I have noticed several older sailplanes with some play in the wings.
They don't seem to pull into the fuselage and have a few thousandths play so that the wings move fore and aft, slightly. Can this be shimmed? I know from working on L-33's that they come from the factory with shims. Is this an acceptable fix for older glass ships? Jack |
The ASW 20 has instructions to nock the fuselage pins
out and put shims behind them to remove slack, apparently to prevent the fuselage fishtailing. The Hornet and Club Libelle i fly both have external shims on the fuselage pins, they would have a lot of slack otherwise. manufacturer maintenace manual should advise Pete At 16:54 02 July 2007, Jack wrote: I have noticed several older sailplanes with some play in the wings. They don't seem to pull into the fuselage and have a few thousandths play so that the wings move fore and aft, slightly. Can this be shimmed? I know from working on L-33's that they come from the factory with shims. Is this an acceptable fix for older glass ships? Jack |
On Jul 2, 12:50 pm, Jack wrote:
I have noticed several older sailplanes with some play in the wings. They don't seem to pull into the fuselage and have a few thousandths play so that the wings move fore and aft, slightly. Can this be shimmed? I know from working on L-33's that they come from the factory with shims. Is this an acceptable fix for older glass ships? Jack Jack, I suppose there's no one answer, as a lot depends on the ship. For example, I've owned gliders from both Grob and LS, and the approach to adjusting out this play was very different. For example, the bushings for the drag spars on the fuselage of the LS8 are threaded and allow some of this play to be removed without additional shims. The Grob Astir had a similar arrangement. P3 |
If you consult the maintenance manuals, you will probably find the maximum
allowable fore-aft and up-down free motion (play). For many gliders these are amazingly large figures. If my Nimbus 2C were at the max tolerance (which it isn't), flight could then be fairly described as a "loose formation of glider parts". Form my point of view, there are two types of 'play'. One is true free motion due to clearances in the fittings. The other involves some stick-slip action that occurs with alarming violence - this is very worrying. Grob 103's are prone to this. The 103's leading edge pins (spigots) actually protrude through the sides of the rear cockpit into the side pockets where the rear seat occupant is likely to be resting elbows. These pins can shift inward with a loud bang numbing the rear pilots arms. Given the complexity of Grob wing fittings, I think very little play should be tolerated. Bill Daniels "Jack" wrote in message oups.com... I have noticed several older sailplanes with some play in the wings. They don't seem to pull into the fuselage and have a few thousandths play so that the wings move fore and aft, slightly. Can this be shimmed? I know from working on L-33's that they come from the factory with shims. Is this an acceptable fix for older glass ships? Jack |
Bill Daniels wrote:
If you consult the maintenance manuals, you will probably find the maximum allowable fore-aft and up-down free motion (play). For many gliders these are amazingly large figures. If my Nimbus 2C were at the max tolerance (which it isn't), flight could then be fairly described as a "loose formation of glider parts". Form my point of view, there are two types of 'play'. One is true free motion due to clearances in the fittings. The other involves some stick-slip action that occurs with alarming violence - this is very worrying. Grob 103's are prone to this. The 103's leading edge pins (spigots) actually protrude through the sides of the rear cockpit into the side pockets where the rear seat occupant is likely to be resting elbows. These pins can shift inward with a loud bang numbing the rear pilots arms. Given the complexity of Grob wing fittings, I think very little play should be tolerated. Bill Daniels "Jack" wrote in message oups.com... I have noticed several older sailplanes with some play in the wings. They don't seem to pull into the fuselage and have a few thousandths play so that the wings move fore and aft, slightly. Can this be shimmed? I know from working on L-33's that they come from the factory with shims. Is this an acceptable fix for older glass ships? Jack My personal general considerations on tolerances and play. There are designed in gaps on most moving assemblies. One that is easy to see is the little bit of vertical freedom in most gliders rudder. This tolerance is generally designed in - although sometimes it is simply production quality or wear. Thing to know is which applies to whatever you are wiggling. So - consider the aircraft gattling gun - it has lots of precision machined parts that rattle around as if they were unable to machine accurately. Take out the gaps, and it would seize solid as pieces expand when it fires. Same principle applies to gliders. If there is excessive free movement in something (i.e.that is not designed to have it) - ground the thing and fix it. If you are not sure if it is excessive, find out - the manuals should have the limits, and if they don't JAR22 or its successors have blanket limits. Consider - the all moving elevator on my Std Cirrus has around 4mm tramline movement. This is considered "good" by the agents given the design of the fitting. Much less and there would be risk of binding at low temperature. If the Kestrel had the same play it would be grounded. From my limited experience I would expect there to be procedures for shimming or replacing the bearing pins on the wings at the leading edge and at the drag spar. This is a critical connection - it should be right. One reason for developing the play on long wings is when misguided or moronic "helpers" manhandle glass ships by the wingtips. This puts very high loads into the pins and they will get loose. |
Peter Thomas wrote: The ASW 20 has instructions to nock the fuselage pins out and put shims behind them to remove slack, apparently to prevent the fuselage fishtailing. The Hornet and Club Libelle i fly both have external shims on the fuselage pins, they would have a lot of slack otherwise. manufacturer maintenace manual should advise Pete I think external shims on Libelles are common. Both my 301 Libelles had shims on the pins. |
Berry wrote:
In article , Peter Thomas wrote: The ASW 20 has instructions to nock the fuselage pins out and put shims behind them to remove slack, apparently to prevent the fuselage fishtailing. The Hornet and Club Libelle i fly both have external shims on the fuselage pins, they would have a lot of slack otherwise. manufacturer maintenace manual should advise Pete I think external shims on Libelles are common. Both my 301 Libelles had shims on the pins. So does my 201. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Bruce wrote:
From my limited experience I would expect there to be procedures for shimming or replacing the bearing pins on the wings at the leading edge and at the drag spar. This is a critical connection - it should be right. One reason for developing the play on long wings is when misguided or moronic "helpers" manhandle glass ships by the wingtips. This puts very high loads into the pins and they will get loose. Does anyone know if there are certification standards for this kind of ground handling force? I see people manhandling the wingtips, but I've never heard of damage as a result, so I suspect the designers expect it and design accordingly. I've carefully avoided that kind of stress, but my Libelle 301 and ASW 20 C still developed audible wing play. My ASH 26 E, with more time than the 301 and 20 combined, has not developed wing play. Go figure. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
ground handling force? I see people manhandling the wingtips, but I've never heard of damage as a result, so I suspect the designers expect it and design accordingly. I believe that FAR23 and JAR22 call for resistance to something like 100 lbs or the equivalent kN applied fore and aft at the wingtip. However, those standards also allow for less resistance if the lower loads can be justified. My guess is that lighter ships like the PW5 are so certified. Thanks, Bob K. |
| Thread Tools | |
| Display Modes | |
| Lets play bust the TFR! | Michelle P | Piloting | 0 | August 20th 06 06:41 PM |
| How not to play nice with a GPS | Roy Smith | Instrument Flight Rules | 11 | August 24th 05 05:16 AM |
| Even fundamentalists like to play. | Tamas Feher | Military Aviation | 0 | April 29th 04 04:55 PM |
