Tim Taylor wrote:
High on Final, Summary Thanks to all that have given input so far. My original intent was to do some modeling before starting the discussion, but this is RAS and it has a life of it's own. So here is the issue. You are high on final and full spoilers are to enough; what do you do? List of options so far: 1. Slip 2. "S" turns 3. Dive until intercepting normal angle for spoilers 4. Dive until near the ground, then decelerate 5. Slow down until intercepting normal angle for spoilers 6. 360 degree turn Unfortunately I still don't have good data for what happens to the polar as speed increases with the spoilers open. Condor was a good suggestion, and I am working to see if I can get meaningful data from it. John Cochrane brought the discussion back to the real point which is what would you use in the real world? It is interesting but not that useful to discuss how you do this at your home airport with 2500 to 9000 feet of runway and know precisely the field elevation. When your aircraft and your own safety are on the line in a real off-field, what are you going to do? What I do must be taken with a grain of salt, because I'm not an instructor, pretty much learned how to deal with field landings by trial and error, have 20 or 30 of them under my belt (5 to 10 in "small" fields), and have yet to do any more damage than scuff up the underside of the nose. First, I *never* fly a normal pattern. I fly directly overhead high enough to make one or more big lazy circles around the field at approach speed, so I can look carefully for fences, wires, rocks, figure out which way the field is sloped, get an idea of the actual wind direction, potential for sink, get a picture of just how high I am above the field, and pick the spot where I plan to touch down. When it becomes clear that I won't be able to make another 360 (and I've found that pretty easy to determine), I shift the circle as needed to approximate an abbreviated downwind, base, and final, and will use spoilers, landing flaps, slips, adjustments to the circle, etc., to get myself into the field as best I can. I never let myself get out of reach or visibility to the touch down point, and keep plenty of energy in case it becomes clear that I need to make a last second shift to a different touch down point (and that has happened more than once). Using this approach, I've never found myself too high or low to land when I commit to final approach... Marc |
Tim Taylor wrote:
So here is the issue. You are high on final and full spoilers aren't enough; what do you do? List of options so far: 1. Slip 2. "S" turns 3. Dive until intercepting normal angle for spoilers 4. Dive until near the ground, then decelerate 5. Slow down until intercepting normal angle for spoilers 6. 360 degree turn Unfortunately I still don't have good data for what happens to the polar as speed increases with the spoilers open. Condor was a good suggestion, and I am working to see if I can get meaningful data from it. John Cochrane brought the discussion back to the real point which is what would you use in the real world? It is interesting but not that useful to discuss how you do this at your home airport with 2500 to 9000 feet of runway and know precisely the field elevation. When your aircraft and your own safety are on the line in a real off-field, what are you going to do? Is there really a need to be on the ground 10 seconds faster than using some of the other techniques? Maybe only if a severe thunderstorm is approaching and you must be on the ground now. Fast approaching weather is a good reason for an "expedited landing", and besides thunderstorms, there gust fronts, snow, rain, and blowing dust. And also other reasons: there are a dozen gliders approaching at high speed to finish a contest task; you want to land before sunset and are still high; you want to land before the tow plane so you don't interfere with the next tow (or have the next tow interfere with your landing); airplanes are holding their takeoff until you land; to fit in between the four airplanes circulating in the pattern doing incessant touch and go's; getting out of the way before the skydivers exit the jump plane. I've done it for all those reasons. Regardless of the need to get down quickly, Option 3, as I use it, is something I do on final after a normal pattern entry. It's not a "get down quicker" technique. snip It is true that sink rate goes up with speed, but the actual decent angle does not go up nearly as much. For my Ventus B at 45 knots descent rate is 122 ft/min while at 135 knots it is 894 ft/ min, but actual loss per nautical mile is 163 ft/ktm verses 397 ft/ ktm. This is not a good comparison, because these numbers are for a "clean" glider, where the major drag at 45 knots is *induced* drag (which reduces as speed increases), at 135 knots the major drag is *parasitic*, and you've gone to negative flaps to reduce drag! With the gear and spoilers out, landing flap selected, the drag will increase more rapidly with speed than for your example, as the drag is significantly parasitic to begin with. The other thing we don't mention is the average pilot going to handle the decision making process better at higher speeds and less time? At stable speeds it takes about 11 seconds to lose 300 feet at 135 knots with the spoilers out verses 22 seconds at 45 knots. These numbers way off: the Ventus (spoilers out) has a 800 fpm sink rate at 45 knots (seems too high), and it is only 1600 fpm at 135 knots (seems too low)? Three times the speed and only double the descent rate? Even clean, the descent rate increased a factor of 7. Ok, lets try a hypothetical (well maybe not, been there done that ;-) off-field landing. snip Slip? Yes, when I had the Std Cirrus (I practiced slips a lot, because it has poor spoilers); no, with the ASW 20 C (slips work fine, however); maybe, in my ASH 26 E (I don't practice them much). "S" turns? Never, at that altitude. Dive until intercepting normal angle for spoilers? Yes, in Ka-6E (got to love those divebrakes!); Yes, in the ASW 20 C (got to love those 40 deg landing flaps!); yes, in the ASH 26 E. Dive until near the ground, and then decelerate? No, Std Cirrus; no, Ka-6e (it will be on glide path well before it gets near the ground); probably won't need to with the 20 C; might be what happens with the ASH 26 E, with it's 8.3 psf wing loading. Slow down until intercepting normal angle for spoilers? Never. 360 degree turn? Never. snip Dive until intercepting normal angle for spoilers? Maybe, but can you dive, lose the altitude, decelerate and get it on the ground for a tail wheel first, full stall landing? As others have pointed out - bad idea. I might be able to manage it the Ka-6e with it's huge spoilers and light wing loading (5 psf); the Cirrus, 20, and 26 would be put on the ground as soon as possible with full air and wheel brakes and some forward stick to give maximum traction. I think the 20 would stop the soonest of these three. snip Summary Each situation is different, but I think we should focus on teaching techniques that are robust and give that average pilot the best opportunity to have a good outcome in an off-field landing. I know of very few off-field landings that start at 1000 feet at the end of down wind. The off-field landing "technique" of turning final at 800' instead of 400' is "robust", in my opinion, and should be one of the things we teach. A lot (majority?) of bad outcomes during an off-airport landing have "too low" when starting the landing pattern as a major factor. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Tim Taylor wrote:
The situation: You are 70 miles from home over unfamiliar territory (read not sure of exact elevation of the terrain below, your altimeter is useless now). You have gone for a Cu over a dry lake bed and it doesn't work. You have selected a landing site in the lake bed that is about 350 feet long and 100 feet wide that looks safe to land. There are tree stumps and other object in other parts of the lakebed. There are no obstructions on the ends of the site so you can do a normal approach. The winds are 15 to 20mph out of the south so you are landing from the north to south. As you drop lower you make a rectangular pattern over the site checking for any missed obstacles. The downwind is fast with the tailwind, as you turn base you estimate you are 400 feet. Your adrenaline is pumping as you prepare for a fairly technical landing. You want to keep it close so that you don't end up short back into the wind and you turn base a little too soon. You are on short final about 350 feet, but about 100 feet over full spoilers decent. What do you do? Tim, We've already screwed up a bunch of things to get ourselves here, but then we may do that from time to time, so: S-turns. In this situation I want more time: to achieve the necessary descent while flying the ship in the way I most frequently fly it--this is not the time for something completely different--even though I can _probably_ do a "360" from that height with a "clean" wing. _Know_ what your configuration is. Gear? Spoilers? If there is any cross-wind, turn into the wind initially, using anything from a 45 to 120 degree turn depending on conditions, but I'll be more comfortable with 60 to 80 degrees; keep the touchdown area in sight; control speed carefully; do not hurry the process; continually assess drift, obstructions, and condition of roll-out space as your vantage point changes while crossing the extended runway centerline. Do not continue maneuvering below a safe altitude. The last 100 feet should look as normal as any you've ever done. If not you've been in too much of a hurry to get to the runway. Just relax and fly around until you get to where everything looks about right again--really, thats what we always do, isn't it? That's why we must be able fly the pattern very comfortably without reference to the altimeter. When airliners need more spacing on final approach, something similar to this method is surprisingly effective without disturbing the customers too much. One more note: if every approach we fly at our home field looks just the same as every other one, we may not be learning enough. Mix it up a little. Where I fly that's rarely a problem, though, and I think that's good for us in the long run. Jack |
On Oct 21, 12:13 pm, Tim Taylor wrote:
[...] It is purely an academic exercise from a safety discussion we had about what are the best steps to follow if you are high on final. I am trying to look at the difference between several suggested techniques if full spoilers are not enough. Since I was a participant in the original discussion, I feel obliged to throw in my $0.02 even though the thread has been hijacked. Truth in advertising: while I am a CFI-G, the vast majority of my dual given has been in powered airplanes. First, Tim's method works for him and probably for many other pilots. This does not mean that it works for all pilots, or even most pilots. By analogy, some maneuvers might be a piece-of-cake for a proficient aerobatic pilot (that would not be me) but deadly for others. The low airspeed drag-it-in kind of approach that some have advocated for power planes falls into this category. One of the skills an instructor must bring to the table is the ability to figure out what approach is best for the student and teach that. The aerodynamics of Tim's maneuver - slow down and get on the "back side" of the polar - mean that the plane has lost both potential and kinetic energy. The two methods lose comparable amounts of potential energy, so the loss of kinetic energy is significant. Loss of kinetic energy also means loss of maneuverability in all axes, due to reduced airflow over the control surfaces. So, a glider that has slowed and hits big sink will take longer to recover than one with a higher airspeed, due to reduced elevator effectiveness. Also, the slower glider is just a few knots above stall, so a rather small wind shear (headwind-to-tailwind) will lead to a stall and more loss of altitude. For this reason alone I would be uncomfortable teaching it to new pilots. |
Frightening! That you would slow down to decrease
forward motion. What happens with downdrafts or wind shear after you have given up the option for altitude that speed gives you. Forward slip in glass gliders won't get you much descent; S-turns might eat up a good bit, but the high-parasitic drag approach is a much more valuable tool. Get about 4000ft agl near the pattern, open full spoilers, and push over to about 70-80kts. When you've burnt off 1000ft, lift the nose to the horizon until speed drops to best l/d and then close the spoilers. You will see that this is not a ballistic maneuver and that it is completely controllable. I'm not sure a speed curve for full divebrakes is needed; you can eyeball this and make it come out right. Either find an instructor who can demonstrate for you, or else do it several times at altitude and when comfortable practice it at lower altitude and on final. In the latter situation you might do just a few seconds to see how entry and recovery look and behave. There is more probability of undershooting than overshooting, in my experience, but you'll be aware that these are about to happen before they become a serious problem. I do these on BFRs routinely into a 2400ft strip. Remember, you can break this off at any time, so you don't have to give up options. At 18:18 21 October 2007, Tim Taylor wrote: LOL, thanks. It is purely an academic exercise from a safety discussion we had about what are the best steps to follow if you are high on final. I am trying to look at the difference between several suggested techniques if full spoilers are not enough. My list of preferences is: 1. Full spoilers 2. add forward slip 3. add 'S' turns I have used the technique of slowing down to minimize forward speed, increase sink and decrease glide angle. Others have suggested increasing speed to increase drag. I am not a big fan of this technique because I feel it minimizes options for the pilot and is susceptible to pilot error that can end up in over shooting the LZ. Last years article in soaring I believe confirms my feeling that this is a technique that should not be held up as one of the primary techniques that should be used. I am working on developing models to asses each in terms of effectiveness, time required, safety and options left to the pilot. Tim |
On 22 Oct 2007 16:12:47 GMT, Nyal Williams
wrote: Forward slip in glass gliders won't get you much descent; I'm not sure about that - the glass gliders that I have tried forward slips with usually got really huge descent rates. A few examples: ASK-21, G-103, ASW-24: Sideslip very effective DG-300, DG-505: Sideslip extremely effective AS22-2: Sideslip pretty effective Bye Andreas |
On Oct 22, 10:12 am, Nyal Williams
wrote: Frightening! That you would slow down to decrease forward motion. What happens with downdrafts or wind shear after you have given up the option for altitude that speed gives you. snip Frightening? Really? It actually works very well with a bit of head wind. Backcountry power pilots occasionally use this technique as well. It could be "Frightening" on a normal approach but remember the context. A Downdraft or Windshear would be welcomed as the whole point is to lose altitude. It does requires some expertise in slow flight and stall awareness. But then glider pilots or at least soaring pilots are supposed to be the experts at slow flight. Once you get down close to a normal approach angle simply accelerate (which will bleed off some more altitude) to your normal approach speed and fly the remaining part of the approach normally. In fact it is necessary that at about 200 feet AGL or higher that you do accelerate to a normal approach speed so that you will have enough energy to flare with. I would strongly recommend practicing it with an instructor and in the specific airplane before having to use it. Usually with gliders there are other, as good, or better options to this technique. Brian |
Brian wrote:
Frightening? Really? It actually works very well with a bit of head wind. Backcountry power pilots occasionally use this technique as well. It's a completely different thing in a power plane. (Although I wouldn't recommend it with power planes, either.) A short look at a typical glider polar is all that is needed to understand why your "technique" is a no-no. If you continue using it, then it's only a question of time that we'll hear about you in the news. |
On Oct 22, 3:33 pm, John Smith wrote:
Brian wrote: Frightening? Really? It actually works very well with a bit of head wind. Backcountry power pilots occasionally use this technique as well. It's a completely different thing in a power plane. (Although I wouldn't recommend it with power planes, either.) A short look at a typical glider polar is all that is needed to understand why your "technique" is a no-no. If you continue using it, then it's only a question of time that we'll hear about you in the news. Looking at a polar is exactly why it works. It is called Speed to fly. It really only works well when you have some headwind. It does work somewhat in calm conditions but is really not very effective. It probably doesn't work at all in a tailwind condition. As noted gliders usually have a better ways of dealing with being high. And since most people aren't excessivly high with a headwind it does have limited use in gliders. There are really only two things that can go wrong with using the technique and both should be easily controllable. These are a Stall/Spin or continuing the slow approach to too low of altitude to recover back to a normal approach speed. Personally I seldom use it, The High Parasitic Drag approach and/or Slips described above is usually more effective in a wider range of conditions. Brian |
Brian wrote:
Looking at a polar is exactly why it works. It is called Speed to fly. It really only works well when you have some headwind. It does work somewhat in calm conditions but is really not very effective. It probably doesn't work at all in a tailwind condition. First I thought that you were pulling our legs, but it seems you're actually serious. Every year a couple of pilots die because they are too slow on approach. Where I fly, a student will fail his checkride big time if he's only one knot below the yellow triangle on final. *Especially* with a headwind. If you don't understand this, I *strongly* recommend you talk to a knowledgeble instructor. |
MA-8 with parachute extended S63-00693.jpg | [email protected] | Aviation Photos | 0 | April 10th 07 02:52 PM |
spoilers vs. ailerons | [email protected] | Piloting | 36 | August 8th 05 11:24 AM |
Frozen spoilers | stephanevdv | Soaring | 0 | November 4th 04 05:24 PM |
Extended GPX Schema | Paul Tomblin | Products | 0 | September 25th 04 02:44 AM |
L-13 Spoilers | Scott | Soaring | 2 | August 27th 03 06:08 AM |
