On Mar 6, 6:15 pm, Mxsmanic wrote:
Jim writes: Excellent advice on all points. Only thing I would add is to use these steps in basic trainer such as C172 until proficient, as in real life you must crawl before you can walk. Flying a complex aircraft in simulation is task intensive and frustrating. Does a Baron 58 count as complex? It seems easy to fly compared to the big iron. It has retractable gear and variable pitch props, means it's complex. Not to mention multi-engine. I fly mostly the Baron 58 as Dreamfleet's simulation is rigorously accurate, so it behaves just like the real thing. The C172 seems too easy, so either this is the world's easiest plane to fly in real life, or the sim is not as accurate as it could be. In real life, I'd want to fly the same thing I had flown in the sim, if I could find a place that would give me instruction in a Baron (a new one, not one of those WWII relics, but without the G1000 junk). You would be very ill-advised to try and start your flight training in a twin. There's way too much stuff to cope with when you're trying to learn how to take off, fly s+l and land.. Best to learn on something small, slow, forgiving, and you can move up later. I found even going from a C152 to an Archer, I got way behind the aircraft - too much happening too fast, and the Archer doesn't have two engines, CSU's or retract. And the difference in cruise is only 35kt or so, but enough to get me seriously behind the aircraft!! Be careful not to float or balloon in ground effect. If you do balloon add a bit of power to stabilize and cut the throttle again and flare to landing. Hope this helps. I do seem to glide excessively just before touchdown. I have a phobia about expensive damage to the gear. I've hardly ever crashed in a way that would injure me in real life, but I've had a fair number of landings in which the gear was damaged (on one occasion I damaged flaps as well, not sure how). If you are floating you are going too fast or trying to hold it off too long. From reading your earlier post, you identified the VSo of the Baron as 75. My research came up with 69-72 as stall speeds. Which makes VSo x1.3 = 89-93kt. You probably don't want to be going for a full stall landing in a twin, so come in at about 90kt, raise the nose a bit to flare and let it settle onto the runway. Don't try and hold it off, that's what a Cessna pilot should do, but probably not a twin pilot. Just make sure your mains touch before your nose wheel. Mind you, I am not a twin pilot so that could all have been rubbish. :-) |
chris wrote:
It has retractable gear and variable pitch props, means it's complex. And flaps...it has to have flaps. Not to mention multi-engine. The number of engines doesn't matter. By the way a twin with two HP wouldn't be HP either. |
On Tue, 06 Mar 2007 16:26:52 -0500, Ron Natalie
wrote: chris wrote: It has retractable gear and variable pitch props, means it's complex. And flaps...it has to have flaps. Not to mention multi-engine. The number of engines doesn't matter. By the way a twin with two HP wouldn't be HP either. or 200 for that matter. Isn't is still "greater than 200"? Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Roger wrote:
On Tue, 06 Mar 2007 16:26:52 -0500, Ron Natalie wrote: chris wrote: It has retractable gear and variable pitch props, means it's complex. And flaps...it has to have flaps. Not to mention multi-engine. The number of engines doesn't matter. By the way a twin with two HP wouldn't be HP either. or 200 for that matter. Isn't is still "greater than 200"? Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com That is high performance - not complex. |
Ron Natalie writes:
And flaps...it has to have flaps. Don't small single-engine planes have flaps? The number of engines doesn't matter. By the way a twin with two HP wouldn't be HP either. High-performance, complex ... when did the FAA set these standards? It must have been when the Wright brothers were around if they are this low. To me, an F-16 is high performance, not a Baron. And a Space Shuttle is complex (or, arguably, a large jet airliner). -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Ron Natalie writes: And flaps...it has to have flaps. Don't small single-engine planes have flaps? The number of engines doesn't matter. By the way a twin with two HP wouldn't be HP either. High-performance, complex ... when did the FAA set these standards? It must have been when the Wright brothers were around if they are this low. To me, an F-16 is high performance, not a Baron. And a Space Shuttle is complex (or, arguably, a large jet airliner). That's because you have no idea what happens in the real world. Compared with ms flight sim on a computer an ultralight is high performance and complex... |
Tim writes:
That's because you have no idea what happens in the real world. Maybe I'm just smarter than a lot of pilots, if they call a Baron "complex" or "high performance." Compared with ms flight sim on a computer an ultralight is high performance and complex... Try it. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Tim writes: That's because you have no idea what happens in the real world. Maybe I'm just smarter than a lot of pilots, if they call a Baron "complex" or "high performance." Maybe. But I don't think that has anything to do with your delusions about being able to fly a real Baron. Compared with ms flight sim on a computer an ultralight is high performance and complex... Try it. I have. It is a nice game. I prefer the real thing though. They have very little in common. |
Tim writes:
But I don't think that has anything to do with your delusions about being able to fly a real Baron. Since it hasn't been tested, we don't know if it's a delusion or not. I have. It is a nice game. I prefer the real thing though. They have very little in common. If so, you haven't configured your sim correctly. -- Transpose mxsmanic and gmail to reach me by e-mail. |
The kindly and greatly respected Uncle Al over on the sci.physics
newsgroup offered an observation as to the intrinsic worth of a poster's contributions that I've taken the liberty paraphrase here, regarding MX's observations re complex aircraft. Not only does he know more than we do, he also knows more than the FAA! Mx is an epiphany of chronic abusive trolling ignorant persona. Mx is a snail-skulled little rabbit. Would that a hawk pick up Mx, drive its beak into Mx's Lilliputian brain, and upon finding it rancid set Mx loose to flutter briefly before spattering the ocean rocks with the frothy pale pink shame of its Ignoble blood. May Mx choke on the queasy, convulsing nausea of his own trite, foolish beliefs. I cannot believe how incredibly ignorant Mx is. I mean rock-hard ignorant. Blazing hot mid-day sun on Mercury ignorant. Surface of Venus under 80 atmospheres of red hot carbon dioxide and sulfuric acid vapor dehydrated for 300 million years rock-hard ignorant. Ignorant so ignorant that it goes way beyond the ignorant we know into a whole different sensorium of ignorant. Mx is trans-ignorant ignorant. Meta-ignorant. Ignorant so collapsed upon itself that it is within its own Schwarzschild radius. Black hole ignorant. Ignorant gotten so dense and massive that no intellect can escape. Singularity ignorant. Mx emits more aviation ignorant/second than our entire galaxy otherwise emits ignorant/year. Quasar ignorant. Nothing else in the universe can be this ignorant. Mx is an oozingly putrescent primordial fragment from the original Big Bang of Ignorant, a pure essence of ignorant so uncontaminated by anything else as to be beyond the laws of physics that define maximally extrapolated hypergeometric n-dimensional backgroundless ignorant as we can imagine it. Mx is Planck ignorant, a quantum foam of ignorant, a vacuum decay of ignorant, a grand unified theory of ignorant. Mx is the epiphany of ignorant. On Mar 7, 12:05 am, Mxsmanic wrote: Ron Natalie writes: And flaps...it has to have flaps. Don't small single-engine planes have flaps? The number of engines doesn't matter. By the way a twin with two HP wouldn't be HP either. High-performance, complex ... when did the FAA set these standards? It must have been when the Wright brothers were around if they are this low. To me, an F-16 is high performance, not a Baron. And a Space Shuttle is complex (or, arguably, a large jet airliner). -- Transpose mxsmanic and gmail to reach me by e-mail. |
| Thread Tools | |
| Display Modes | |
| ID Please - Throttle Quad | Orval Fairbairn | Restoration | 0 | December 17th 05 09:35 PM |
| Throttle movement | Max Richter | Naval Aviation | 12 | December 12th 04 12:09 AM |
| Engine throttle | Bob Ingraham | Simulators | 13 | December 11th 04 08:17 PM |
| Which throttle governer? | Garfiel | Rotorcraft | 1 | December 13th 03 05:30 PM |
| Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 06:20 AM |
