chris writes:
None of the small aircraft I have ever flown has had TCAS.. Are you sure you got that right ??? By "often used," I meant "when present on small aircraft, this is the type usually used," because it's cheaper. I don't think TCAS is really present very much on small GA aircraft, but I don't have actual figures. Since good avionics represent a substantial portion of the total cost of an aircraft, it follows that one wouldn't see advanced avionics that often on aircraft that are not otherwise very expensive. Who would install $2 million of avionics on a $90,000 aircraft? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Oz Lander writes: OK, so TCAS reads transponder codes. I thought it was like a radar. TCAS I (the kind often used on small aircraft) reads Mode C replies from other transponders and builds a picture of the airspace from that, with moderate accuracy. TCAS II (the kind mandated on large aircraft) also listens to other TCAS systems to build a much more accurate picture of the airspace (if lots of other aircraft are similarly equipped). As usual you are wrong again. Try not to base your entire world on your fantasies and guesswork. Very few GA aircraft have any sort of collision avoidance, and I've never seen any with TCAS I. The few that are out there that are transponder based like the Monroy, Zaon, Ryan TCAD, L3/Goodrich Skywatch are all generic traffic avoidance systems. They Skywatch and higher end Avidyne TAS systems can be installed as TCAS I. The TCAS I will send interrogations and it will locate aircraft with more than "moderate" accuracy. You're confusing the lesser PCAS and other traffic avoidance systems with TCAS I. The difference is that TCAS II units talk to other TCAS II units via the mode S datalink to coordinate resolution of conflicts. |
Crash Lander wrote:
"Dan Luke" wrote in message ... How did he see stuff behind him? -- Dan C-172RG at BFM Would it have come up on TCAS? Crash Lander Not unless they've started putting transponders on the space junk. |
| Thread Tools | |
| Display Modes | |
| Why Screeners Miss Guns and Knives (and why pilots miss planes and airports) | cjcampbell | Piloting | 2 | January 3rd 06 05:24 AM |
| Junk Yards | NVArt | Home Built | 5 | July 13th 05 08:35 PM |
| FS Aviation Junk | Jim | Aviation Marketplace | 1 | February 11th 05 11:57 PM |
| Space Junk & GPS Reliability | Doug Carter | Instrument Flight Rules | 9 | July 11th 03 02:38 PM |
| Space Junk & GPS Reliability | Dan R | Piloting | 7 | July 11th 03 02:38 PM |
