I have just recently acquired a Garmin 430/WAAS for my Mooney 201. In
practicing approaches to familiarize myself with the unit, I went up with an instructor to get some advice/tips. I had flown a GPS overlay approach (NDB/GPS Runway 5 KLWM, Lawrence MA) previously in VFR conditions and tracked the vertical guidance provided by the GPS and loved it ... very stable approach and no need to dive/level/dive etc. Then I went up with the instructor and did what I thought was a great approach (also NDP/GPS 5 KLWM) and he was upset I didn't fly it more like the "original" non-precision approach by identifying fixes with cross radials and doing the stepdowns. So that is the question. Which technique should be used and why? If I give up the "track the GPS glideslope" approach I feel I'm giving up the advantage of a very stable/controlled approach configuration and not sure what I'm gaining in return. Comments from the experts?? Final questions: With the WAAS GPS on this approach, can I descend to the lower minimum based on identifying the final stepdown fix if I am just flying the GPS's vertical guidance? Where are the answers to these questions provided? |
On Apr 13, 7:26 pm, "Mooney" wrote:
I have just recently acquired a Garmin 430/WAAS for my Mooney 201. In practicing approaches to familiarize myself with the unit, I went up with an instructor to get some advice/tips. I had flown a GPS overlay approach (NDB/GPS Runway 5 KLWM, Lawrence MA) previously in VFR conditions and tracked the vertical guidance provided by the GPS and loved it ... very stable approach and no need to dive/level/dive etc. Then I went up with the instructor and did what I thought was a great approach (also NDP/GPS 5 KLWM) and he was upset I didn't fly it more like the "original" non-precision approach by identifying fixes with cross radials and doing the stepdowns. So that is the question. Which technique should be used and why? If I give up the "track the GPS glideslope" approach I feel I'm giving up the advantage of a very stable/controlled approach configuration and not sure what I'm gaining in return. Comments from the experts?? Final questions: With the WAAS GPS on this approach, can I descend to the lower minimum based on identifying the final stepdown fix if I am just flying the GPS's vertical guidance? Where are the answers to these questions provided? There is no reason you need to use the minimum altitude unless the altitude on the plate has a bar abouve it (meaning max altitude) -robert |
I have a 530W/430W combo recently, and in fact did some RNAV/GPS approaches
tonight. I find it easier to let the autopilot track the GS in LNAV/VNAV approaches rather than dive and drive. It's identical to an ILS- when the DH is reached, then either land or go around. It's probably the same reason why precision approaches with GS are easier to fly than non precision approaches. By the way, tracking the VNAV or LPV glideslope and GPS "localizer" were much smoother than a traditinional ILS or localizer approach. |
On Apr 13, 11:27 pm, "Viperdoc" wrote:
I have a 530W/430W combo recently, and in fact did some RNAV/GPS approaches tonight. I find it easier to let the autopilot track the GS in LNAV/VNAV approaches rather than dive and drive. It's identical to an ILS- when the DH is reached, then either land or go around. It's probably the same reason why precision approaches with GS are easier to fly than non precision approaches. By the way, tracking the VNAV or LPV glideslope and GPS "localizer" were much smoother than a traditinional ILS or localizer approach. I agree that this is easier to just fly the GPS glideslope and my temptation is to just do it that way, but I'm trying to figure out why my instructor is adamant that I use the stepdown process. Can you be confident if you fly the glideslope that you will not violate the minimum altitudes at each stepdown fix? If you are below these BUT ON THE GS are you legal or does the GS have no legal status? More importantly is there any safety issue of just flying the GS? |
On Apr 14, 6:04 am, "Mooney" wrote:
On Apr 13, 11:27 pm, "Viperdoc" wrote: I have a 530W/430W combo recently, and in fact did some RNAV/GPS approaches tonight. I find it easier to let the autopilot track the GS in LNAV/VNAV approaches rather than dive and drive. It's identical to an ILS- when the DH is reached, then either land or go around. It's probably the same reason why precision approaches with GS are easier to fly than non precision approaches. By the way, tracking the VNAV or LPV glideslope and GPS "localizer" were much smoother than a traditinional ILS or localizer approach. I agree that this is easier to just fly the GPS glideslope and my temptation is to just do it that way, but I'm trying to figure out why my instructor is adamant that I use the stepdown process. Can you be confident if you fly the glideslope that you will not violate the minimum altitudes at each stepdown fix? If you are below these BUT ON THE GS are you legal or does the GS have no legal status? More importantly is there any safety issue of just flying the GS? I guess I've done that same with students. Perhaps what he was trying to do was to see how well you can follow the steps (which is much harder/more critical) and you made it too easy by following the GS. -Robert, CFII |
Sometimes step-downs are to clear obstacles. I haven't tried the 430W
yet, but how does the "stabilized approach" deal with this? Is there a variable glideslope? |
On 14 Apr 2007 06:04:57 -0700, "Mooney" wrote:
On Apr 13, 11:27 pm, "Viperdoc" wrote: I have a 530W/430W combo recently, and in fact did some RNAV/GPS approaches tonight. I find it easier to let the autopilot track the GS in LNAV/VNAV approaches rather than dive and drive. It's identical to an ILS- when the DH is reached, then either land or go around. It's probably the same reason why precision approaches with GS are easier to fly than non precision approaches. By the way, tracking the VNAV or LPV glideslope and GPS "localizer" were much smoother than a traditinional ILS or localizer approach. I agree that this is easier to just fly the GPS glideslope and my temptation is to just do it that way, but I'm trying to figure out why my instructor is adamant that I use the stepdown process. Not sure. If you're flying the GPS overlay then the GPS, WAAS or not, is just as valid as the VOR radials for identifying fixes. Can you be confident if you fly the glideslope that you will not violate the minimum altitudes at each stepdown fix? Not unless it's an LPV approach, which none of the approaches to LWM are. The manual says "GPS approaches with vertical guidance may be either LNAV/VNAV or LNAV approaches with advisory vertical guidance. LNAV-only approaches with advisory vertical guidance only have LNAV minima listed on the bottom of the approach plate. The glidepath if typically denoted by a light dashed line on the vertical profile (Jeppesen only) with an associated glidepath angle (usually in the 3.00deg range). These approaches are indicated with "LNAV+V". So, if there is a dashed line on your Jepp chart, then you should be above or at the altitudes at each fix. If you are below these BUT ON THE GS are you legal or does the GS have no legal status? More importantly is there any safety issue of just flying the GS? If you are below the listed altitude for any segment of the approach it's not legal, regardless of how you got there. |
"Peter Clark" wrote in message ...
On 14 Apr 2007 06:04:57 -0700, "Mooney" wrote: Can you be confident if you fly the glideslope that you will not violate the minimum altitudes at each stepdown fix? Not unless it's an LPV approach, which none of the approaches to LWM are. The manual says "GPS approaches with vertical guidance may be either LNAV/VNAV or LNAV approaches with advisory vertical guidance. LNAV-only approaches with advisory vertical guidance only have LNAV minima listed on the bottom of the approach plate. The glidepath if typically denoted by a light dashed line on the vertical profile (Jeppesen only) with an associated glidepath angle (usually in the 3.00deg range). These approaches are indicated with "LNAV+V". So, if there is a dashed line on your Jepp chart, then you should be above or at the altitudes at each fix. If you are below these BUT ON THE GS are you legal or does the GS have no legal status? More importantly is there any safety issue of just flying the GS? If you are below the listed altitude for any segment of the approach it's not legal, regardless of how you got there. Jeppesen says their VNAV depiction meets all altitude restrictions. I don't see a specific restriction to LPV approaches. Here is a small extract from a 2002 Jeppesen Briefing Bulletin at: http://www.jeppesen.com/download/bri...ulletin02C.pdf "VNAV path information illustrates the geometric descent path with a descent angle from the Final Approach Fix (FAF) to the Threshold Crossing Height (TCH). The inclusion of VNAV angles on non-precision approach charts was done on a limited basis. For those non-precision approach procedures for which the State authority did not specify a descent gradient or did not provide a recommended DME/ Altitude table, a descent angle derived from the Jeppesen NavData database is to be shown on the corresponding approach chart. This angle, if used by certified VNAV-capable avionics equipment, will ensure a stable, constant rate of descent clearing all intervening altitude restrictions (step-down fixes) established by the State authority." For the O.P. "Mooney", that says your altitudes will be OK because your 430W is computing vertical guidance from its NavData database. If you find an example where you'd be below the stepdown altitudes, yet "on the glide slope", please post more details here. Jeppesen doesn't seem to expect that to happen. |
Mooney wrote:
I have just recently acquired a Garmin 430/WAAS for my Mooney 201. In practicing approaches to familiarize myself with the unit, I went up with an instructor to get some advice/tips. I had flown a GPS overlay approach (NDB/GPS Runway 5 KLWM, Lawrence MA) previously in VFR conditions and tracked the vertical guidance provided by the GPS and loved it ... very stable approach and no need to dive/level/dive etc. Then I went up with the instructor and did what I thought was a great approach (also NDP/GPS 5 KLWM) and he was upset I didn't fly it more like the "original" non-precision approach by identifying fixes with cross radials and doing the stepdowns. So that is the question. Which technique should be used and why? If I give up the "track the GPS glideslope" approach I feel I'm giving up the advantage of a very stable/controlled approach configuration and not sure what I'm gaining in return. Comments from the experts?? Final questions: With the WAAS GPS on this approach, can I descend to the lower minimum based on identifying the final stepdown fix if I am just flying the GPS's vertical guidance? Where are the answers to these questions provided? Your instructor's logic is probably the argument that if you descend to the next stepdown minimum quickly, say 1000 ft/min, you have a better chance of getting under the clouds sooner than if you go down the glide slope. The other danger is that using the LNAV+V glide slope can lure you into such a steady approach that you forget to level off at the MDA and continue in level flight until the MAP. You cannot stay on the glideslope below MDA unless you have landing aids in sight. |
BillJ wrote: Mooney wrote: I have just recently acquired a Garmin 430/WAAS for my Mooney 201. In practicing approaches to familiarize myself with the unit, I went up with an instructor to get some advice/tips. I had flown a GPS overlay approach (NDB/GPS Runway 5 KLWM, Lawrence MA) previously in VFR conditions and tracked the vertical guidance provided by the GPS and loved it ... very stable approach and no need to dive/level/dive etc. Then I went up with the instructor and did what I thought was a great approach (also NDP/GPS 5 KLWM) and he was upset I didn't fly it more like the "original" non-precision approach by identifying fixes with cross radials and doing the stepdowns. So that is the question. Which technique should be used and why? If I give up the "track the GPS glideslope" approach I feel I'm giving up the advantage of a very stable/controlled approach configuration and not sure what I'm gaining in return. Comments from the experts?? Final questions: With the WAAS GPS on this approach, can I descend to the lower minimum based on identifying the final stepdown fix if I am just flying the GPS's vertical guidance? Where are the answers to these questions provided? Your instructor's logic is probably the argument that if you descend to the next stepdown minimum quickly, say 1000 ft/min, you have a better chance of getting under the clouds sooner than if you go down the glide slope. The other danger is that using the LNAV+V glide slope can lure you into such a steady approach that you forget to level off at the MDA and continue in level flight until the MAP. You cannot stay on the glideslope below MDA unless you have landing aids in sight. More likely, his instructor just isn't up to speed on the new equipment and doesn't understand that there are better ways to do things than the way he learned during his instrument training. Other than wanting to bust some student's balls during training, I can't imagine any reason anybody would ever want to fly a series of stepdowns if a glideslope is available. |
| Thread Tools | |
| Display Modes | |
| Dual glide slope, $95...priceless! | Jack Allison | Owning | 20 | October 22nd 06 04:45 AM |
| Can a failed Glide Slope also void the Localizer approach? | Jim Carter | Instrument Flight Rules | 17 | August 24th 06 10:01 PM |
| Glide Slope Antenna Ground Plane | JKimmel | Home Built | 6 | August 1st 06 02:28 AM |
| En route glide slope? | Andrew Gideon | Piloting | 17 | November 21st 04 06:49 PM |
| Effect of airbrake blade height on glide slope | Mike | Soaring | 1 | January 30th 04 09:24 PM |
