I own a 1960 Cessna 172 with 2500 hours on the airframe. It is not
rated for aerobatic flight, but the positive and negative G loads that it is approved for far exceed the normal G forces associated with a well-executed barrel roll. Has anyone heard of this maneuver being performed in a 1960 172? |
On May 1, 9:52 pm, gt wrote:
I own a 1960 Cessna 172 with 2500 hours on the airframe. It is not rated for aerobatic flight, but the positive and negative G loads that it is approved for far exceed the normal G forces associated with a well-executed barrel roll. Has anyone heard of this maneuver being performed in a 1960 172? Maybe once... eg Jay Beckman PP-ASEL Chandler, AZ |
gt wrote:
I own a 1960 Cessna 172 with 2500 hours on the airframe. It is not rated for aerobatic flight, but the positive and negative G loads that it is approved for far exceed the normal G forces associated with a well-executed barrel roll. And what happens if you poorly execute one? |
On May 2, 12:52 am, gt wrote:
I own a 1960 Cessna 172 with 2500 hours on the airframe. It is not rated for aerobatic flight, but the positive and negative G loads that it is approved for far exceed the normal G forces associated with a well-executed barrel roll. Has anyone heard of this maneuver being performed in a 1960 172? Almost any aircraft can be rolled whether barrel or aileron. The main concern is to have enough energy (speed) to complete the manuever without falling out of the top of it. The next concern is to have the training and experience to perform the maneuver. I have no doubt that the 172 has been rolled many times by many thousands of pilots. I know one pilot that told me he had rolled everything he flew including the Shorts 360 and the 172. I know another pilot who fell out of the top of a barrel roll in a Vampire jet fighter/trainer and almost crashed. The first pilot had trained in Decathlons and Pitts the second one hadn't. John Dupre' |
John wrote:
Almost any aircraft can be rolled whether barrel or aileron. Well, any fixed-wing aircraft (including, I would guess, most gliders). I suspect you're going to have a hard time rolling an airship or a hot air baloon, however. One of the coolest things I've seen is a helicopter do a roll (at Farnboro airshow). That was amazing. I had always though helicopters were not capable of doing anything like that. |
"Roy Smith" wrote in message ... John wrote: Almost any aircraft can be rolled whether barrel or aileron. Well, any fixed-wing aircraft (including, I would guess, most gliders). I suspect you're going to have a hard time rolling an airship or a hot air baloon, however. One of the coolest things I've seen is a helicopter do a roll (at Farnboro airshow). That was amazing. I had always though helicopters were not capable of doing anything like that. AH-64? |
On 2007-05-01 21:52:46 -0700, gt said:
I own a 1960 Cessna 172 with 2500 hours on the airframe. It is not rated for aerobatic flight, but the positive and negative G loads that it is approved for far exceed the normal G forces associated with a well-executed barrel roll. Has anyone heard of this maneuver being performed in a 1960 172? Of course. However, that does not mean it is legal or smart. The 172 may be able to stand the G forces, but that is not the only limitation. The carburetor only works when right side up, for example. A barrel roll should not be a problem, executed properly, but if you screw it up then you might have some trouble. The 172 is allowed to do spins, but it can be hard on the instruments, knocking them back and forth from stop to stop. For that reason some FBOs insist that spin training be done in other airplanes. I suspect, however, that the real reasons the 172 is not certified for aerobatics is Cessna didn't want the liability, the 172 has a not-very-much-fun roll rate, and sooner or later some pilot would be bound to do them with passengers and no parachutes. Finally, if you are the sort of person who goes out and abuses other people's property and tries to conceal it, I suspect that most of us would not want you renting our planes. -- Waddling Eagle World Famous Flight Instructor |
Roy Smith wrote: One of the coolest things I've seen is a helicopter do a roll (at Farnboro airshow). That was amazing. I had always though helicopters were not capable of doing anything like that. Rigid rotar system. From aging memory... Back in the 1960's, Lockheed built the Cheyenne prototypes, predecessor of today's Apache. It had a rigid rotor system and could fly loops and rolls. The program was cancelled in favor of the cheaper Huey Cobra. The first commercially built helicopter with the rigid rotor system approved for aerobatics is the BO-105, followed by the BK-117, now part of Eurocopter. Those helos have been performing at the big Eurpean airshows since the 1980's. |
In article .com,
gt wrote: I own a 1960 Cessna 172 with 2500 hours on the airframe. It is not rated for aerobatic flight, but the positive and negative G loads that it is approved for far exceed the normal G forces associated with a well-executed barrel roll. Has anyone heard of this maneuver being performed in a 1960 172? Not enough "energy" to be performed in level flight. It can be done in a dive by a competent aerobatic pilot, maintaining airspeed and 1-G loading throughout the maneuver. |
On May 2, 7:18 am, C J Campbell
wrote: On 2007-05-01 21:52:46 -0700, gt said: The 172 may be able to stand the G forces, but that is not the only limitation. The carburetor only works when right side up, for example. A barrel roll should not be a problem, executed properly, but if you screw it up then you might have some trouble. The 172 is allowed to do spins, but it can be hard on the instruments, knocking them back and forth from stop to stop. For that reason some FBOs insist that spin training be done in other airplanes. The main reason most FBO's won't allow us to spin students is because they invest a lot of money in gyros. I think in the "old guy days" instrument rates were not as common and an FBO maybe had one plane for instrument training. Today FBOs want all airplanes available for instrument training (the IR is great money for FBOs, lots of dual and lots of accessories to buy) Finally, if you are the sort of person who goes out and abuses other people's property and tries to conceal it, I suspect that most of us would not want you renting our planes. When gave instruction in the Decathlon the FBO broke off the "reset" knob on the G meter so you can always see what the top and bottom G load had been for the day on the plane. -robert, CFII |
| C172 charter in LA | Timo | Piloting | 15 | January 30th 06 08:20 PM |
| Looking for a nice C172 | Richardt Human | Piloting | 1 | February 12th 05 09:06 PM |
| C172/175/177 diff? | John T | Piloting | 19 | January 24th 05 09:07 PM |
| C172 fuel cap | [email protected] | Owning | 13 | September 25th 04 06:25 AM |
| C172 Air vents | Matt Young | Owning | 8 | July 2nd 04 01:53 PM |
