Seems to be a common thing at contests or any other
time you are flying something different than what the pilot is use to pulling. How about the next time it happens to you, have your radio call be 'Towplane pulling Glider (Insert your callsign here), please speed up 5 MPH' or some such if you aren't clearly able to identify the towplane. Most of those guys know what glider they are pulling at the time. They keep track so they have a record of how many tows they made. Or better yet, spend a little time talking with the towpilots and getting to know them. When it is your turn, watch and see who comes by to pull you into the sky. If you are being pulled too slow or too fast, call the towpilot by name with your request. But do it very nicely, please. As John pointed out, these guys work hard so we can go play. And sometimes, they even get to go play, too. Thanks again to all that have towed me! Steve Leonard Wichita, KS |
On Nov 16, 8:44 pm, Steve Leonard
wrote: Seems to be a common thing at contests or any other time you are flying something different than what the pilot is use to pulling. How about the next time it happens to you, have your radio call be 'Towplane pulling Glider (Insert your callsign here), please speed up 5 MPH' or some such if you aren't clearly able to identify the towplane. Most of those guys know what glider they are pulling at the time. They keep track so they have a record of how many tows they made. Or better yet, spend a little time talking with the towpilots and getting to know them. When it is your turn, watch and see who comes by to pull you into the sky. If you are being pulled too slow or too fast, call the towpilot by name with your request. But do it very nicely, please. As John pointed out, these guys work hard so we can go play. And sometimes, they even get to go play, too. Thanks again to all that have towed me! Steve Leonard Wichita, KS If you are carrying water and the tow plane slows down below the stall speed what would happen. I felt things were close once and used the radio to request speeding up. Can't imagine rocking the wings when you are in that situation. |
Steve Leonard wrote:
have your radio call be 'Towplane pulling Glider (Insert your callsign here), please speed up Even better would be to know the callsign of your tow plane. I consider a short radio check with my tug before taking off a basic safety rule, YMMV. |
On 17 Nov, 04:44, Steve Leonard
wrote: Or better yet, spend a little time talking with the towpilots and getting to know them. I tend to have the opposite problem - tug pilots may not tow much wood, and often go rather fast. So whenever I can, I make a point of talking to the tuggy beforehand and letting them know my ideal speed range. Ian |
Hi Folks,
I'm new to this list. I'm the towpilot at Great Western Soaring in Crystalire which is in the Mojave desert, right up by the mountains, in California. Come and see us, you can find us on the web. Tow speed is always an issue. I have found very often, when glider pilots complain of incorrect speeds, it is because their AIS are not working properly. Yes it is a good idea to communicate with the towpilot, but how many glider 'renters' have their own radios?? Les H On Nov 16, 8:44 pm, Steve Leonard wrote: Seems to be a common thing at contests or any other time you are flying something different than what the pilot is use to pulling. How about the next time it happens to you, have your radio call be 'Towplane pulling Glider (Insert your callsign here), please speed up 5 MPH' or some such if you aren't clearly able to identify the towplane. Most of those guys know what glider they are pulling at the time. They keep track so they have a record of how many tows they made. Or better yet, spend a little time talking with the towpilots and getting to know them. When it is your turn, watch and see who comes by to pull you into the sky. If you are being pulled too slow or too fast, call the towpilot by name with your request. But do it very nicely, please. As John pointed out, these guys work hard so we can go play. And sometimes, they even get to go play, too. Thanks again to all that have towed me! Steve Leonard Wichita, KS |
Hey, glider pilots, go back to your FARs -- they require you to agree
with the tow pilot on four points before taking off: "airspeed limitations, emergency procedures, signals, and maximum angles of bank." (FAR 61.69). Some of this is standardized, so you don't have to say you'll use specific signals, but speeds vary according to ballasting, etc. So not only is it a good idea to talk to the tow pilot, it is actually a requirement. When I'm towing I want to talk to the glider pilot prior to hookup anyway so I know he has a working radio and I know who will be billed. So to standardize, I like towpilots to establish radio contact as you are being hooked up and find out WHO the pilot is and Where he wants to go. A third item is obviously the radio check, but if you've passed the name and destination along, you've also established that your radio is working. And this is the time to pass on your required tow speed. Fred |
On 17 Nov, 16:55, wrote:
Hey, glider pilots, go back to your FARs Our ... whats? Ian |
In article
s.com, Ian writes On 17 Nov, 04:44, Steve Leonard wrote: Or better yet, spend a little time talking with the towpilots and getting to know them. I tend to have the opposite problem - tug pilots may not tow much wood, and often go rather fast. So whenever I can, I make a point of talking to the tuggy beforehand and letting them know my ideal speed range. Ian A lot of years ago I was towed at 80 KPH when the glider had a placard reading Ne jamais depasser 65KPH. Nobody seemed the least bothered. -- Mike Lindsay |
Ian wrote:
On 17 Nov, 16:55, wrote: Hey, glider pilots, go back to your FARs Our ... whats? F@ckin' American Rules :-) Shawn |
| Thread Tools | |
| Display Modes | |
| Gear Up, pt 6 - p-47-being-towed.jpg (1/1) | Mitchell Holman | Aviation Photos | 1 | April 19th 07 04:34 PM |
| towed aerial target at Cabeza Prieta NWR | Dave Kearton | Aviation Photos | 6 | January 8th 07 11:13 AM |
| 4 Gliders towed by one towplane -picture- | [email protected] | Soaring | 25 | January 4th 06 08:09 AM |
| why so slow??!! | Heino & Deanne Weisberg | Home Built | 6 | November 6th 05 07:22 PM |
| Dallas westbound NE-1 need something towed? | [email protected] | Soaring | 0 | October 30th 05 12:38 AM |
