after looking at all the planes in the oshkosh museum, I saw a few
radials where the crank was stationary, and the rest of the engine moved with the prop. which brought me to this question. why did they use radials? some of the first planes used inline engines, nut for some reason radials came into play. |
"Tater" wrote in message
oups.com... after looking at all the planes in the oshkosh museum, I saw a few radials where the crank was stationary, and the rest of the engine moved with the prop. which brought me to this question. why did they use radials? some of the first planes used inline engines, nut for some reason radials came into play. Good cooling with all the cylinders whirling in the breeze. BTW: They are called "rotary" engines - "radials" have stationary cylinders (but are also easier to cool) -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
On Sep 22, 6:02 pm, "Capt. Geoffrey Thorpe" The Sea Hawk at wow way
d0t com wrote: "Tater" wrote in message oups.com... after looking at all the planes in the oshkosh museum, I saw a few radials where the crank was stationary, and the rest of the engine moved with the prop. which brought me to this question. why did they use radials? some of the first planes used inline engines, nut for some reason radials came into play. Good cooling with all the cylinders whirling in the breeze. BTW: They are called "rotary" engines - "radials" have stationary cylinders (but are also easier to cool) -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. Radials have a short, stiff crank, which keeps the weight down. All the cylinders (in a single-row radial) get lots of cooling air. On old airplanes the whole engine was out in the breeze. No cowl, no baffles, no nothing. Light and cheap. Dan |
"Tater" wrote which brought me to this question. why did they use radials? some of the first planes used inline engines, nut for some reason radials came into play. Reasons for widespread use of radials #10 Simplicity #9 Durability #8 Reliability #7 Ease of repair #6 Able to take battle damage without quitting #5 Ease of repair after #6 occurs #4 Weight #3 Weight #2 Weight #1 Savings of all the above Weight -- Jim in NC |
On Sep 23, 11:57 am, Tater wrote:
after looking at all the planes in the oshkosh museum, I saw a few radials where the crank was stationary, and the rest of the engine moved with the prop. An engine with all the clyinders spinning around a stationary crank (and the prop bolted onto the engine) is called a Rotary engine. World-war-one vintage stuff. The main reasons for thier usage in those early times was that the engines of the time were big, inefficient, and rotated slowly, this meant a couple of things, first is that they needed good cooling (esp when the aircraft was on the ground) and second is that a plain radial of the time (rotating crank) would introduce lots of nasty power-pulse vibration due to the slow running and large combustion strokes. With a rotary, the engine itself becomes an *enormous* flywheel which both provides cooling for the cylinders even if the aircraft is stationary, and also smooths out the power. The big disadvantage is you effectively have built a massive gyroscope onto the front of your plane, which radically affects the handling, if you move with the gyro then the effect can be used to your advantage (if it doesn't take you by surprise first!), but that big engine only spins in one direction so moving against the gyro causes some issues. And of course when you open the throttle and the engine starts spinning faster, your whole plane is going to have a very distinct notion to roll over with the engine. As engine technology improved (fairly rapidly), the advantage of a rotary (spinning engine) over a radial (spinning crank) waned and radials took over. Radials are not common in modern aircraft having been surplanted by inline engines, however they do still find favour in certain applications (bush flying for example) due to thier relative simplicity and therefore reliability (if treated right). |
On Sep 22, 6:57 pm, Tater wrote:
after looking at all the planes in the oshkosh museum, I saw a few radials where the crank was stationary, and the rest of the engine moved with the prop. which brought me to this question. why did they use radials? some of the first planes used inline engines, nut for some reason radials came into play. hey, thanks for all the replies, but it brings up one more question..... why don't we use radials now? |
On 26 Sep, 01:30, Tater wrote:
On Sep 22, 6:57 pm, Tater wrote: after looking at all the planes in the oshkosh museum, I saw a few radials where the crank was stationary, and the rest of the engine moved with the prop. which brought me to this question. why did they use radials? some of the first planes used inline engines, nut for some reason radials came into play. hey, thanks for all the replies, but it brings up one more question..... why don't we use radials now? For lower power engines the air cooled flat 4/6 has turned out to be the winner. higher power requirements are best met with a gas turbine. I think that the smallest turbines in widespread use are about 400hp. Smaller ones do exist:- http://www.youtube.com/watch?v=OVxeZYdVRLM http://www.jet-man.com/actuel_eng.html |
why don't we use radials now? Lubrication is a messy business, AIUI. |
Tater wrote in news:1190766611.292026.287600
@g4g2000hsf.googlegroups.com: On Sep 22, 6:57 pm, Tater wrote: after looking at all the planes in the oshkosh museum, I saw a few radials where the crank was stationary, and the rest of the engine moved with the prop. which brought me to this question. why did they use radials? some of the first planes used inline engines, nut for some reason radials came into play. hey, thanks for all the replies, but it brings up one more question..... why don't we use radials now? I do, why don';t you? Bertie |
why don't we use radials now? The large frontal area produces more drag (lower airspeed), and note the statements above about reliability "if treated right". They also limit forward visibility to some extent. Having said that, they are still used a lot. I've heard that one nice thing about radials is instant power response. |
| Thread Tools | |
| Display Modes | |
| Radial GA tires | [email protected] | Owning | 3 | August 2nd 05 05:02 AM |
| Lead Radial Question | Stan Prevost | Instrument Flight Rules | 4 | November 25th 04 07:20 PM |
| radial engine | Randy | Aviation Marketplace | 2 | December 3rd 03 03:28 PM |
