GTX330 programming
Old August 6th 07, 03:35 PM posted to rec.aviation.owning
Gig 601XL Builder
Default GTX330 programming
Kyprianos Biris wrote:
In the Garming GTX330 Transponder how do you disable the FLT ID PWR-
UP ENTRY at start up ?
I have a standard aircraft reg. number and will never need this
feature.
Thanks in advance
I beleive that is your MODE S code. I'm surprised they didn't enter it when
they installed the 330. You so a really easy way to find out what the number
is don't you?
Old August 6th 07, 10:14 PM posted to rec.aviation.owning
Kyprianos Biris[_2_]
No they did enter the Mode S code that was given to us by our CAA.
What it asks for each time is the tail / flight ID code.
Since we do not fly commercial all I need to have there is the aircraft
registration (tail number) and the unit not to ask again for it.
Previous posters covered my question, thank you all.
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message
feature.
Thanks in advance
when they installed the 330. You so a really easy way to find out what the
number is don't you?
Old August 7th 07, 10:38 AM posted to rec.aviation.owning
Thomas Borchert
Kyprianos,
That set-up mode, once you're in there, has some other interesting
options, too.
Thomas Borchert (EDDH)
Thomas Borchert
Gig,
is don't you?
Nope, very important difference. Your aircraft is assigned a hex code which
should be entered by the installing agency only and shouldn't be changed by the
user. However, the S mode data packet also contains one more data field with
either one of two informations: Either the aircraft registration or the flight
number. Obviously, for us lowly GA pilots, we want the aircraft registration in
there and we don't need to change it. It is entered without any dashes some
countries might have in there (e.g. in Germany all registrations start with
D-), so you enter it just like on a flight plan form.
However, if the GTX330 is installed in an airline aircraft, the crew is
supposed to enter the flight number (e.g. UA078) before each flight. You can
set in the set-up menu whether the GTX330 should ask for a flight number every
time after switching it on or not.
Aerodynamics for flight/space simulator programming Timothy Stark Simulators 0 July 8th 07 04:31 AM
Programming $10 Event Radio Paul Dow (Remove Caps in mail address) Piloting 12 August 25th 06 12:20 AM
KLN94 -> GTX330 (GND/ALT switching) Bill Chernoff Instrument Flight Rules 3 June 30th 05 08:36 AM
Interesting consequence of improperly programming GPS route Icebound Piloting 17 June 18th 05 05:29 AM
CNN's post-Cessna-invasion programming Charles O'Rourke Piloting 29 May 14th 05 09:31 PM
