the runway for a long time. Finally, when I
got a joystick with a twist axis, I eventually assigned the twist axis to the
pan function in MSFS, so that I can "look" in various directions by twisting
the throttle as I fly. It works pretty good, and I'm better now at patterns
than I used to be. I don't know how much of this modest improvement is due to
practice and how much is due to being able to "turn" my head, though.
Unfortunately I tend to be impatient in the sim and I'm often still not
aligned even as I cross the threshold, unless I planned to land at that
airport well ahead of time. I usually come in fast because I'm making rather
risky turns on the approach and I don't want to come too close to a stall.
In a stabilized approach, though, I'm better.
How do you trim to a speed? Especially when you are adjusting power?
What airspeed do you choose for landing?
Hmm ... I had not thought of working out numbers that I could reuse. Each
approach has been trial and error but I haven't been noting anything. I guess
I'll have to write stuff down (or at least try to remember it). I do have a
few things memorized for the Baron, after hundreds of hours in it, but not as
much as I probably need or could use.
Old March 6th 07, 01:22 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
DR
Default XXX Tweaking the throttle on approach
The benefit of your simulator is that it doesn't destroy the landing
gear on your sloppy landings and that is why it is nothing like real
life. It lets you get away with the most terrible landings... (It always
says excellent landing to me but that's not what my instructor ever says
-and he's right I'd give myself typically 5-8/10). Based on your
extolling the virtues of MSX I recently got the latest version and tried
it out with the aircraft I'm training on. Basically I'd have to say it
simulates a C172 very poorly and I'd say it's only use is for simulated
instrument flying. Even so, it's response does not mimic my aircraft
near the limits of the flight envelope -it behaves like a flying game
really. Red Bull flying race? What a pile!
Mark
Old March 6th 07, 02:16 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
chris[_1_]
Hi, just a couple of notes:
A good landing starts with a good approach. If you don't get your
approach sorted out you are almost certain to stuff the landing up.
A good airspeed for crossing the fence is VSo x 1.3. Find out what
your stall speed is, multiply by 1.3 and you have your speed at short
finals. You can add a bit for the early part of the approach, for a
172 you might use 70-80 kt on approach, reducing to 55 kt on short
finals. Whatever light aircraft you fly will be similar, can't speak
for the heavies though.. If you use much more than 80kt on approach
it can be difficult to get rid of the speed while still descending.
Stall speeds are affected by weight, so if you are heavy the 55kt will
become more like 66kt..
Old March 6th 07, 02:34 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
If not aligned at the threshold in a real plane, you should go around.
You should strive to become aligned with the centerline soon after
turning onto final, and then hold it there. It can be done with
practice. Don't forget you'll need a crab angle to take care of
crosswind.
Don't try to do both at the same time. Hold power constant, and
adjust pitch with the yoke until you are at your desired airspeed,
then apply trim until you can release the yoke without the pitch
attitude (and therefore, airspeed) changing. Then with the airspeed
stabilized, adjust power to change the rate of descent, small changes
in power won't affect your airspeed.
You need the proper speed for your aircraft. If it's not available in
the Pilot's Operating Handbook, then use an old rule of thumb, set the
airspeed equal to 1.3 times the aircraft's stall speed. Your aircraft
should be slowed to this speed by the time you turn final, and then
hold it precisely at that speed. The normal way to hold airspeed is
by trimming to that speed in pitch.
You will not achieve consistent landings until you can fly a
stabilized approach. To do this, you need to discover the numbers for
your aircraft, and then use them. To find them, I suggest you conduct
some experiments in the sim. Set up your aircraft in level flight on
downwind, constant speed, gear down, at 1000 ft AGL, with a medium
power setting. When opposite the numbers, lower your flaps to their
first setting (or 10 deg) and reduce power until you stabilize at a
500 ft/min descent rate with the airspeed at 1.5 times stall speed.
Record the power setting and airspeed. Use those numbers for your
initial descent from the pattern. After 30 seconds, turn base and
lower flaps to the second setting and set pitch for airspeed = 1.4
times stall speed. Then turn final, lower flaps completely, and set
pitch for 1.3 times stall speed. Fly it like this until you hit the
ground. If you land long, then reduce power a little more next time.
If you land short, add a little power next time. Keep iterating until
you zero in on the right numbers.
Old March 6th 07, 03:46 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Jim[_14_]
crosswind.
Excellent advice on all points. Only thing I would add is to use these
steps in basic trainer such as C172 until proficient, as in real life
you must crawl before you can walk. Flying a complex aircraft in
simulation is task intensive and frustrating. Flying the C172 will
allow you to master the fundamentals, then move on to more complex
aircraft. Also to compute the approach speed use the upper limit of
the white arc on the airspeed indicator as the number you use to
multiply by 1.3 to give your final approach speed. As you cross the
numbers cut the throttle and flare. Be careful not to float or balloon
in ground effect. If you do balloon add a bit of power to stabilize
and cut the throttle again and flare to landing. Hope this helps.
Jim in Houston
osPAm
Nurse's creed: Fill what's empty, empty what's full,
and scratch where it itches!! RN does NOT mean Real Nerd!
Old March 6th 07, 04:09 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Kev
On Mar 5, 7:22 pm, DR wrote:
[...] Based on your
A lot of people think FS2004 is better than the latest version,
because it needs less computer horsepower. MSFS is like the Star Trek
movies... every other one is a dog ;-) In any case, download the
RealAir C172, it acts better than the stock version:
http://www.realairsimulations.com/li...page=downloads
Luck! Kev
ID Please - Throttle Quad Orval Fairbairn Restoration 0 December 17th 05 09:35 PM
Throttle movement Max Richter Naval Aviation 12 December 12th 04 12:09 AM
Engine throttle Bob Ingraham Simulators 13 December 11th 04 08:17 PM
Which throttle governer? Garfiel Rotorcraft 1 December 13th 03 05:30 PM
Completing the Non-precision approach as a Visual Approach John Clonts Instrument Flight Rules 45 November 20th 03 06:20 AM
