Question to Mxmanic
Old April 20th 07, 06:16 PM posted to rec.aviation.piloting,rec.aviation.student
mike regish
Default Question to Mxmanic
A 60 degree bank produces 2 G's. A 45 degree bank produces 1.414 G's.
mike
"swag" wrote in message
2. the bank angle changes the rate of descent of the wake
So if you are doing a standard rate turn that takes two minutes, you
will not hit youur wake. But if you do a 2g turn (around 45 degrees)
it should take 19 seconds and you will hit your wake.
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 07:39 PM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 02:11 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 02:26 AM
