![]() I was just checking the rental terms at an FBO in the city I plan to visit over Christmas. I've got most of my hours in the type I wanted to rent and the FBO said they want 3 takes offs and landings, then a power on and power off stall. They charge the time to do this as dual. I can see 20 minutes of landings, then a climb to do the power on and off stalls... depending on traffic, it seems like it would take .75 to 1.0 dual hobbs time. Basically, I'd spend more money on the checkride than I intended to spend on the actual flight. Is this a little stiff or is it the normal practice? -- Dallas |
On Dec 6, 10:23 am, Dallas wrote:
I was just checking the rental terms at an FBO in the city I plan to visit over Christmas. I've got most of my hours in the type I wanted to rent and the FBO said they want 3 takes offs and landings, then a power on and power off stall. They charge the time to do this as dual. I can see 20 minutes of landings, then a climb to do the power on and off stalls... depending on traffic, it seems like it would take .75 to 1.0 dual hobbs time. Basically, I'd spend more money on the checkride than I intended to spend on the actual flight. Is this a little stiff or is it the normal practice? It's pretty normal. Sometimes they claim its an insurance requirement but of the FBO policies I've seen I've not seen one that actually says what a check out includes (other than landings). -Robert |
On 12/6/2007 1:23:39 PM, Dallas wrote:
Is this a little stiff or is it the normal practice? I would say it is normal. The one time I rented far from home I had to go through a three hours checkride for a C172S rental, a model in which I had about 500 hours at the time, at an FBO in Palm Springs, CA. Look at it this way: It is always valuable to have a different instructor evaluating your piloting skills. If you are fortunate you might actually receive some previously unknown tips or lessons from the instructor during your checkride. -- Peter |
Dallas wrote:
I was just checking the rental terms at an FBO in the city I plan to visit over Christmas. I've got most of my hours in the type I wanted to rent and the FBO said they want 3 takes offs and landings, then a power on and power off stall. They charge the time to do this as dual. I can see 20 minutes of landings, then a climb to do the power on and off stalls... depending on traffic, it seems like it would take .75 to 1.0 dual hobbs time. Basically, I'd spend more money on the checkride than I intended to spend on the actual flight. Is this a little stiff or is it the normal practice? My check flights usually went like this; I'd always start you off by asking you some weight and balance questions based on the specific airplane being checked out. By the time I had watched you preflight the airplane I pretty much knew what to expect from you in the air. By the time we reached the end of the runway I had either verified my initial impression or based on your performance that far, made a mental list of things I wanted to verify in the air. By the time you rotated, climbed to altitude and leveled the airplane I had a good idea of your general flying abilities. At this point I would have you fly the airplane at minimum controllable airspeed and note your skill and comfort level doing that. Then I'd have you do a simple stall series power on and off going as deep with the stall configurations as I deemed necessary as you progressed while performing them. Then we'd go into the pattern where we'd do a power approach and one with no power available from the key position, preferably on a crosswind runway. If this all went well, you'd get the airplane. Generally, this can be done in an hour if all goes well. This should be about standard in the industry unless the pilot being checked out is known to the operation and/or the check pilot. Expect this if coming in cold asking for a check ride. -- Dudley Henriques |
Dallas wrote:
I was just checking the rental terms at an FBO in the city I plan to visit over Christmas. I've got most of my hours in the type I wanted to rent and the FBO said they want 3 takes offs and landings, then a power on and power off stall. They charge the time to do this as dual. I can see 20 minutes of landings, then a climb to do the power on and off stalls... depending on traffic, it seems like it would take .75 to 1.0 dual hobbs time. Basically, I'd spend more money on the checkride than I intended to spend on the actual flight. Is this a little stiff or is it the normal practice? That's not uncommon at all. After all, they don't know you from Adam so they want to make sure you are in fact a safe and competent pilot before they rent you an airplane. Once you are checked out you will be able to rent from them anytime. |
Dallas wrote:
Is this a little stiff or is it the normal practice? It's more normal than not, in my experience. On past sightseeing trips in places I don't go to often, I've just brought the CFI with us, skipping the formal checkride. |
B A R R Y wrote in news:H5Y5j.30695$Pv2.21285
@newssvr23.news.prodigy.net: Dallas wrote: Is this a little stiff or is it the normal practice? It's more normal than not, in my experience. On past sightseeing trips in places I don't go to often, I've just brought the CFI with us, skipping the formal checkride. Wise anyway. When I was a kid, one of the CFIs at the place I was working gave one of his buds who had been flying a 727 for a living fly a rental cherokee after only a couple of minutes checkout. half an hour later, a 110 knot approach and touchdown rendered a brand new cherokee environmentally friendly. Bertie |
![]() "Dallas" wrote in message . .. I was just checking the rental terms at an FBO in the city I plan to visit over Christmas. I've got most of my hours in the type I wanted to rent and the FBO said they want 3 takes offs and landings, then a power on and power off stall. They charge the time to do this as dual. I can see 20 minutes of landings, then a climb to do the power on and off stalls... depending on traffic, it seems like it would take .75 to 1.0 dual hobbs time. Basically, I'd spend more money on the checkride than I intended to spend on the actual flight. Is this a little stiff or is it the normal practice? Based on my experience, this is normal for a very reasonable FBO. Many require as much as twice that. |
B A R R Y wrote:
Dallas wrote: Is this a little stiff or is it the normal practice? It's more normal than not, in my experience. On past sightseeing trips in places I don't go to often, I've just brought the CFI with us, skipping the formal checkride. That's what I did when I rented a plane in England. I flew and he kept me honest. -- Regards, Ross C-172F 180HP KSWI |
![]() "Bertie the Bunyip" wrote in message .. . B A R R Y wrote in news:H5Y5j.30695$Pv2.21285 @newssvr23.news.prodigy.net: Dallas wrote: Is this a little stiff or is it the normal practice? It's more normal than not, in my experience. On past sightseeing trips in places I don't go to often, I've just brought the CFI with us, skipping the formal checkride. Wise anyway. When I was a kid, one of the CFIs at the place I was working gave one of his buds who had been flying a 727 for a living fly a rental cherokee after only a couple of minutes checkout. half an hour later, a 110 knot approach and touchdown rendered a brand new cherokee environmentally friendly. Bertie How bad did he screw it up? |
Cessna 210 Rental | CPilot | Piloting | 3 | June 17th 07 08:30 AM |
O2 Rental.. | Dan | Piloting | 1 | September 15th 06 07:14 PM |
PW-5 rental for WC Nationals | Bill Thar | Soaring | 30 | January 14th 06 08:46 PM |
Saw a low-flying rental... let the FBO know? | Yossarian | Piloting | 48 | October 3rd 04 07:17 AM |
PW-5 Rental | BTIZ | Soaring | 0 | July 11th 03 09:45 PM |
