That is interesting. Does the FAA specify tach vs. oil pressure Hobbs, vs. electric Hobbs? Think of how many pilot logbooks are based on electric Hobbs time. Neither is correct to the letter of the regulation, both are acceptable to the FAA. Pilot time is the real time from the time that the aircraft first moves under its own power for the purpose of flight until it comes to rest at the destination. The oil pressure time is pretty darned close (I assert the aircraft moves forward a tiny bit as soon as the engine starts and isn't really at "rest" until it stops). Unless you leave the master on for a long time in a prolonged preflight, the difference is probably within the tenth of an our accuracy of the unit. For maintenance, it's time in service. Frankly, even putting the hobbs on a gear switch is acceptable to the FAA (saves you some time if you operate out of places like Dulles where you can wait / taxi for a long time before taking off). |
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message
... B A R R Y wrote: Orval Fairbairn wrote: Sometimes, unscrupulous owners will wire the Hobbs to the master switch, so you get charges whenever the MS is ON. My Hobbs is on the master, but the airplane has never been rented. Which brings up a very interesting question. I'm building a plane that will be licensed as an Experimental. Once inspected I'll have to test fly for 40 hours for phase one. If I use a Hobbs as the official time and hook it to the MS I would probably end up reducing the phase one time considerably. Maybe. At what RPM is your tach even with elapsed time? All of the rentals and the only plane I have owned turn the tach faster than elapsed time at higher RPM. (By the way, what do you call the counter thingy in a tach?) My max RPM is 2650. I have to bring it back to around 2350 to be even with elapsed time. That happens to be at the top of a restricted zone so I would never be at an advantage using Hobbs to log flight time unless I spent most of the flight idling around the airport. I happened to do most of my renting from a club that charged by the tach time. Everyone thought that was great - and maybe it was for students who do less cruising - but the tach time was always more than elapsed for my weekend trips. Is there some specficiation or reg as to what RPM equals elapsed time? If you're renting, fly slower. You'll log more hours cheaper. If your test flying, fly faster. You'll chew up more tach time per elapsed hour. ------------------------------- Travis Lake N3094P PWK |
On Jul 2, 12:31 pm, Orval Fairbairn wrote:
In article , B A R R Y wrote: Larry R wrote: Ok, I am *almost* embarrased to ask this question, but here goes. Do Hobbs meters ever "go bad"? Sure, it's a mechanical device. On two occasions over the last few years, my Hobbs has failed to move. For this reason, I always note my tach time and time off. The extra start numbers will help just in case I don't notice for a while that the Hobbs isn't running, and I need to have a fuel consumption figure. Sometimes, unscrupulous owners will wire the Hobbs to the master switch, so you get charges whenever the MS is ON. My hobbs is wired to the master. Am I unscrupulous somehow??? What would be the reason for someone to sit so long with the master on and the engine not running? -Robert |
Robert M. Gary wrote:
My hobbs is wired to the master. Am I unscrupulous somehow??? What would be the reason for someone to sit so long with the master on and the engine not running? Apparently the minute and a half (or less) that it takes you (and I) to do the "electric loop" during preflight is flogging logs. G At least in my case, I flip the switch, check the fuel pressure and guages, do the lights / strobes / pitot heat / stall horn walk-around checks, and turn it back off. That's pretty much it without the engine running. |
On Jul 3, 11:26 am, B A R R Y wrote:
Robert M. Gary wrote: My hobbs is wired to the master. Am I unscrupulous somehow??? What would be the reason for someone to sit so long with the master on and the engine not running? Apparently the minute and a half (or less) that it takes you (and I) to do the "electric loop" during preflight is flogging logs. G At least in my case, I flip the switch, check the fuel pressure and guages, do the lights / strobes / pitot heat / stall horn walk-around checks, and turn it back off. That's pretty much it without the engine running. Yes. even when I'm flying the glass cockpit planes I don't think I have the master on without the engine running for more than a couple of minutes. I don't think it would be a good idea to sit there with the master on for long periods. Seems like the smart FBO would wire the hobbs to the master to prevent people from running the battery for no reason. |
On Tue, 03 Jul 2007 23:32:32 -0000, "Robert M. Gary"
wrote: Seems like the smart FBO would wire the hobbs to the master to prevent people from running the battery for no reason. Even though fuel is used, I actually feel it's beneficial to have the engine running while I pick up clearances, program the GPS, set the radios, etc... On cold days, we get a bit of heat spread around the oil and engine block before I go full throttle for takeoff. On hot days, the spinning prop keeps the cockpit cooler. G I do lean the mixture while ground idling and taxiing, to prevent fouling the plugs. Once the engine is started, I'm rolling within a few minutes. |
Robert
I've set in the parking area with the radio on waiting for an IFR clearance, Big John ************************************************** ***** On Tue, 03 Jul 2007 18:11:27 -0000, "Robert M. Gary" wrote: On Jul 2, 12:31 pm, Orval Fairbairn wrote: In article , B A R R Y wrote: Larry R wrote: Ok, I am *almost* embarrased to ask this question, but here goes. Do Hobbs meters ever "go bad"? Sure, it's a mechanical device. On two occasions over the last few years, my Hobbs has failed to move. For this reason, I always note my tach time and time off. The extra start numbers will help just in case I don't notice for a while that the Hobbs isn't running, and I need to have a fuel consumption figure. Sometimes, unscrupulous owners will wire the Hobbs to the master switch, so you get charges whenever the MS is ON. My hobbs is wired to the master. Am I unscrupulous somehow??? What would be the reason for someone to sit so long with the master on and the engine not running? -Robert |
| Thread Tools | |
| Display Modes | |
| fwd: For Hobbs | Jack | Soaring | 9 | November 26th 06 06:28 AM |
| Hampton Inn Hobbs, NM | Kilo Charlie | Soaring | 5 | July 10th 04 03:03 AM |
| Hobbs Day 5 7-08 # 711. | TomnKeyLargo | Soaring | 2 | July 9th 04 05:14 AM |
| Hobbs Day 2 7-05-04 | TomnKeyLargo | Soaring | 0 | July 6th 04 06:24 AM |
| LS8-18 FS after Hobbs (USA) | SAM AND LEIGH ZIMMERMAN | Soaring | 1 | April 5th 04 01:43 PM |
