What am I looking for?
Old November 4th 07, 02:48 AM posted to rec.aviation.soaring
kirk.stant
Default What am I looking for?
I have a couple of times and couldn't see a thing, I could only verify
by feel and tugging on the flaperons. I often see owners with
inspection mirrors peeking inside. If I remember correctly, the
connection is somewhere behind the spar, is there a trick to seeing it?
No trick, seriously:
You just reach in and hook them up by feel - one hand on the
connector, and other hand on the control (stick or dive brake) to move
to the right position to snap in place. Verify the ball is in the
socket, then screw the safety all the way on. THEN: Look through the
opening and you can see all 4 connections, directly and on the mirrors
installed by LS behind them. Sleeves are color coded to show if they
are not correctly hooked up.
No additional inspection mirrors needed, since they are already
installed in the ship!
I really fail to see how it could be any easier - except of course,
automatic hookups a la LS6-c...
Beyond that, the fact that I know two very experienced long term LS6
owners who managed to screw up that connection is the main reason I shy
away from them...
In the above sentence, replace LS6 with just about any glider,
including those with automatic hookups, and it will still be true.
Anything mechanical can fail or be mishandled...
Anyway, I hope you like your ship, cuz I love mine!
Kirk
Old November 4th 07, 03:19 AM posted to rec.aviation.soaring
Tony Verhulst
socket,
Right, that's what I do on my 6b.
Before I do that, I try to pull the connections apart (thanks to Dave
Nadler for that suggestion).
Tony V. LS6-b "6N"
Old November 3rd 07, 12:39 AM posted to rec.aviation.soaring
Mark Dickson
There are plenty of very good gliders that don't have
self-connecting controls, don't let that put you off
buying them; unless you think you are the sort of idiot
that will take-off without having the connections checked.
At 02:48 02 November 2007, Waduino wrote:
What's the solution to this question?
What's a good first glider for someone transitioning
from a CS77 and
wanting the following:
- automatic hookups
- easy to rig
- flaps
- well behaved in terms of stall/spin, and
- climbs well in weak conditions and runs reasonably
well in average
east coast conditions
Budget? Say 20-60k US, depending whether I go alone
or with 1 or 2
partners.
Thanks.
Wad.
Old November 3rd 07, 01:06 AM posted to rec.aviation.soaring
Unfortunately relying on being less of an idiot than others does not
always seem to work as a safety approach. :-(
So personally I had automatic control hookups on my requirement list
in my early glider purchase decisions.
On the other hand what is it with people still not doing positive
control checks. On any glider manual or automatic hookup (and I am
aware of incidents with failure of automatic hookups). I threatened
not to run one guys wing earlier this season because he had not done a
positive check and instead was standing around chatting to people
waiting for a tow - and he was about to tow a matter of a few hundred
feet from where somebody had been killed a few years ago from guess
what... not having controls connected.
Sigh.
Darryl
On Nov 2, 5:39 pm, Mark Dickson
from a CS77 and
- automatic hookups
- easy to rig
- flaps
well in average
or with 1 or 2
partners.
Thanks.
Wad.
Old November 3rd 07, 02:14 AM posted to rec.aviation.soaring
rlovinggood
Wad,
I'm surprised nobody's mentioned the LS8. I don't know market value
on this ship right now, but I would imagine a used "straight 8", i.e.,
15m wingspan only and not the 15/18m version, might be had for $60k.
Well, maybe not. These are still competitive ships. Damned good
ones, too. They have automatic connections, assemble very easily, and
go VERY WELL.
Wings seem a bit heavy (I'm the guy out on the tips, so I know the
wings are heavier than ASW-20C, Discus CS, ASW-24, Standard Cirrus,
LS1-f, and Libelle 301. These are the other ships at my club that I
get to help assemble.) But the LS8 goes together so quickly that I
don't have to hold them very long.
So, I would definitely add the LS8 to your list.
Ray Lovinggood
Carrboro, North Carolina, USA
LS1-d
Old November 3rd 07, 02:23 AM posted to rec.aviation.soaring
Marc Ramsey[_2_]
Given that "flaps" were his second priority after "easy to rig", that
could be fixed with a hack saw and a bit of time...
Old November 3rd 07, 02:51 AM posted to rec.aviation.soaring
rlovinggood
Marc,
Yes, yes, yes. He did mention flaps, but as UH mentioned, on the East
Coast, Standard Class ships do quite well and go "almost" as fast
(sometimes faster?) than the flapped variety.
Do you really need a hacksaw, or can you just add a "dummy" lever on
the left side of the cockpit, in order to give the left hand something
to do during flight?
Ray Lovinggood
LS1-d
Old November 3rd 07, 03:05 AM posted to rec.aviation.soaring
Marc Ramsey[_2_]
I think you and UH see flaps as just a go fast option, for a lot of us,
flaps are for going slow when we're trying to land in little dinky fields...
Marc
Old November 3rd 07, 04:37 AM posted to rec.aviation.soaring
Marc
20 and 24 are still wood gliders : look inside
SZD-55 has automatic hookups, no wood, big tanks for ridge, light
wings for assy,
Look at last Sunday OLC 1010 km from Mifflin.
RW
Old November 3rd 07, 05:45 AM posted to rec.aviation.soaring
What's a good first glider for someone transitioning from a CS77 and
- automatic hookups
- easy to rig
- flaps
- climbs well in weak conditions and runs reasonably well in average
Budget? Say 20-60k US, depending whether I go alone or with 1 or 2
partners.
Thanks.
Wad.
L/D =$/Distance. Tthat's what you are looking for?.
SZD55 kicks any asses
