Newps, Thanks.
Newps wrote: Ray Andraka wrote: OK, I have a 496, and an air gizmo mount, which I'd like to put on my panel. I'm curious to the signoffs needed: The Air gizmo I think should be allowed to be installed by the owner/pilot as an interior decoration as long as it doesn't involve drilling or cutting the panel. Correct? If I have to cut the panel or drill holes, do I need an A&P signature? The W&B change is negligible I believe. It is a minor alteration and needs to be signed off by an A&P as such. An owner cannot do that. Drilling or cutting does not affect that. In order to wire the power into the aircraft power (not through a cigar lighter plug), I think I need an A&P signature, and all work has to conform to 43.13, nothing more correct? Yes. One other way to go is to have the A&P wire up a cig lighter plug under the panel where you can't see it. That way when the next latest/greatest comes out you're ready to go. I have two extra cig lighters under the panel. I have one wired directly to the battery so it is always hot, that way I can recharge a cell phone or whatever. The other is wired to come on with the master, that way the GPS fires up automatically. How about running extension wires for the XM USB and remote antenna to the top of the glareshield with the wires behind the panel? I imagine that needs an A&P sign-off if the wires are tie-wrapped into place? No, it wouldn't. OK, and the final question: It looks like in order to fit it in, I'll need to pull the ancient Foster Loran and it's tray out. That's surely going to need somebody's sign-off. Does that have to be pulled by an avionics shop (it does have a connection to the autopilot switch), or can that be done under an A&P's supervision and signature as well? I figure I'll replace the Loran antenna with a comm antenna and leave the end available on the panel for my handheld. An A&P can do that. You can do all the work, just have him look it over and sign it off. He'll have to change the placard on the autopilot switch to reflect that the loran was removed. |
![]() Is your aircraft certified or experimental? Here's an article from AOPA on the subject: http://www.aopa.org/whatsnew/newsite...0201parts.html Don't take panel-mount option out of portable GPS, AOPA tells FAA Think your portable GPS would work great mounted to your old Cessna 172's instrument panel? If the FAA has its way, you won't be able to mount it. The parts — panel dock and connective wiring — needed to mount your portable GPS would either no longer be available or be too expense to buy. The FAA's proposal would make it illegal for manufacturers to produce a replacement or modification part if they know (or should know) the part would end up installed in a certified aircraft — that is unless they obtain production approval from the agency. But that costs tens of thousands of dollars, something many companies can't afford. While AOPA agrees production approval is necessary for critical parts like connecting rods and cylinders, it isn't needed for non-critical parts like a portable GPS panel dock or traffic detector that enhance pilot safety. "This [rule] would basically require any person who manufactures a part, like a light bulb, smoke detector, entertainment system, or other non-critical part that has not been identified as a 'standard or commercial part' to obtain a production approval from the FAA if the part is to be installed in a type-certificated product," Gutierrez said in formal comments opposing the proposed rule. Also under the rule, parts listed on the design approval for one aircraft couldn't be used as a replacement in another aircraft. For example, let's say Cessna installs GE light bulbs in the aircraft's instrument panel and lists the bulb in its design approval. Well, you wouldn't be able to use that same type of light bulb to replace the burned out one in your old Bonanza. These proposals "would substantially increase the cost of general aviation parts and unnecessarily stifle the development and availability of safety and operational enhancement modifications," Gutierrez told the FAA. "AOPA requests that the FAA revise this proposal to ensure that replacement and modification parts remain affordable and available to GA aircraft owners." February 1, 2007 --------------------------------- AOPA's response to FAA NPRM: Docket No. FAA-2006-25877; Notice of Proposed Ruelmaking; Production and Airworthiness Approvals, Part Marking, and Miscellaneous Proposals: http://www.aopa.org/whatsnew/newsite...rts-letter.pdf -------------------------------- Enter docket number 25877 he http://dms.dot.gov/search/searchFormSimple.cfm And you can read the NPRM and comments. -------------------------------- http://www.faa.gov/about/office_org/...M_Briefing.ppt http://search.google.dot.gov/FAA/FAA...ntend&oe=UTF-8 Summary of Proposals 14 CFR Part 45 Continued New Part Marking Requirements Manufacturer & Part Number Req?d Delete ?FAA-PMA? Markings Delete ?installation eligibility? ? PMA Project Status Currently On Track ? NPRM and Implementation Advisory Circulars Available for Comment at http://dms.dot.gov, docket numbers 25877 and 25882 Final Rule to be published by April, 2008 Effective Date of Final Rule is set for October, 2009 --------------------------------- |
Mounting 396 | Paul kgyy | Piloting | 40 | August 24th 07 08:47 AM |
Mounting Cambridge 10 in ASW-19 | jcarlyle | Soaring | 0 | February 27th 06 01:48 PM |
ELT Mounting for an ASW20-C | Papa3 | Soaring | 11 | January 26th 06 06:37 AM |
Mounting my GPS | Charles Talleyrand | Owning | 8 | November 19th 03 11:51 AM |
Mounting my GPS | Charles Talleyrand | Piloting | 8 | November 19th 03 11:51 AM |
