Old, but interesting topic
Old March 30th 07, 06:49 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Old, but interesting topic
Sammy writes:
Not in the seat next to them they wouldn't.
He doesn't have to be in the seat next to them.
The fact that it hasn't happened in all these years of aviation makes
it more than just a little unlikely. It's definitely so unlikely it's
silly.
The issue is not whether or not the scenario is silly, but what would actually
happen. In risk management, this type of thought experiment is common and
useful.
Not certified for IIIc means a good chance of hitting the ground so
hard you create a crater or stalling the plane at high speed a few
feet above the ground.
Hardly. It's still a much better bet than having a non-pilot try to land by
hand.
...and runways world wide are STILL being extended to cope with the
A380.
Those extensions may be premature.
There are still notorious approaches around the place.
You don't direct an aircraft with an emergency to a notorious approach.
The unrealistic perfect situation you mention is better called a
fantasy.
Automation such as I have discussed is more the rule than the exception in
airliners.
ATC can't reopen runways for you or make the weather go away.
It doesn't have to.
How does this not apply in an emergency?
In this emergency, there's only one pilot.
You have to do certain things
at certain times and if you can't within the time limit something goes
wrong.
Sometimes. Not all omissions will cause serious problems, though.
If all these things are working perfectly AND if you can instruct the
FMC and other automated systems correctly and in a timely manner.
They routinely work perfectly; they are very reliable (otherwise they would be
of no use). You can carry out the necessary operations easily with a bit of
help.
Takeoff and landing are rarely automated at the moment.
Take-off is rarely automated; landing is from time to time (even in clear
weather). But these are only small parts of a flight. And the part of the
flight that begins when the pilots are incapacitated in this scenario can be
fully automated all the way to touchdown and rollout.
No its not done every day by an untrained person.instructed over a
radio.
That's why such a scenario would be considered an emergency.
The fantasy is that everything goes right just because on this
particular day you have incapacitated pilots and that some janitor can
just be told to press a sequence of buttons to get the plane on the
ground.
Everything would go right, just as it does just about every day. It's
unrealistic to assume that the aircraft would coincidentally fail at the same
time as the pilots are incapacitated.
Old March 30th 07, 08:56 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Sammy
On Mar 30, 3:49 pm, Mxsmanic wrote:
Sammy writes:
Show me your real world data.
silly.
useful.
The issue we were debating was indeed whether or not the scenario was
silly. I do wish you'd actually read what was written instead of
trying to change the target.
If this were considered a significant risk by the risk management
experts of the world, we'd have a standing procedure on what happens
if both pilots are incapacitated just as we have procedures for water
landings etc. I'm not about to ignore the experts and listen to you.
hand.
Again dead is dead. Crashed is crashed. How's it better if a non
certified ILS ploughs you into the ground. I think what you meant to
say is that your chances are better with the non-certified autoland
than with a human non-pilot manually landing. However even then you'd
be wrong because chances are almost 100% it wouldn't be calibrated
well enough. I wouldn't like your odds of survival in either
circumstance.
A380.
Yes again, the experts are wrong and you're right. People are just
throwing away millions of dollars because they're stupid and you're
the one with all the solutions for the world. How old are you? 12?
Ahhhhhh so now you are going to change that set in stone FMC
programming are you? I thought that would never be needed and that the
aircraft would magically continue to a full auto landing almost
unassisted!
fantasy.
airliners.
Another pathetic generalisation. In what part of the world are you
talking? Plenty of countries are running very old aircraft.
It doesn't have to.
Well it does if you don't want to reprogram your final approach.
wrong.
Yes but it only takes one to kill everyone on board.
help.
Failures on aircraft aren't one in a million things. They happen every
day.
weather).
Yes, as I said rarely.
Too bad the small part of the flight we are talking about is landing.
And the part of the
Only in some circumstances.
radio.
Yes, because many emergencies end in disaster.
Repeating yourself again? Have you turned blue yet? See above.
Old March 30th 07, 12:02 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Kev
Hmm. Since indeed very recently an airplane over Greece (?) lost
both pilots, it's definitely not an impossiblie scenario. If there
isn't a procedure in place (and apparently there isn't, since that
plane crashed with a poor flight attendant in the cockpit), why the
heck not?
Even the least imaginative of risk managers should think to have
attendants trained on what to do. If that crash had happened in the
US, there'd have been lawyers all over the place asking the same
question.
Curious,
Kev
Old March 30th 07, 03:17 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Sammy writes:
silly.
No, we were debating whether or not it's possible. And it is possible.
Assessments of silliness are subjective and have no place here.
The absence of a procedure doesn't mean that a given procedure won't work.
How's it better if a non certified ILS ploughs you into the ground.
It is unlikely to do that.
well enough.
How great would the error be, exactly?
No, they simply assume that the A380 will be a reality soon, whereas I do not.
The FMC is not programmed for a notorious approach to begin with.
talking?
All of the developed world now.
One of that gravity is statistically unlikely.
day.
Even engines can run several hundred thousand hours without a failure. And
jet engine cores run even longer than that.
Take-off is the only relevant part here, and it is already in the past when
the non-pilot takes over. Landing can be automated.
In the majority of circumstances.
Most do not.
Old March 30th 07, 03:19 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Kev writes:
heck not?
The Helios accident raises the question of whether or not securing the cockpit
in such a paranoid way is worthwhile. Which is more likely: pilot
incapacitation or hijack? It's an interesting question. If you protect
against one, you leave yourself open to the other.
The Helios flight crashed because nobody could get into the cockpit until the
engines ran out of fuel (which shut down electrical power and unlocked the
cockpit door), by which time it was too late. The flight attendant probably
could have landed the aircraft with radio assistance.
Old March 30th 07, 04:41 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Sammy
Count the number of total crew incapacitations. Count the number of
terrorists hijacks. I think you'll find that there are far more
terrorist hijacks. Securing the cockpit in a paranoid way has other
drawbacks though. I tend to think a lot of the supposed security since
9/11 is "security theatre" - all for show but not hard for a
determined terrorist to get around.
Nope I don't think they could have. If they were used doors that lock
electrically rather the mechanically sound rather like a bad choice to
ward off terrorists.
Old March 30th 07, 05:03 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Sammy
On Mar 31, 12:17 am, Mxsmanic wrote:
Sammy writes:
silly.
You're contradicting yourself again. You just argued the scenario
isn't silly, then argued the debate is subjective and has no place
here. Which is it?
A procedure by definition is a step by step recipe for what to do.
I'll leave you to look it up in the dictionary.
Calibration off by a small tolerance will do that. That's why you have
certifiation for Cat IIIc
well enough.
Great enough that it's considered an unacceptable risk to auto land
unless the equipment is certified.
I'm sorry. The A380 has landed in Sydney airport. That landing
required the runway to be lengthened. I was unaware that it was a
fictitious aircraft and that everyone is hallucinating it.
That's rubbish. You said the FMC is programmed from the start
(Incorrect, the approach is usually input en-route, but never mind).
Now we know that planes do use these notorious approaches. Explain how
the plane lands if the approach isn't programmed in.
talking?
Define developed world. What fraction of the world are you talking
about by population (or by number of flights). I think you'll find a
large portion of the world doesn't operate the way you think.
Absolute rubbish. Take a look at a few air crash reports some time.
day.
They still fail, particularly when you have many thousands of flights
every day and an aging fleet of aircraft.
Landing isn't usually automated. There is no reason to assume that an
autoland is programmed in if a pilot becomes incapacitated. The odds
are very slim that it is. Some portion of the approach may be but even
that's not likely as the pilot will await last minute instructions
from ATC.
Most do not.
Most? That's a statistical statement. Want to provide me with stats on
what proportion of declared emergencies end in loss of life for large
aircraft? Any idea at all what the number is?
Look you hold a bunch of truly bizzare opinions and once stated try to
tell people you've provided facts. They're not facts they're
unsubstantiated supposition. Your world view does not tally with the
majority of accepted evidence, or with what experts report. If you
want me to take you at all seriously you need to provide solid
reference material. You can't do that because many of your weird ideas
are pure and utter fanciful conjecture by someone that thinks if they
can read and form an opinion that replaces real world experience and a
body of solid evidence. Your education has failed you as evidenced by
your inability to argue in a rational manner, and your inability to
substantiate anything you say with any kind of reference. You have
severe issues that I'm not qualified to diagnose or deal with.
Seriously go and get yourself some help. Do you realise how cut snake
crazy you sound?
In the last few weeks you've argued that:
- Checklists are overrated
- Pilots are overqualified and under-skilled
- People with disabilities are an inconvenience, and should get no
special consideration to allow them to remain mobile
- Most people with allergies are just making it up to get attention
- It's possible to learn a complex skill without any practical
experience just by thinking about it. (You're not an ancient Greek by
any chance are you???)
- Any evidence you're shown to contradict your point of view is biased
and therefore wrong
- You don't need to provide evidence for anything you say as it's
simply true
The list goes on and on. All extreme and unconventional points of view
with no support. Honestly it's really sad. You wouldn't know how to
make an argument if one bit you on the behind.
Old March 30th 07, 07:02 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Peter Dohm
cockpit
until the
probably
I did not read anything to suggest that the cockpit door of the Helios 737
was ever locked. Admittedly, I did not see fit to research this incident at
length--and I also am not familiar with Helios procedures.
I do agree that a lot of the recent security initiatives are "security
theater" and I also believe that many have the net effect of reducing our
long term security by reducing our GDP.
The Helios case, however, seems much more interesting as an argument against
fully automated passenger carrying aircraft. Presuming that the report was
correct, regarding the outflow valve being left in manual/open; then there
is further reason to suppose that other flight crews may have found and
corrected similar errors before they became incidents or accidents.
Just a little "food for thought" ...
Old March 30th 07, 07:06 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Mxsmanic wrote in
Sammy writes:
silly.
actually happen. In risk management, this type of thought experiment
is common and useful.
land by hand.
A380.
approach.
How th efjuk woudl you know, ****?
Bertie
Mxsmanic wrote in
Kev writes:
heck not?
cockpit in such a paranoid way is worthwhile. Which is more likely:
pilot incapacitation or hijack? It's an interesting question. If you
protect against one, you leave yourself open to the other.
until the engines ran out of fuel
No, it didn't, moron..
Bertie
Off-topic, but in need of help dennis Aviation Photos 0 January 4th 07 10:40 PM
Almost on topic... Richard Lamb Home Built 22 January 30th 06 06:55 PM
off topic, just a little--maybe? L.D. Home Built 5 August 27th 05 04:56 PM
off topic Randall Robertson Simulators 0 January 2nd 04 01:29 PM
