On Jan 1, 9:22 am, "
wrote: On Nov 28 2007, 9:41 pm, " wrote: On Nov 28, 5:15 pm, " wrote: On Nov 28, 2:18 wrote: sorry, I should have mentioned, you need Google Earth 4.2 and the current .NET installed It falls over with an immediate null reference exception on Windows XP SP2 on my ThinkPad. Anybody want the stack trace? email me. No cigar. I've got Google Earth 4.2 and the .NET 3.0 Framework with the very latest updates. When you say the current .NET exactly what version and update are you running against? On what OS platform? I'm on XP SP2 at the very latest public release updates. Anybody else got this to run? Darryl BTW a quick check with the debugger showed this apparently uses .NET 2.0, so you don't need to waste time downloading the NET 3.0 bloatware. I've emailedTobithe debug information. Darryl Tobias found the problem with his code and .NET strangeness on my laptop, seems like it may have affect some other laptops as well. Anyhow it is all working great on my ThinkPad now. Thanks Tobias for this great utility! Darryl Ramm Darryl, So does that mean there's an updated application to download from Tobias' site? I've been using it with a thinkpad, too, still think it's an absolutely great program but have noticed some strangeness, too. Thanks, Larry |
On Jan 1, 8:15 pm, wrote:
On Jan 1, 9:22 am, " wrote: On Nov 28 2007, 9:41 pm, " wrote: On Nov 28, 5:15 pm, " wrote: On Nov 28, 2:18 wrote: sorry, I should have mentioned, you need Google Earth 4.2 and the current .NET installed It falls over with an immediate null reference exception on Windows XP SP2 on my ThinkPad. Anybody want the stack trace? email me. No cigar. I've got Google Earth 4.2 and the .NET 3.0 Framework with the very latest updates. When you say the current .NET exactly what version and update are you running against? On what OS platform? I'm on XP SP2 at the very latest public release updates. Anybody else got this to run? Darryl BTW a quick check with the debugger showed this apparently uses .NET 2.0, so you don't need to waste time downloading the NET 3.0 bloatware. I've emailedTobithe debug information. Darryl Tobias found the problem with his code and .NET strangeness on my laptop, seems like it may have affect some other laptops as well. Anyhow it is all working great on my ThinkPad now. Thanks Tobias for this great utility! Darryl Ramm Darryl, So does that mean there's an updated application to download from Tobias' site? I've been using it with a thinkpad, too, still think it's an absolutely great program but have noticed some strangeness, too. Thanks, Larry There was an update recently, it at least fixed a .NET startup problems on some laptops where the application would crash as I described earlier. I am guessing that is very unlikely to be related to any other problems - except Tobias told me that the left hand control panel may size wrong on laptop displays but can just be changed manually. I have no idea what other things if any changed. Why don't you try the latest build anyhow and then email him a description of the strangeness you are seeing. He is very responsive. Darryl |
The new version works very well for me and it is a
really excellent tool. One tip for users - if you haven't already discovered it - if the terrain ahead seems slow to load then dip the view downwards momentarily and back up and it loads immediately. Thinking of it as a flight terrain viewer rather than a flight simulator three things would enhance it for me: A side map showing current location. The ability scan scan left/right and up/down while paused. An option to automatically jump the display to miss out thermals except for, say, the first and last turns. Thanks Tobi John Galloway At 06:54 02 December 2007, Bumper wrote: 'Henryk Birecki' wrote in message .. . I got it working today. Really amazing !! However I am seeing something very annoying. The terrain view keeps pulsating on me ('closer-further' for lack of better description). Does anyone see that as well? Can it be fixed? Cheers, Henryk Birecki This is normal. You are probably flying at Minden in rotor. bumper zz Minden, NV |
On Dec 2, 12:47 pm, John Galloway wrote:
Thinking of it as a flight terrain viewer rather than a flight simulator three things would enhance it for me: A side map showing current location. Thanks Tobi, fabulous! John Opened IGC GE and then opened the file with SeeYou file in Route mode and "futzed" with the replay speeds to get everything synced and then let them run. Had to continuosly sync using the GE time control but that was easy. The 2 applications kept time drifting, Google seems to have some small realtime issues. Worked like a charm though and is a great tool for learning the terrain in a area. I am headed for Sondrio in March and this helps me to learn the extended local terrain. I downloaded IGC files from the OLC for the Sondrio area. With SeeYou, GE and a chart I am statring to familarize myself with the area, including the "hot" thermal spots! Bob Thanks again Tobi! |
Google Earth | Frank Whiteley | Soaring | 3 | November 16th 07 12:36 AM |
Google Earth fun | Al Denelsbeck | Aviation Photos | 4 | January 11th 07 04:31 PM |
Google Earth - Glider | David Pye | Soaring | 1 | June 8th 06 04:39 PM |
SeeYou 3D and Google Earth | [email protected] | Soaring | 4 | May 23rd 06 04:24 AM |
Google Earth | ttaylor at cc.usu.edu | Soaring | 8 | September 22nd 05 12:07 PM |
